Windows 10: after update my laptop fan was stuck on high speed and the power settings would not work right
Discus and support after update my laptop fan was stuck on high speed and the power settings would not work right in Windows 10 Software and Apps to solve the problem; Hello I have windows 11 and got the 22h2 update. Then about a hour later the fan speed went to high speed and never has gone back to cycle on and off... Discussion in 'Windows 10 Software and Apps' started by curtjackson, Oct 8, 2022.
  1. after update my laptop fan was stuck on high speed and the power settings would not work right
    Hello I have windows 11 and got the 22h2 update. Then about a hour later the fan speed went to high speed and never has gone back to cycle on and off when needed like it used to. And I have the power settings for the screen set right and when i stop using my laptop the screen would not go off until the correct times it was set at. Now in about 1 minute the screen goes off when plugged in or unplugged when i stop using it. and then i have to sign back in right away instead of it not being used for 15 minutes like before then i would have to sign back in. Now if i let it sit for 1 min the scree
  2. DaveM121 Win User
    Manually adjust Lenovo S740 Fan speed
    Hi Tatinausa,
    Generally, when the processor is running at a high clock speed, the fans should ramp up to full speed automatically to keep the system cool.
    On that model, the only option may be to change the power plan.
    Open the old Control Panel (not the Settings app), at the top right, set View to icons
    Open Power Options.
    What Power Plan is your laptop set to, is that Balanced?
    If it is, the fan speeds should adjust automatically
    Do you see other Power Plans, like Performance or Ultimate performance?
    Either of those should set the fans to be always at top speed.
    DaveM121, Oct 8, 2022
  3. Jack2063 Win User
    Laptop fan 1 not working?
    Hey, for a while I've noticed that one of my laptop fans on my gaming laptop does not work. I have a program on my laptop called Dragon Gaming Centre and it says that fan 1 speed is 0 RPM, but my laptop fan 2 speed is about 5000 RPM when I have it on high.
    Don't know if it's possible that I turned it off somehow or if it could be a physical issue with it being broken.
    I was wondering if I could have some suggestions on how how to troubleshoot what the problem is so I can know how to fix it and solutions if possible. It's caused me lots of problems already because my CPU overheats and causes me to get low fps spikes in
    games.
    Thank you so much for your time and help. after update my laptop fan was stuck on high speed and the power settings would not work right :)
    Jack2063, Oct 8, 2022
  4. after update my laptop fan was stuck on high speed and the power settings would not work right
    Fan speed too high and receives black screen
    I reset my pc too factory settings now the fan speed on all fans are rela high. will not show anything on display screen.
    Original title: pc
    michaelbeard_860, Oct 8, 2022
  1. after update my laptop fan was stuck on high speed and the power settings would not work right - Similar Threads - update laptop fan
  2. My screen turns black but power stays on. sometimes fans speed up high too.
    My screen turns black but power stays on. sometimes fans speed up high too.: Ive tried uninstalling drivers with DDU and reinstalling drivers/using different versions of drivers/Reseating the gpu/cpu/ramnothing worked. eventually my screen started turning off right after i entered my pin on start up sometimesi checked my event logger and found thisThe...
  3. My screen turns black but power stays on. sometimes fans speed up high too.
  4. high fan speed when idle
    high fan speed when idle: hello,I bought a new gaming laptop, the laptop is totally new and clean, after 2 days from buying it, I have noticed an issue, the fan is on 2000 RPM when idle , according to task manger, most of the time CPU usage around 1% to 5%, the problem has started two days ago, before...
  5. high fan speed when idle
  6. after update my laptop fan was stuck on high speed and the power settings would not work right
    after update my laptop fan was stuck on high speed and the power settings would not work right: Hello I have windows 11 and got the 22h2 update. Then about a hour later the fan speed went to high speed and never has gone back to cycle on and off when needed like it used to. And I have the power settings for the screen set right and when i stop using my laptop the screen...
  7. My Laptop Fan Speeds Up After Sleep
    My Laptop Fan Speeds Up After Sleep: Hi, I'm using my "Asus UX434FLC" laptop for a couple of months now, but I'm having this issue over the past several days: when I put my laptop in sleep by closing the lid and open it back, fan starts to run at the top speed. This started a couple of days ago and task...
  8. High fan speed
    High fan speed: My laptop is dual booted with Ubuntu 18.04 LTS. Both in windows and ubuntu its fan starts to run in maximum speed in normal use. It started to happenn only when I dual-booted, so its not a hardware problem. Moreover, I found a process named 'frontend' is running in the...
  9. Fan randomly starts at high speed
    Fan randomly starts at high speed: While not doing any cpu intensive tasks, my fan has started up randomly very fast, and i have to restart my laptop to make it go back to normal https://answers.microsoft.com/en-us/windows/forum/all/fan-randomly-starts-at-high-speed/1e84cd7c-df8b-49c4-a158-d2ff1f1897b9
  10. Unstable fan speed after 1803 update
    Unstable fan speed after 1803 update: Actually, I might be imagining things. But I am noticing my CPU fan is running erratically. I have the PM set to balance. I have a custom desktop. Specs are Asus Sabertooth Z170s, i5 6600K 4.2 ghz using a Coolmaster EVO cooler. 16 gigs DDR4-3000 (2 x 8 gig sticks), Gigabyte...
