Windows 10: after update my laptop fan was stuck on high speed and the power settings would not work right
Discus and support after update my laptop fan was stuck on high speed and the power settings would not work right in Windows 10 Gaming to solve the problem; Hello I have windows 11 and got the 22h2 update. Then about a hour later the fan speed went to high speed and never has gone back to cycle on and off... Discussion in 'Windows 10 Gaming' started by curtjackson, Oct 8, 2022.
after update my laptop fan was stuck on high speed and the power settings would not work right - Similar Threads - update laptop fan
My screen turns black but power stays on. sometimes fans speed up high too.
in Windows 10 GamingMy screen turns black but power stays on. sometimes fans speed up high too.: Ive tried uninstalling drivers with DDU and reinstalling drivers/using different versions of drivers/Reseating the gpu/cpu/ramnothing worked. eventually my screen started turning off right after i entered my pin on start up sometimesi checked my event logger and found thisThe... -
in Windows 10 Software and AppsMy screen turns black but power stays on. sometimes fans speed up high too.: Ive tried uninstalling drivers with DDU and reinstalling drivers/using different versions of drivers/Reseating the gpu/cpu/ramnothing worked. eventually my screen started turning off right after i entered my pin on start up sometimesi checked my event logger and found thisThe... -
high fan speed when idle
in Windows 10 Gaminghigh fan speed when idle: hello,I bought a new gaming laptop, the laptop is totally new and clean, after 2 days from buying it, I have noticed an issue, the fan is on 2000 RPM when idle , according to task manger, most of the time CPU usage around 1% to 5%, the problem has started two days ago, before... -
in Windows 10 Software and Appshigh fan speed when idle: hello,I bought a new gaming laptop, the laptop is totally new and clean, after 2 days from buying it, I have noticed an issue, the fan is on 2000 RPM when idle , according to task manger, most of the time CPU usage around 1% to 5%, the problem has started two days ago, before... -
in Windows 10 Software and Appsafter update my laptop fan was stuck on high speed and the power settings would not work right: Hello I have windows 11 and got the 22h2 update. Then about a hour later the fan speed went to high speed and never has gone back to cycle on and off when needed like it used to. And I have the power settings for the screen set right and when i stop using my laptop the screen... -
My Laptop Fan Speeds Up After Sleep
in Windows 10 Performance & MaintenanceMy Laptop Fan Speeds Up After Sleep: Hi, I'm using my "Asus UX434FLC" laptop for a couple of months now, but I'm having this issue over the past several days: when I put my laptop in sleep by closing the lid and open it back, fan starts to run at the top speed. This started a couple of days ago and task... -
High fan speed
in Windows 10 BSOD Crashes and DebuggingHigh fan speed: My laptop is dual booted with Ubuntu 18.04 LTS. Both in windows and ubuntu its fan starts to run in maximum speed in normal use. It started to happenn only when I dual-booted, so its not a hardware problem. Moreover, I found a process named 'frontend' is running in the... -
Fan randomly starts at high speed
in Windows 10 BSOD Crashes and DebuggingFan randomly starts at high speed: While not doing any cpu intensive tasks, my fan has started up randomly very fast, and i have to restart my laptop to make it go back to normal https://answers.microsoft.com/en-us/windows/forum/all/fan-randomly-starts-at-high-speed/1e84cd7c-df8b-49c4-a158-d2ff1f1897b9 -
Unstable fan speed after 1803 update
in Windows 10 Drivers and HardwareUnstable fan speed after 1803 update: Actually, I might be imagining things. But I am noticing my CPU fan is running erratically. I have the PM set to balance. I have a custom desktop. Specs are Asus Sabertooth Z170s, i5 6600K 4.2 ghz using a Coolmaster EVO cooler. 16 gigs DDR4-3000 (2 x 8 gig sticks), Gigabyte...
