Windows 10: After updating sound drivers my laptop lost sound input and sound output devices and there...
Discus and support After updating sound drivers my laptop lost sound input and sound output devices and there... in Windows 10 Software and Apps to solve the problem; After updating sound drivers my laptop lost sound input and sound output devices and there is yellow mark om Intel Smart Sound Technology OED. There is... Discussion in 'Windows 10 Software and Apps' started by Kamlesh Bhatt1, Sep 20, 2024.
  1. After updating sound drivers my laptop lost sound input and sound output devices and there...
    After updating sound drivers my laptop lost sound input and sound output devices and there is yellow mark om Intel Smart Sound Technology OED. There is no sound now. How to solve this issue?
  2. No sound input or output devices
    Since updating WIndows I no longer have any sound input or output devices listed under device manager - sound video games controllers. Intel smart sound technology oed had yellow warning triangle.
    What can I do to get the sound working on my laptop.
    T Chinn9090, Sep 20, 2024
  3. Shawn Brink, Sep 20, 2024
  4. After updating sound drivers my laptop lost sound input and sound output devices and there...
    Since the upgrade to Windows 10, my Toshiba laptop with DTS sound card sounds very bad.
    As you have issues with sound on Windows 10, I suggest you to try the below and check.
    Steps to update the drivers for audio.
    • Press Windows+X and click on Device Manager.
    • Expand Audio inputs and outputs, right click on the
      Realtek High Definition Audio and click on
      Update driver software.
    To find drivers for sound on Toshiba laptop, I suggest you to refer to the below link:
    http://support.toshiba.com/drivers
    For further reference:Fix
    sound problems
    Hope it helps. Reply to the post with an updated status of this issue to assist you further.
    Deepika Gowda, Sep 20, 2024
  1. After updating sound drivers my laptop lost sound input and sound output devices and there... - Similar Threads - updating sound drivers
  2. No Laptop Sound Output Sound Device
    No Laptop Sound Output Sound Device: On 9/30/24, my laptop sound was working as intended. On 10/1/24, it stopped working. I have tried uninstalling the drivers, updating them, and troubleshooting, but nothing seems to work. There have been no recent Windows update. Currently, my laptop says that there are no...
  3. No Laptop Sound Output Sound Device
    After updating sound drivers my laptop lost sound input and sound output devices and there...: After updating sound drivers my laptop lost sound input and sound output devices and there is yellow mark om Intel Smart Sound Technology OED. There is no sound now. How to solve this issue?...
  5. No sound input or output devices
    No sound input or output devices: Since updating WIndows I no longer have any sound input or output devices listed under device manager - sound video games controllers. Intel smart sound technology oed had yellow warning triangle. What can I do to get the sound working on my laptop....
  6. No sound input or output devices
  7. Laptop Not Detecting Sound Input or Output
    Laptop Not Detecting Sound Input or Output: I was attempting to watch a lecture video this morning and sound would not come out of my laptop's internal speakers. When I checked sound settings it said it found no audio devices. I ignored it and moved on because I could juts connect my bluetooth headphones and it worked....
  8. Input and output Sound
    Input and output Sound: Hi there! I need help with my Input and Output sound. I have recently bought headphones that had a mic on the cable. When I switched the headphones as my output it doesn't show my headphones mic as an input. But if I put my headphones mic as in input it doesn't put my...
  9. Sound input and output
    Sound input and output: I was wondering, how do I make it so that the input and output of sound, basically the microphone and earphone, are in the same place, as I don't have headphones but still want to use my microphone on the earphones...
  10. no input or output sounds
    no input or output sounds: i recently did a hard reset now sound nor mic are working i am on an rca 2 n 1 windows10 also my touch screen is all screwy https://answers.microsoft.com/en-us/windows/forum/all/no-input-or-output-sounds/fb9550bd-6813-4bd2-be12-c6d35d2c47da
