Windows 10: Audio and microphone low sound or no sound when using 3rd party applications
Discus and support Audio and microphone low sound or no sound when using 3rd party applications in Windows 10 Gaming to solve the problem; I recently bought a new laptop that came with Windows 11 installed NOT an upgrade. The sound and mic work fine using WIndows. However, any time I use a... Discussion in 'Windows 10 Gaming' started by CherylColeman1, Jan 8, 2022.
  1. Audio and microphone low sound or no sound when using 3rd party applications
    I recently bought a new laptop that came with Windows 11 installed NOT an upgrade. The sound and mic work fine using WIndows. However, any time I use a Windows compatible application, or Zoom or another 3rd party application, the sound is inaudible and are hearing it as garbled or no sound at. I bought an audio interface and thought that might solve the issue - it did not. My old WIndows 10 system has no issues whatsoever. I did a search and found there are a number of people having the same issue - and short of uninstalling drivers, none of the troubleshooting worked. THanks.
  2. Elixed Win User
    3rd party applications not detecting microphone.
    I recently did a full reset of my PC and my microphone stopped detecting any sound on 3rd party applications like browsers or Discord. When I try to record anything, silence is recorded. However it works perfectly fine on all native Windows apps and surprisingly
    League of Legends voice chat. Before the reset, everything worked perfectly on all applications. I have only one microphone device enabled (Realtek High Definition Audio) and it's my built-in microphone of my laptop. I've tried everything i found on the internet
    but nothing seems to work.
    • I updated microphone drivers.
    • I allowed apps to access my microphone (in microphone privacy settings)
    • I installed all windows updates
    • I disabled all sound effects on the device.
    Is there anything else I could try?
    Elixed, Jan 8, 2022
  3. Blue Snowball microphone with low audio quality on Windows 10.
    Hi Eoin,
    I realize the inconvenience you are experiencing with Windows 10. I will certainly help you.
    This issue might occur if there is change microphone or audio settings.
    To assist you better, please provided us the information below:
    • Have you tried to check the issue by connecting with another microphone device on the computer?
    • Are you getting any error message on the computer when you use the Microphone?
    I suggest you to follow the steps provided in the Microsoft Help Article about sound related issues and check if it helps.
    Fix sound problems:
    https://support.microsoft.com/en-us...eac-4566-867a-98d2761a770d/fix-sound-problems
    Please get back to us with an update on with low sound through Microphone, we will be happy to help.
    Nyima Yonten, Jan 8, 2022
  4. Ethan's Win User
    Adding 3rd party sound in sound scheme
    Original title: Sounds
    I use a sound scheme that used 3rd-party sounds (Windows 8 sounds downloaded from the internet) and when I get notified or check the volume, it doesn't make a sound. Do you think dragging the 3rd-party sounds into C:\Windows\Media would make them work??
    Ethan's, Jan 8, 2022
  1. Audio and microphone low sound or no sound when using 3rd party applications - Similar Threads - Audio microphone low
  2. No low end sound when using speakers.
    No low end sound when using speakers.: Whenever i plug in my Yamaha HS4 Studio Monitors into my laptop the sound quality is very low, the low end is basically not there at all. This problem is true with headphones as well as the laptop speakers themselves. I have plugged my speakers and headphones into other...
  3. Low microphone voice sound
    Low microphone voice sound: My microphone is good but it is barely recording voice sound i have also increased it to100 from properties, it only recognizes breathing air sound easily. I have tried updating driver from device manager and it says that I have already latest driver installedI have also...
  4. Low microphone voice sound
  5. Low microphone voice sound
  6. Airpod sound extremely low on pc when microphone used
    Airpod sound extremely low on pc when microphone used: I've noticed recently after some windows update that my Airpods pro gen 2 generate extremely low sound, but only when I'm on Zoom/Skype where also my microphone is being used. If I switch the use of the microphone from Airpod to some other mic, the sound volume on Airpods...
  7. Airpod sound extremely low on pc when microphone used
  8. Audio and microphone low sound or no sound when using 3rd party applications
    Audio and microphone low sound or no sound when using 3rd party applications: I recently bought a new laptop that came with Windows 11 installed NOT an upgrade. The sound and mic work fine using WIndows. However, any time I use a Windows compatible application, or Zoom or another 3rd party application, the sound is inaudible and are hearing it as...
  9. Prevent 3rd Party Applications from Adjusting Microphone
    Prevent 3rd Party Applications from Adjusting Microphone: I want Windows 10 to prevent 3rd Party Applications from adjusting the microphone gain.I spent a year troubleshooting this problem. Brought about 1000USD worth of mics, headphones, external mics trying to eliminate a ground loop hum and ambient noise from being picked up by...
  10. 3rd party applications not detecting microphone.
    3rd party applications not detecting microphone.: Hello, I recently did a full reset of my PC and my microphone stopped detecting any sound on 3rd party applications like browsers or Discord. When I try to record anything, silence is recorded. However it works perfectly fine on all native Windows apps and surprisingly...
