Windows 10: Audio issue between monitor audio and system audio.
Discus and support Audio issue between monitor audio and system audio. in Windows 10 Software and Apps to solve the problem; So, I have a monitor that can extract audio from HDMI through a 3.5mm jack on its back. The problem is the monitor will take over the audio and the... Discussion in 'Windows 10 Software and Apps' started by Lingxiang Zhu, Dec 1, 2023.
Audio issue between monitor audio and system audio. - Similar Threads - Audio issue between
in Windows 10 GamingAudio issue between monitor audio and system audio.: So, I have a monitor that can extract audio from HDMI through a 3.5mm jack on its back. The problem is the monitor will take over the audio and the computer stop using its own 3.5mm jack so I had to plug in the monitor. The computer/motherboard audio still appears in the... -
System Audio
in Windows 10 Software and AppsSystem Audio: why my new hp laptop not supporting higher audio formats?my 5 year old laptop used to support 192000hz but this new one is stuck at 16bit 48000hzwhen I used to click at drop down menu it shows only only one option availablePls help me... -
System Audio
in Windows 10 GamingSystem Audio: why my new hp laptop not supporting higher audio formats?my 5 year old laptop used to support 192000hz but this new one is stuck at 16bit 48000hzwhen I used to click at drop down menu it shows only only one option availablePls help me... -
Audio jumps between headset and machine audio
in Windows 10 GamingAudio jumps between headset and machine audio: Hi,I've lost control over my audio settings.As you can see in the enclosed video, the screen jumps and doesn't let to set it to a specific option, my preference, the headset.I tried to disable windows audio service and reboot, update drive, Nothing helped.Could you suggest a... -
in Windows 10 Software and AppsAudio jumps between headset and machine audio: Hi,I've lost control over my audio settings.As you can see in the enclosed video, the screen jumps and doesn't let to set it to a specific option, my preference, the headset.I tried to disable windows audio service and reboot, update drive, Nothing helped.Could you suggest a... -
what is difference between audio and pro audio
in Windows 10 Customizationwhat is difference between audio and pro audio: [ATTACH] does audio and pro audio same? https://answers.microsoft.com/en-us/windows/forum/all/what-is-difference-between-audio-and-pro-audio/6a4626e7-0f6f-4f63-a155-d2e761496455 -
System hangs in between with Audio issues
in Windows 10 Ask InsiderSystem hangs in between with Audio issues: I am on Windows 10 2004 which I installed a couple of days ago and the Maximus Formula X board with i7 8700k and 32GB RAM. I am facing this issue since the install - After every couple of hours the cursor freezes for a few seconds and the sound driver shows jack unplugged... -
Audio Issues Switching Between HDMI Inputs
in Windows 10 Drivers and HardwareAudio Issues Switching Between HDMI Inputs: Having problems with audio when switching between HDMI Inputs. Have tried updating drivers, changing output devices, windows audio restart, switching which HDMI they are on, changed HDMI cords etc. NOTHING works. We have a PC in HDMI 3 and a PS4 in HDMI 2. HDMI 2 always works... -
system audio
in Windows 10 Drivers and Hardwaresystem audio: so this has been driving me insane for about 2 weeks now but no matter what im doing whether im in a call or not or even when my headset is unplugged, system sounds like anything from watching videos or playing music from either the desktop or the web browser is not only...
