Windows 10: Audio splitter not working when using it on cosmic byte G4000 head phones and audio...
Discus and support Audio splitter not working when using it on cosmic byte G4000 head phones and audio... in Windows 10 Drivers and Hardware to solve the problem; pls help today the splitter and headphones arrived but when i combine the and connect to my pc it is not workingmy laptop model is lenovo G580 and the... Discussion in 'Windows 10 Drivers and Hardware' started by Rohan_200919, Jun 24, 2021.
Audio splitter not working when using it on cosmic byte G4000 head phones and audio... - Similar Threads - Audio splitter working
Headset mic not working audio splitter
in Windows 10 Software and AppsHeadset mic not working audio splitter: I recently bought an audio splitter cus my laptop only has 1 jack but my headphones use 1 for sound 1 for microphone but when I plugged it in my laptop didnt recognize the microphone and its continuing to use the built in microphone.Does someone know a way to fix?Laptop is hp... -
No audio output when using a headset splitter, but mic works
in Windows 10 GamingNo audio output when using a headset splitter, but mic works: I've tried the headset by itself and it works but mic doesn't. So i go to use the splitter then the mic works and there's no audio. I have tried running a diagnostic but nothing, It's not that the volume was down. Please help.... -
in Windows 10 Software and AppsNo audio output when using a headset splitter, but mic works: I've tried the headset by itself and it works but mic doesn't. So i go to use the splitter then the mic works and there's no audio. I have tried running a diagnostic but nothing, It's not that the volume was down. Please help.... -
Cosmic byte wired controllers not working
in Windows 10 GamingCosmic byte wired controllers not working: Hi team .. Me and my friend bought two new cosmic byte controllers. We are unable to connect both of them at a time as one of them blinks. Can someone help on this... -
in Windows 10 Software and AppsCosmic byte wired controllers not working: Hi team .. Me and my friend bought two new cosmic byte controllers. We are unable to connect both of them at a time as one of them blinks. Can someone help on this... -
in Windows 10 Drivers and HardwareCosmic byte wired controllers not working: Hi team .. Me and my friend bought two new cosmic byte controllers. We are unable to connect both of them at a time as one of them blinks. Can someone help on this... -
Audio Splitter not working properly
in Windows 10 Drivers and HardwareAudio Splitter not working properly: I just bought a new audio splitter from amazon because my predator helios 300 has only 1 audio jack, I wanted to use a headphone and a separate mic, when I plug in the audio splitter it prompts me to select between the following Line in Mic in Headphone Speaker out Headset... -
Headset microphone (with audio splitter) not working
in Windows 10 Drivers and HardwareHeadset microphone (with audio splitter) not working: My Acer Predator (Helios 300) laptop has a singular audio port, which I use with my headset that has a separate microphone and headphone cable. I have used an audio splitter to get around this issue for a while now, and it has worked perfectly fine. Normally when I would plug... -
Audio when using head phones is distorted
in Windows 10 Drivers and HardwareAudio when using head phones is distorted: So, as the title says the sound is distorted when using headphones. The headphones work fine in everything else but refuse to work here. I have tried to reinstall the drivers. I have Realtek audio. When i use them i can hear the music of a video but not the speaker. Please...
