Windows 10: Audio Volume Too Loud for System Sound ONLY after installing old versions of audio card driver
Discus and support Audio Volume Too Loud for System Sound ONLY after installing old versions of audio card driver in Windows 10 Gaming to solve the problem; I accidentally installed older versions of audio driver: aud_win10_64_6.0.8716.1 and it requires 2 times of reboot.After reboot, the system volume goes... Discussion in 'Windows 10 Gaming' started by Keyu_520, Sep 5, 2022.
  1. Keyu_520 Win User
    I accidentally installed older versions of audio driver: aud_win10_64_6.0.8716.1 and it requires 2 times of reboot.After reboot, the system volume goes very loud that I can only use it at 10%. While I'm playing music or watching videos, the sound is missing high frequencies. However it's not missing sound quality for system sound. And with headphone both the volume and the quality are normal. This is a new laptop bought 3 months ago, very unlikely to be hardware problems.Here's my laptop and system:ROG Strix SCAR 17 2022 G733Win 11Here's what I tried and didn't work:RebootUpdate and uninstal
  2. Loud Audio Until Volume is Adjusted (Realtek Audio Driver)
    Hi Michael,
    I understand the inconvenience caused. I will be glad to assist you with this.
    Thank you for mentioning the steps you have tried to resolve the issue. We appreciate your effort.
    To better assist you, do let us know the make and model of the computer.
    I would suggest you to try using the generic audio driver that comes with Windows.
    Here's how: in Device Manager, right-click (or tap and hold) your audio driver >
    Update driver software... > Browse my computer for driver software
    > Let me pick from a list of device drivers on my computer, select
    High Definition Audio Device, select Next, and follow the instructions to install it.
    Also, try turning off the audio enhancement by following the steps below:
    • Go to Start, enter Sound, and select Sound Control Panel
      from the list of results.
    • On the Playback tab, right-click (or tap and hold) the Default Device
      and select Properties.
    • On the Enhancements tab, select the Disable all enhancements
      check box and try to play your audio device.
    • If that doesn't work, select Cancel and, on the Playback
      tab, select another default device (if you have one), select the Disable all enhancements check box, and try to play audio again. Do this for each default device.
    Let us know the result.
    Wungraileng Vashi, Sep 5, 2022
  3. tny770 Win User
    Realtek audio too loud
    I was wondering seeing as there are some with driver modding skills around here could tell me if it's possible to change the seemingly hard-coded volume level in Realtek drivers.
    I have a Gigabyte board with an ALC1150 and no matter which driver I try the audio volume is so loud I have to turn Windows global volume to 10% otherwise it hurts my ears (I'm using headphones).
    I'm not an expert but it's like Realtek are over amplifying the stereo output ?, I've tried enabling the loudness equalization in Realtek control panel & this only partially fixes it for music or Youtube but system audio sounds are still often ear piercingly loud. If I change the audio output to the GPU and plug headphones into monitor it works largely okay volume is around 70-80% level and comfortable though it doesn't sound as good.
    Anyone any ideas on this ?
    Thanks.
    [My backup plan is to get a spdif/optical to analogue DAC, and use the optical out on the Realtek and see if that is any better or look at a sound card]
    tny770, Sep 5, 2022
  4. Audio Volume Too Loud for System Sound ONLY after installing old versions of audio card driver
    Audio Sound Card
    Suddenly lost all sound. When I turned on computer today, I get a message that it can't find 'Conexant SmartAudio HD' I don't know what happened or how to get it back.
    System information Audio lists as follows:
    Sound Card - Conexant Smart Audio HD
    Driver Provider Conexant
    Driver Version 8.54.40,8-2-2012
    Driver C:\windows\system32\drivers\chdrt64.sys
    Any idea what I have to do to get my sound back? Running windows 10.
    AllanFluke_522, Sep 5, 2022
  1. Audio Volume Too Loud for System Sound ONLY after installing old versions of audio card driver - Similar Threads - Audio Volume Too
  2. Audio way too loud on lowest setting
    Audio way too loud on lowest setting: My headphones play audio too loud - I have never had this issue before and when I connect them to another device, I did not face this issue. Even the volume six is too loud.As you can see in the attached picture, the volume is overflowing and I have no idea what to do. It it...
  3. Audio too loud on headset
    Audio too loud on headset: I'm currently using a headset connecting via usb, I have tried the sound troubleshooter and checked if my headset was a default device. Yet, no matter how much I lower system sounds my headset plays sounds at its highest setting. This has been happening today....
  4. Audio too loud on headset
  5. Audio Volume Too Loud for System Sound ONLY after installing old versions of audio card driver
    Audio Volume Too Loud for System Sound ONLY after installing old versions of audio card driver: I accidentally installed older versions of audio driver: aud_win10_64_6.0.8716.1 and it requires 2 times of reboot.After reboot, the system volume goes very loud that I can only use it at 10%. While I'm playing music or watching videos, the sound is missing high frequencies....
  6. Volume too LOUD
    Volume too LOUD: Something is wrong with my volume. It's only on 9 and yet it feels like it's on like 24. This only started happening after i restarted for an update. Anyone know what is wrong and how I can fix it?...
  7. Volume is too loud on 5% volume
    Volume is too loud on 5% volume: Hello i have a wired JBL headphones and i always have to put my volume on 4% or less because its too loud and my bluetooth headphones didnt have that problem before I tried using troubleshooter it didnt help....
  8. Audio too loud even if the volume level is low
    Audio too loud even if the volume level is low: I used to set the level to around 60%, however now I get the same loudness from 6 - 8%. This happened suddenly when I ran Audacity. The device I am using is Logitech G633 Gaming Headset. I have so far tried several solutions from other similar questions posted here and on...
  9. Sound is too loud even when it's on volume 2...
    Sound is too loud even when it's on volume 2...: Hi guys im rather frustrated now... I recently got a new desktop to windows 10 and everything is working fine but that was till I noticed that the sound was being too loud for what it should be. Let's say right now i have it on volume 15 it will sound like volume 80, this...
  10. Sound is too loud even when it's on volume 2...
