Windows 10: Battery Management, USB Flash Drive Missing, USB Plugging Problems etc
Discus and support Battery Management, USB Flash Drive Missing, USB Plugging Problems etc in Windows 10 Drivers and Hardware to solve the problem; I have following questions about Windows problems:1. Sometimes happens that my USB Flash Drive neither show up, nor is turned on when plugged to... Discussion in 'Windows 10 Drivers and Hardware' started by OnePerson1, May 28, 2021.
  1. Battery Management, USB Flash Drive Missing, USB Plugging Problems etc
    I have following questions about Windows problems:1. Sometimes happens that my USB Flash Drive neither show up, nor is turned on when plugged to Windows. I know that it is problem of Windows since other USB Flash Drive sometimes behave the same way. My question is - As it's not shown up in Windows at all, and I turn off the PC then the USB Flash Drive won't get corrupted because of it, if I unplug it when Windows was turned off? Pointing out that the Flash Drive didn't show up on Windows or Unrecognized.2. Why in new PCs 11 generation of Intel there is no Advanced Options in Battery Manage
  2. Lazzer408 Win User
    help. USB drive isn't assigned a drive letter.
    Any usb flash drive I plug into my computer isn't assigned a drive letter. The physical drive shows in the "safely remove hardware" but it doesnt show up in disk management. I have tried to populate the volume thru the safely remove hardware properties window and it does pop up in the list but it doesn't stay there. This isn't a format or assign a letter problem. It's more complicated then that. Maybe one of the services needed for usb drive management was disabled? Suggestions needed. btw external usb harddrives work fine.
    Lazzer408, May 28, 2021
  3. Ferdz Amp Win User
    Toshiba External USB drives not showing in Explorer or Disk Management Plug-in
    Thank you for the update.
    Looks like your system is unable to detect your external hard drive. Let's see if scanning for new hardware will fix the issue. Follow these steps:
    • Press the Windows key to launch the Start menu.
    • Type in Device Manager and press Enter.
    • Under Device Manager, select Action tab > Scan for hardware changes.
    • Wait for your system to install the generic driver for your device and follow the on-screen instructions.
    If the issue still persists, we suggest that you perform the following recommendations below:
    • Plug in your external USB drives to other USB device port of your system.
    • Use other USB cables for your external device to connect to your system.
    Keep us updated and we will be glad to assist you further.
    Ferdz Amp, May 28, 2021
  4. Battery Management, USB Flash Drive Missing, USB Plugging Problems etc
    Files inside exFAT formatted USB flash drive are missing.
    Recently I bought a new 64GB USB flash drive from eBay. The files I saved inside the USB flash drive are missing once I plugged in to the PC. But the flash drive properties shows as the used space is almost 30GB. Is there any method to recover the missing
    files? I've almost tried plugging the flash drive in a MacBook and a PC running Windows 7. But can't get the data inside that.
    Mushthaq Mush, May 28, 2021
  1. Battery Management, USB Flash Drive Missing, USB Plugging Problems etc - Similar Threads - Battery Management USB
  2. problem with usb flash drives
    problem with usb flash drives: Hello, it's been since this morning that I've been experiencing this problem with my pc. After taking a USB stick from a friend to get some files, I started to notice a strange behavior from the pc. Every time I insert a USB stick, two things happen: first, the device window...
  3. problem with usb flash drives
  4. USB mouse stops working when USB flash drive is plugged in.
    USB mouse stops working when USB flash drive is plugged in.: Hello. I have a problem with my USB 3.0 ports on 2 of my PCs. Problem description: Windows 10 Pro, genuine, with latest updates, latest drivers original, not driverpack or other s*** and BIOS. System is on WD NVMe SSD on one PC and Samsung sata SSD on the other one....
  5. USB flash drives problem
    USB flash drives problem: Here's an odd one! I put a flash drive in the PC today and the files on it showed as info I know that's not on it. In fact, it contains Windows install files I made just the other day and then used it for a clean installation. Then I formatted the drive but it still showed...
  6. USB Flash Drive Problem... or ?
    USB Flash Drive Problem... or ?: I picked up a Hama brand 128Gb USB2 drive a couple of weeks ago from a reputable component supplier. The drive was retail packaged and I have no doubts over its authenticity. When used on my Dell i5 laptop running W10 insider builds I find the drive freezes when transferring...
  7. Annoying warning plugging in usb flash drive
    Annoying warning plugging in usb flash drive: When I Plug in a USB Flash Drive, I get This Annoying Message . Camera Upload. Keep Your Memories Safe. All your photos and videos will be automatically saved to dropbox. How can I get rid of or dissable this warning/message...
  8. USB Flash Drive Problem
    USB Flash Drive Problem: Hey guys, So, I have this 8 GB USB Flash Drive which is completely empty, no hidden files/folders, nothing. But it says that around 1 GB is used - Imgur: The most awesome images on the Internet Why is that? Can I free up that memory? Not that it's very important, but I...
  9. USB flash drive problem
    USB flash drive problem: I purchased a flash drive to use as ReadyBoost, and I had it set and know it was working. I removed and when I plugged it back in, went to Properties/ReadyBoost tab it shows the error message attached. The hub I an using is 2.0 so I don't know what this means. [img] 103195
  10. USB Flash Drive UEFI problem
    USB Flash Drive UEFI problem: Hello Tenforums.com No matter what I do, my Lenovo Flex 2-14 doesn't seem to recognise my USB as an UEFI Windows bootable flash device, despite following this guide https://www.tenforums.com/tutorials/2...dows-10-a.html (Option 2), step by step. I am using a Verbatim...
