Windows 10: Battery not charging only works in AC power even battery is zero
Discus and support Battery not charging only works in AC power even battery is zero in Windows 10 Gaming to solve the problem; My laptop is msi Bravo 15. I know about the msi dragon center's charging modes this is not about that. My laptops battery is not charging . It is... Discussion in 'Windows 10 Gaming' started by karthick SK, Jul 13, 2022.
Battery not charging only works in AC power even battery is zero - Similar Threads - Battery charging works
Huge Battery Problem Only running on AC power
in Windows 10 Drivers and HardwareHuge Battery Problem Only running on AC power: I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8. One day while I was doing this, the battery suddenly cut off and never worked again Keep in mind the battery is relatively... -
in Windows 10 GamingHuge Battery Problem Only running on AC power: I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8. One day while I was doing this, the battery suddenly cut off and never worked again Keep in mind the battery is relatively... -
in Windows 10 Software and AppsHuge Battery Problem Only running on AC power: I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8. One day while I was doing this, the battery suddenly cut off and never worked again Keep in mind the battery is relatively... -
battery only charging to 60%
in Windows 10 Gamingbattery only charging to 60%: battery om a ASUS X515 laptop https://answers.microsoft.com/en-us/windows/forum/all/battery-only-charging-to-60/d82eada7-e01c-4f4f-9a3a-def266f71e44 -
in Windows 10 Software and Appsbattery only charging to 60%: battery om a ASUS X515 laptop https://answers.microsoft.com/en-us/windows/forum/all/battery-only-charging-to-60/d82eada7-e01c-4f4f-9a3a-def266f71e44 -
in Windows 10 Software and AppsBattery not charging only works in AC power even battery is zero: My laptop is msi Bravo 15. I know about the msi dragon center's charging modes this is not about that. My laptops battery is not charging . It is initially at 44% when I know about this issue. When I connect the adaptor the laptop doesn't use the battery it automatically use... -
Dell Laptop Battery Not Charging or Working off of AC Adapter
in Windows 10 Ask InsiderDell Laptop Battery Not Charging or Working off of AC Adapter: I have recently replaced my Dell XPS L702X battery this Christmas. I stopped using the computer for about 3 weeks and the battery no longer works. Windows says it has 96 percent and not charging but if I unplug it the power cuts immanently. I followed the manufacture's... -
ac adapter warning message; battery will not charge
in Windows 10 Performance & Maintenanceac adapter warning message; battery will not charge: Need a fix for ac adapter warning as the battery will not charge. Says to use a 45 w adapter, but that's what I have. Any suggestions? https://answers.microsoft.com/en-us/windows/forum/all/ac-adapter-warning-message-battery-will-not-charge/7e3d3e2b-37bd-48a8-abcf-a70096d1c4c9 -
ac adapter for battery charger not charging
in Windows 10 Drivers and Hardwareac adapter for battery charger not charging: my dell insprion 5551 ac adapter isn't charging by battery and I have tried all the suggestions that dell provided and still nothing. my battery is at 10%. I not had a problem till I remember month or 2 ago I reset my pc but ac adapter didn't get notice till month ago. when I...
