Windows 10: Battery report at 153%, different from system battery indicator, battery drain to 0%,...
Discus and support Battery report at 153%, different from system battery indicator, battery drain to 0%,... in Windows 10 Ask Insider to solve the problem; I have the following issue: The laptop discharges during sleep down to 0%. This is below the 5% threshold at which it shuts down automatically when... Discussion in 'Windows 10 Ask Insider' started by /u/cascom96, Jan 23, 2021.
  1. Battery report at 153%, different from system battery indicator, battery drain to 0%,...
    I have the following issue: The laptop discharges during sleep down to 0%. This is below the 5% threshold at which it shuts down automatically when being used. In summary, the laptop drains much energy during sleep at night time.
    To understand this, the following was done: 1) powercfg -batteryreport and 2) the admin rights sleepstudy.
    1) batteryreport gives:
    DESIGN CAPACITY
    70,001 mWh
    FULL CHARGE CAPACITY
    63,489 mWh
    But, at a 99% charge (indicated by the battery icon in the taskbar), this report indicates more than 100% charge, thus an inconsistency between batteryreport and system battery icon:
    15:43:34
    Report generated
    Battery
    147 %
    62,527 mWh
    2) The second sleepstudy report "correctly" (that is, same as the system icon) specifies the following:
    15:17:57
    0:00:16
    Active
    Drain
    99%
    What could be the cause for this inconsistency? Could thes be causing an abnormal shutdown where my laptop thinks it is above 0%, but then drains the battery until the end? Still, this would not answer why it drains so much energy during sleep. However, the latter question could anyway not be solved following so many instructions.
    N.B.: Yes, updates all done, Bios latest version etc. ASUS Zenbook UX480FD, 2019 edition, new.
    submitted by /u/cascom96
    [link] [comments]
  2. Try3 Win User
    Battery report
    Gabriela,
    I have very precise records of when I swap over my batteries [because I run battery reports both before & after] and the moment of opening up the computer or changing the battery does not show up in my battery reports.
    - My Battery report section Usage history - History of system usage on AC and battery goes all the way back to when the computer maker finished setting the computer up [and then posted it to me]. Your corresponding records seem to show the same.
    - I know of no command to reset the parameters listed in a battery report.
    The Start time entry you circled in red shows the time that the computer was turned on or awakened on battery power. There is no indication of anything dishonest being done. Windows re-starts that list whenever it feels like it. There is nothing significant in that entry at all. Just for example, my Battery report Start time entries are only showing for today but the computer was in use yesterday and earlier on battery.
    Denis
  3. clayto Win User
    Battery apps and battery report lack data
    Below I have Copy / Pasted a report generated by the PC. As you can see (I hope) most of the expected battery data is simply not there. I have four Store apps monitoring the battery, two of which concentrate on displaying battery usage statistics in tables and graphs. But they also do not show the data. The battery is reported to have zero charge when in fact it has up to 100%. I have been frequently getting an annoying pop-up notification saying the battery has 0% charge and to 'connect the charger', when it is connected and charging. I have examined Settings and Tasks Library but have not found anything to explain this.
    It is important to me to be able to monitor the battery in my 2-in-1 tablet
    Battery report
    COMPUTER NAME DESKTOP-SI0QNOV
    SYSTEM PRODUCT NAME Cube I15-TC
    BIOS 5.11 05/07/2016
    OS BUILD 14393.321.amd64fre.rs1_release_inmarket.161004-2338
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-10-21 17:29:01
    Installed batteries
    Information about each currently installed battery
    BATTERY 1
    NAME Intel Battery
    MANUFACTURER Intel Corp
    SERIAL NUMBER 1122
    CHEMISTRY LION
    DESIGN CAPACITY -
    FULL CHARGE CAPACITY -
    CYCLE COUNT 23474
    Recent usage
    Power states over the last 7 days
    START TIME STATE SOURCE CAPACITY REMAINING
    2016-10-21 07:30:00 Active AC - -
    08:08:00 Suspended - -
    09:34:17 Active AC - -
    10:13:01 Active Battery - -
    10:13:36 Active AC - -
    11:08:44 Suspended - -
    14:22:13 Active AC - -
    14:23:55 Active Battery - -
    15:14:26 Active AC - -
    15:50:00 Suspended - -
    17:20:29 Active AC - -
    17:24:58 Active Battery - -
    17:27:00 Report generated Battery - -
    Battery usage
    Battery drains over the last 7 days
    START TIME STATE DURATION ENERGY DRAINED
    2016-10-21 10:13:01 Active 0:00:35 - -
    14:23:55 Active 0:50:31 - -
    17:24:58 Active 0:02:02 - -
    Usage history
    BATTERY DURATION AC DURATION
    PERIOD ACTIVE CONNECTED STANDBY ACTIVE CONNECTED STANDBY
    Battery capacity history
    Charge capacity history of the system's batteries
    PERIOD FULL CHARGE CAPACITY DESIGN CAPACITY
    Battery life estimates
    Battery life estimates based on observed drains
    AT FULL CHARGE AT DESIGN CAPACITY
    Current estimate of battery life based on all observed drains since OS install
    clayto, Jan 23, 2021
  4. 1Gabriela Win User
    Battery report
    Is this a normal check, or does it indicate a system change?
    Battery report at 153%, different from system battery indicator, battery drain to 0%,... [​IMG]
    1Gabriela, Jan 23, 2021
  1. Battery report at 153%, different from system battery indicator, battery drain to 0%,... - Similar Threads - Battery report 153%
  2. My battery drain to 0 in bootup
    My battery drain to 0 in bootup: Hi so ih have had my msi gf76 Ue laptop for a year and half i had this problem for a while when i charg my laptop and un plug it while it is on the battery drains normally while if i shut it down not connected to the charger and boot it up it goes to 0% i have tried updation...
  3. My battery drain to 0 in bootup
  4. Battery levels stuck at 0% in power & battery report
    Battery levels stuck at 0% in power & battery report: Hi,I just got a new laptop. In fact it's the second one this week, because the previous one had to be replaced as it came faulty. On both of them I noticed that the battery report in power & battery shows 0% at all times and no apps being used. How do I fix this? Is this...
  5. Battery levels stuck at 0% in power & battery report
  6. Battery is Draining
    Battery is Draining: Yesterday, when I opened it up, it seemed to drain all its battery.It would also charge in a matter of minutes.The day before that, the battery was fine.Now, the battery can lose 1% in a few seconds. It also shuts down at 30%.This morning, the battery would jump from 100% to...
  7. Battery report above 100%, inaccurate, abnormal shutdown, battery drain to 0%
    Battery report above 100%, inaccurate, abnormal shutdown, battery drain to 0%: I have the following issue: The laptop discharges during sleep down to 0%. This is below the 5% threshold at which it shuts down automatically when being used. In summary, the laptop drains much energy during sleep at night time. To understand this, the following was done:...
  8. Battery drains
    Battery drains: My Asus laptop has a problem where randomly the battery will fall from around 20% dramtically leaving me about 15 seconds each time before it reaches 0%, I thought this was a battery issue but upon buying a new battery I realised it must be a software issue as the issue...
  9. Battery draining abruptly at 40% to 0%
    Battery draining abruptly at 40% to 0%: I have an HP x-360 Pavilion laptop. I updated to the latest Windows 10 2004 version about a month ago. It was working fine. However, since the last week or so, the battery abruptly drains from around 40-50% straight to 0% when working without the AC power connected. I'm not...
  10. Battery Draining Quickly - Ran Battery Health Report
    Battery Draining Quickly - Ran Battery Health Report: In the past 1 - 1.5 weeks I have noticed that my battery is draining much quicker than it used to. I have a Dell XPS 13 that I bought new in July 2018. My battery, up until a week or so ago, was lasting anywhere from 5-8 hours depending on how much I used it throughout the...
