Windows 10: Blank wired Connection entry Crashes settings when clicked on.
Discus and support Blank wired Connection entry Crashes settings when clicked on. in Windows 10 Network and Sharing to solve the problem; In my settings, under Settings>Network and Internet>Ethernet there are two entries under ethernet:1. blank No internet2. Ethernet Not connectedBesides... Discussion in 'Windows 10 Network and Sharing' started by HarrisonMa1, Jan 17, 2022.
Blank wired Connection entry Crashes settings when clicked on. - Similar Threads - Blank wired Connection
in Windows 10 GamingBlank wired Connection entry Crashes settings when clicked on.: In my settings, under Settings>Network and Internet>Ethernet there are two entries under ethernet:1. blank No internet2. Ethernet Not connectedBesides the fact that this list does not reflect the actual list of ethernet adapters I have, when I click on the blank entry... -
in Windows 10 Software and AppsBlank wired Connection entry Crashes settings when clicked on.: In my settings, under Settings>Network and Internet>Ethernet there are two entries under ethernet:1. blank No internet2. Ethernet Not connectedBesides the fact that this list does not reflect the actual list of ethernet adapters I have, when I click on the blank entry... -
Blank Taskbar Entry
in Windows 10 SupportBlank Taskbar Entry: [img] So, as you can see, near the bottom right, there is a blank taskbar entry. The popup menu does little to clarify (pin to taskbar and close all windows, neither of which does anything as far as I can see). The blank is between the Paint.net icon and the Steam Icon and... -
Double entry and clicking
in Windows 10 CustomizationDouble entry and clicking: my cat walked across my keyboard and now when I type, each entry is noted with an audible "click" and I am also not able to type double keys , i.e. can not type "letter" without typing "letspace" then backspace to delete the space then finish with"ter". I cannot backspace... -
When I click on System in the Settings app, it crashes.
in Windows 10 CustomizationWhen I click on System in the Settings app, it crashes.: So, I guess the last cumulative Windows 10 update broke the Settings app. I just debloated my system without breaking things. Last time I upgraded to Windows 10 2004 from 1903, and I've never had the problem with 1903. Last cumulative update probably broke the System tab in... -
Sticky Notes Crashes When Clicking on the Settings Button
in Windows 10 BSOD Crashes and DebuggingSticky Notes Crashes When Clicking on the Settings Button: Just opened Sticky Notes and signed in with my MS account. When I click on the "Settings" button, the program crashes. Why is it doing this and is there a solution?... -
Settings app crashes when clicking on Apps section
in Windows 10 CustomizationSettings app crashes when clicking on Apps section: My desktop PC has been updated from Windows 10 1809 to 1903 recently. In the latest build 18362.116, Settings app crashes when I click on Apps section. The workaround I have found is to open File Explorer, right-click on C drive and go to Properties. Then, click on Disk... -
Settings app crashes when clicking on the About option!
in Windows 10 CustomizationSettings app crashes when clicking on the About option!: When I tried to go to this direction, Settings>System>About, the settings app crashes once I click on the "About"' option ![ATTACH]... -
Settings crash when clicking on Update & Security
in Windows 10 SupportSettings crash when clicking on Update & Security: Earlier I went into Settings and clicked on Update & Security, and I found Windows Problem Reporting running in the background. I checked the Reliability Monitor (because for some reason problem reports aren't saving on my computer) and found this: Faulting application name:...
