Windows 10: Bluetooth dongle question for a low bluetooth level
Discus and support Bluetooth dongle question for a low bluetooth level in Windows 10 Software and Apps to solve the problem; Hi, i have an old laptop that has LMP 4 bluetooth that being bluetooth 2.1 and i want to connect some 5.1 bluetooth headset. Should i get a bluetooth... Discussion in 'Windows 10 Software and Apps' started by Alex.0, Dec 14, 2024.
  1. Alex.0 Win User
    Hi, i have an old laptop that has LMP 4 bluetooth that being bluetooth 2.1 and i want to connect some 5.1 bluetooth headset. Should i get a bluetooth dongle for this problem? Will that solve anything? and if it can do anything, will it work if i already have a bluetooth inserted in it.
  2. Bluetooth USB Dongle
    Ok so here's a question. I had a revelation today that: "Duh, my keyboard/mouse is bluetooth, shouldn't that be the same thing?" My goal here is to get my new Motorola HT820 bluetooth headphones to work with on my computer.
    Keyboard/Mouse is Logitech MX5500 Revolution, bluetooth wireless, came with a USB dongle that they connect through. I tried today to get the headset to work, and it won't receive sound. I can get it "connected," but with complications. I'm using Windows XP, have Setpoint 4.7, and I've tried the following:
    -Changed the radio settings to a bluetooth hub instead of locked to the keyboard/mouse.
    -Clicked "Connect Other Devices."
    - Paired headphones with windows. Windows connects correctly, the device reads connections, windows shows it as "already connected" when I try to connect it again. I click on Control Panel -> Bluetooth Devices, and I see the "Motorola HT820" listed as "Passkey enabled," but it doesn't say "Connected" like the keyboard and mouse do. Also, audio does play on the headphones.
    -Click on Properties on HT820, and then on services, it does not show any services at all.
    - Searched around google, logitech, motorola websites & forums to answers or help, nothing. Closet I got was logitech's "Bluetooth FAQ" which has the following paragraph (http://www.logitech.com/lang/pdf/bluetooth/bluetooth-faq.pdf):
    "3.6 How do I listen to music wirelessly with a Bluetooth headphone?
    All you need is a Bluetooth headphone and a media player such as iTunes or Windows Media Player 10. For optimal results, it is recommended you use a headphone with Bluetooth 2.0 Enhanced Data Rate, to benefit from the maximum bandwidth (up to 3Mb/s).
    Please refer to our online "How To" documents for step-by-step instructions related to your specific device (www.logitech.com/bluetooth/howto)." [That link transfers you back to the same pdf document - it's a circle]
    -I tried to install latest Widcomm stack from broadcomm's website, but it says it's not compatible with this dongle.
    -Called Logitech Tech Support - got a total jerk girl who straight up said "No i can't help you." And then wouldn't give me the time of day after that.
    I've read on threads on Logitech forum that people are using this headset with logitech dongles. Any help getting this connected? I just don't want to have 2 bluetooth dongles connected when I rly only should need this one. Otherwise I guess I'll just purchase one of the ones above, and use that to connect my keyboard, mouse, and headphones all in one swoop.
    Sidenote: anyone have experience/knowledge with behavior when 2 bluetooth USB dongles are connected to the same computer?
    surfsk8snow.jah, Dec 14, 2024
  3. Zaspera Win User
    Bluetooth dongle problem!
    My problem was (got a new laptop w/ built in bluetooth) that the actual bluetooth did not connect with the PC. I didn't have audio playback problems because the bluetooth wasn't even connected to the PC. Someone on another forum said that he had a similar problem and it was due to the wireless mouse drivers he used. I also used a wireless mouse with a little receiver dongle.
    Zaspera, Dec 14, 2024
  4. aasim1111 Win User
    Bluetooth in windows 10
    My computer specs are as listed in the profile. I think all of you guys are correct. I don't have built-in Bluetooth in mobo.
    I contacted skull candy headphones and thy have told me if I do not have built-in Bluetooth, I would need a dongle which supports at least a2dp. I do not know what the heck that means. I have a feeling I would need more than a cheap dongle.
    Anyone suggest some a2dp adapters. I searched but don't know what a2dp is so couldn't make a decision
    aasim1111, Dec 14, 2024
  1. Bluetooth dongle question for a low bluetooth level - Similar Threads - Bluetooth dongle question
  2. Bluetooth dongle question for a low bluetooth level
    Bluetooth dongle question for a low bluetooth level: Hi, i have an old laptop that has LMP 4 bluetooth that being bluetooth 2.1 and i want to connect some 5.1 bluetooth headset. Should i get a bluetooth dongle for this problem? Will that solve anything? and if it can do anything, will it work if i already have a bluetooth...
  3. Bluetooth dongle question for a low bluetooth level
  4. Convert keyboard bluetooth dongle to universal bluetooth dongle
    Convert keyboard bluetooth dongle to universal bluetooth dongle: hi I use to use a bluetooth keyboard, and now switched to wired I was wondering if there is any way to convert my old keyboard's dongle to a universal bluetooth dongle. Keyboard Details: HP ERGO...
  5. Bluetooth dongle
    Bluetooth dongle: I recently bought a bluetooth dongle for my pc. I plugged it in and installed it and restarted my pc to finish it. came back and it says "driver is unavailable" i clicked update and it says theres no updates for it. where do i get the correct driver for this since my windows...
  6. Bluetooth Dongle
    Bluetooth Dongle: I recently bought the Bluetooth dongle listed below. I've plugged it into my pc and it seems to work alright but I can only pair to devices by right-clicking the Bluetooth symbol on the taskbar. When I go into windows settings there isn't even an option to turn Bluetooth on,...
  7. Bluetooth Dongle
    Bluetooth Dongle: I have a Bluetooth USB Adaptor ES-3881+ I have the software disc but when I run it an error message comes up "Err 2 occurred during installation please try to install again" I have tried several times. is there a fix or do I need to buy a new dongle. Thanks in advance...
  8. Bluetooth dongle and window built in bluetooth
    Bluetooth dongle and window built in bluetooth: Can you use both the internal bluetooth and an external bluetooth dongle? https://answers.microsoft.com/en-us/windows/forum/all/bluetooth-dongle-and-window-built-in-bluetooth/d77c5d45-39f8-4997-b031-bebe2dd4b031
  9. Bluetooth dongle
    Bluetooth dongle: I recently bought a Bluetooth adaptor but it doesn't work, I've tried deleting the drivers and reinstalling them but it still doesn't work submitted by /u/Girl_Widda_D [link] [comments] https://www.reddit.com/r/Windows10/comments/ha8jlz/bluetooth_dongle/
  10. Bluetooth Dongle
    Bluetooth Dongle: My windows 10 pc does not have Bluetooth. Please recommend some quality Bluetooth dongle. Many thanks. submitted by /u/NorhoNor [link] [comments] https://www.reddit.com/r/Windows10/comments/ewye1p/bluetooth_dongle/
