Windows 10: Booting problem turned in to BSOD problem
Discus and support Booting problem turned in to BSOD problem in Windows 10 BSOD Crashes and Debugging to solve the problem; Now I have a problem with Windows 10 booting that I believe that i made it only worse and seriously i need quick help as it turned in to a BSOD... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Zeinobia, Jun 27, 2017.
Page 1 of 3
Page 1 of 3
Booting problem turned in to BSOD problem - Similar Threads - Booting problem turned
Intermittent BSOD turning into larger problem
in Windows 10 BSOD Crashes and DebuggingIntermittent BSOD turning into larger problem: I have had the random BSOD for a while now but it always happened whenever I wasn't gaming my primary activity on this machine so it was never something i wanted to address. Eventually the errors got more frequent and occasionally happened during games. The codes were... -
in Windows 10 GamingIntermittent BSOD turning into larger problem: I have had the random BSOD for a while now but it always happened whenever I wasn't gaming my primary activity on this machine so it was never something i wanted to address. Eventually the errors got more frequent and occasionally happened during games. The codes were... -
in Windows 10 Software and AppsIntermittent BSOD turning into larger problem: I have had the random BSOD for a while now but it always happened whenever I wasn't gaming my primary activity on this machine so it was never something i wanted to address. Eventually the errors got more frequent and occasionally happened during games. The codes were... -
problem turning on
in Windows 10 Performance & Maintenanceproblem turning on: After a period of time of being turned off i cant turn on my computer. i try to turn it on but it wont turn on immediately. when i press the power button nothing happens nor the light, after pressing the button for an half of hour or spamming the power button it will turn on.... -
BSOD problems to boot.
in Windows 10 BSOD Crashes and DebuggingBSOD problems to boot.: Hello everyone!:I'm having trouble booting Windows 20H2 (x64). It never starts the first time. I reset the BIOS several times, loaded the optimized values (AMI BIOS UEFI by Gigabyte) and even a memory test that did not find any fault (Kingston Hyper Fury 2666 Mhz 4 x 8). I... -
Boot problem with BSOD
in Windows 10 BSOD Crashes and DebuggingBoot problem with BSOD: Hey everyone, I got very intresting problem with my pc. I got some problems with bsod but i realized that because of proccesor temp. I solved with new thermal paste. After one or two weeks i got some boot problem. When i try the open my laptop with power button rotating dots... -
Random BSOD And problems booting
in Windows 10 BSOD Crashes and DebuggingRandom BSOD And problems booting: My PC crahes and BSOD at randowm times, no pattern to it really. I also sometimes have problems booting the pc, it just hangs on a black screen and will only eventually boot if i turn it off and back on. Attatched the crash file 12738 -
Bsod boot problem
in Windows 10 BSOD Crashes and DebuggingBsod boot problem: Went to restart my computer and when I did and rebooted it it went to a loading screen with the circle balls going around. It then goes to another loading the same thing. Then it goes to a black screen where I can move the mouse. I tried using the space and ctrl tricks to... -
Sudden Booting Problem after BSOD?
in Windows 10 SupportSudden Booting Problem after BSOD?: Hello, I had my laptop open (Dell XPS 9550) and wasn't using it. I noticed the screen changed so I looked over and it had a BSOD. Since that happened, I've been unable to boot it up. I've tried running chkdsk /f c:, but it now says "The type of the file system is RAW....
