Windows 10: BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug
Discus and support BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug in Windows 10 Drivers and Hardware to solve the problem; Dear Community,When I send my Dell 5480 to sleep in battery mode, I reliably get a BSOD with an identical error code PNP_DETECTED_FATAL_ERROR. The... Discussion in 'Windows 10 Drivers and Hardware' started by TOM-SPIKE, Dec 19, 2021.
  1. TOM-SPIKE Win User
    Dear Community,When I send my Dell 5480 to sleep in battery mode, I reliably get a BSOD with an identical error code PNP_DETECTED_FATAL_ERROR. The error does not occur when on power plug.The system is freshly set up 1 week old. New elements are: 32GB RAM instead of 8, NVMe SSD 512 instead of S-ATA SSD 256.No external devices are connected.The problem does not occur in safe mode. The hibernation mode can also be called up in battery mode without any problems.The device manager shows some warning messages only in safe mode. In standard mode everything seems free of errors / warnings.Accor
  2. Battery drain in hibernation
    This is a volunteers forum. We cannot fix anything for you!
    I would start by taking these steps:
    1. Put Windows into hibernation.
    2. Get it out of hibernation.
    3. Check the time stamp of the hidden file C:\Hiberfil.sys. Does it reflect the time when you took Step 1 above? If it does not then the machine was not in hibernation.
    4. Before going to bed, make a note of the battery charge.
    5. Switch the machine off and unplug the power cord.
    6. Next morning, before plugging in the power cord but after turning it on, make another note of the battery charge. If there is a noticeable discharge then you have a leaky battery or a problem with the motherboard. Windows can't be the culprit because it
      was off all night.
    Frederik Long, Dec 19, 2021
  3. Laptop no longer hibernates on critical power
    Hi Mike,
    The laptop's battery is possibly wearing out. Since you haven't change any settings, we suggest that you change the critical battery level a bit higher so that your laptop can perform a hibernation on a much higher percentage than the default. Follow the
    steps below:
    • Type Power Options on the Start menu search bar.
    • Under Battery, click on Critical battery level.
    • Chang the default percentage to 10% or higher.
    • Click on Apply.
    Radney Dri, Dec 19, 2021
  4. BBL70 Win User
    iaStorAC.sys BSOD on battery power
    Hi
    My laptop (Dell Inspiron approx 6 yo) will no longer function on battery power alone. As soon as I pull the main power I get a BSOD and the iaStorAC.sys error.
    I've replaced the battery and this makes no difference.
    Can any one offer (preferably step-by-step) help?
    BBL70, Dec 19, 2021
  1. BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug - Similar Threads - BSOD PNP_DETECTED_FATAL_ERROR hibernate
  2. Power & battery problems
    Power & battery problems: In the Screen, sleep, & hibernate timeouts section, I can only adjust Turn my screen off after and Make my device sleep after and there is no Hibernate after section. And the funny thing is, it seems that the device still Hibernates after sleeping normally, why does the...
  3. Power & battery problems
  4. Power and battery Problem.
    Power and battery Problem.: I have a problem in my power and battery section of settings. Whenever I want to check battery usage of last 7 days then no result appears and the settings app gets automatically close. So what is the problem in settings app....
  5. Power and battery Problem.
  6. BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug
    BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug: Dear Community,When I send my Dell 5480 to sleep in battery mode, I reliably get a BSOD with an identical error code PNP_DETECTED_FATAL_ERROR. The error does not occur when on power plug.The system is freshly set up 1 week old. New elements are: 32GB RAM instead of 8, NVMe...
  7. BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug
  8. Power Switch, hibernate problem
    Power Switch, hibernate problem: Microsoft Support 111221 Power Switch, hibernate problem Dear Microsoft Support, I upgraded from Win 7 to Win 10 for my Netbook, and have some unusual problems with my Power Switch, and hibernate/sleep. I tried going thru shut down and start up several times, and documenting...
  9. Power mode plugged in and on battery?
    Power mode plugged in and on battery?: Which power mode do you guys use when a. your laptop is plugged in, b. when it's on battery? I usually use better performance when plugged in, because I suspect that best performance will lead to heat and to wear out the hardware faster. Am I right on that suspicion? Thanks...
  10. Power Management Battery/Plugged In
    Power Management Battery/Plugged In: Hi all, Just a quickie... does anyone know if its possible to set High Performance mode automatically when plugged in and then change this automatically to Balanced when unplugged? I seemed to think this was possible? 132404
