Windows 10: BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug
Discus and support BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug in Windows 10 Gaming to solve the problem; Dear Community,When I send my Dell 5480 to sleep in battery mode, I reliably get a BSOD with an identical error code PNP_DETECTED_FATAL_ERROR. The... Discussion in 'Windows 10 Gaming' started by TOM-SPIKE, Dec 19, 2021.
BSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug - Similar Threads - BSOD PNP_DETECTED_FATAL_ERROR hibernate
Power & battery problems
in Windows 10 GamingPower & battery problems: In the Screen, sleep, & hibernate timeouts section, I can only adjust Turn my screen off after and Make my device sleep after and there is no Hibernate after section. And the funny thing is, it seems that the device still Hibernates after sleeping normally, why does the... -
in Windows 10 Software and AppsPower & battery problems: In the Screen, sleep, & hibernate timeouts section, I can only adjust Turn my screen off after and Make my device sleep after and there is no Hibernate after section. And the funny thing is, it seems that the device still Hibernates after sleeping normally, why does the... -
Power and battery Problem.
in Windows 10 GamingPower and battery Problem.: I have a problem in my power and battery section of settings. Whenever I want to check battery usage of last 7 days then no result appears and the settings app gets automatically close. So what is the problem in settings app.... -
in Windows 10 Software and AppsPower and battery Problem.: I have a problem in my power and battery section of settings. Whenever I want to check battery usage of last 7 days then no result appears and the settings app gets automatically close. So what is the problem in settings app.... -
in Windows 10 Software and AppsBSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug: Dear Community,When I send my Dell 5480 to sleep in battery mode, I reliably get a BSOD with an identical error code PNP_DETECTED_FATAL_ERROR. The error does not occur when on power plug.The system is freshly set up 1 week old. New elements are: 32GB RAM instead of 8, NVMe... -
in Windows 10 Drivers and HardwareBSOD PNP_DETECTED_FATAL_ERROR on hibernate Battery Power only, no problems on power plug: Dear Community,When I send my Dell 5480 to sleep in battery mode, I reliably get a BSOD with an identical error code PNP_DETECTED_FATAL_ERROR. The error does not occur when on power plug.The system is freshly set up 1 week old. New elements are: 32GB RAM instead of 8, NVMe... -
Power Switch, hibernate problem
in Windows 10 GamingPower Switch, hibernate problem: Microsoft Support 111221 Power Switch, hibernate problem Dear Microsoft Support, I upgraded from Win 7 to Win 10 for my Netbook, and have some unusual problems with my Power Switch, and hibernate/sleep. I tried going thru shut down and start up several times, and documenting... -
Power mode plugged in and on battery?
in Windows 10 Ask InsiderPower mode plugged in and on battery?: Which power mode do you guys use when a. your laptop is plugged in, b. when it's on battery? I usually use better performance when plugged in, because I suspect that best performance will lead to heat and to wear out the hardware faster. Am I right on that suspicion? Thanks... -
Power Management Battery/Plugged In
in Windows 10 SupportPower Management Battery/Plugged In: Hi all, Just a quickie... does anyone know if its possible to set High Performance mode automatically when plugged in and then change this automatically to Balanced when unplugged? I seemed to think this was possible? 132404
