Windows 10: Can I get help with Kernel-Power 41 70368744177664,2 ?
Discus and support Can I get help with Kernel-Power 41 70368744177664,2 ? in Windows 10 Gaming to solve the problem; I need assistance identifying the issue. I have tried everything regarding driver/bios/chipset updates and repairing windows 11. The crashes are... Discussion in 'Windows 10 Gaming' started by KeenonD, Nov 28, 2023.
Can I get help with Kernel-Power 41 70368744177664,2 ? - Similar Threads - help Kernel Power
Kernel-Power 70368744177664, 2 Event ID 41 Task Category 63
in Windows 10 GamingKernel-Power 70368744177664, 2 Event ID 41 Task Category 63: Hi, My computer started crashing from a BSOD with the violation code: DPC_WATCHDOG_VIOLATION I did some google searches and ended up here The first crash I had 3~ days ago, I unplugged and plugged in my Wacom tablet and it crashed shortly after The latest crash came after I... -
in Windows 10 Software and AppsKernel-Power 70368744177664, 2 Event ID 41 Task Category 63: Hi, My computer started crashing from a BSOD with the violation code: DPC_WATCHDOG_VIOLATION I did some google searches and ended up here The first crash I had 3~ days ago, I unplugged and plugged in my Wacom tablet and it crashed shortly after The latest crash came after I... -
in Windows 10 GamingKernel-Power 70368744177664, 2 Event ID 41 Task Category 63: Hi,My pc has been shutting down randomly, lately. I will paste in the even viewer properties below. It is a new gaming pc running on asus rog maxsimus z790 hero motherboard with 13th gen intel i9 13900k processor. i already had several shud down, while rendering in 3ds max... -
in Windows 10 Software and AppsKernel-Power 70368744177664, 2 Event ID 41 Task Category 63: Hi,My pc has been shutting down randomly, lately. I will paste in the even viewer properties below. It is a new gaming pc running on asus rog maxsimus z790 hero motherboard with 13th gen intel i9 13900k processor. i already had several shud down, while rendering in 3ds max... -
70368744177664, 2. Event ID 41 Kernel Power
in Windows 10 Gaming70368744177664, 2. Event ID 41 Kernel Power: My PC will randomly shut down, freeze, or blue screen and subsequently crash from one of those failures. There are times when the system can be used for long periods, but any strain on the system, i.e., running an in-depth anti-virus scan or some gaming program, can also... -
in Windows 10 Software and Apps70368744177664, 2. Event ID 41 Kernel Power: My PC will randomly shut down, freeze, or blue screen and subsequently crash from one of those failures. There are times when the system can be used for long periods, but any strain on the system, i.e., running an in-depth anti-virus scan or some gaming program, can also... -
in Windows 10 GamingKernel-Power 70368744177664, 2 Event ID 41 Task Category 63: Hi,My pc has been shutting down randomly, lately. I will paste in the even viewer properties below. It is a new gaming pc running on asus z790 a prime motherboard with amd 7900xt. For four days it was fine until today it randomly shut down. I'm on windows 11 pro. I have added... -
in Windows 10 Software and AppsKernel-Power 70368744177664, 2 Event ID 41 Task Category 63: Hi,My pc has been shutting down randomly, lately. I will paste in the even viewer properties below. It is a new gaming pc running on asus z790 a prime motherboard with amd 7900xt. For four days it was fine until today it randomly shut down. I'm on windows 11 pro. I have added... -
Kernel-Power (70368744177664),(2)
in Windows 10 Performance & MaintenanceKernel-Power (70368744177664),(2): Good Day, My computer is rebooting randomly. I have searched the web for solutions, but I have failed to fix the problem. Please help. I uploaded my system logs: https://1drv.ms/u/s!AgOA5CRz9rwKjECnWWKaeKUudd8a Below is the error message for the power failure:...
