Windows 10: can low temeperatures cause kernell power 41 error?
Discus and support can low temeperatures cause kernell power 41 error? in Windows 10 Gaming to solve the problem; a week ago when starting my laptop it shut down a short time after, i hand to start it 2-3 times to finally use it, i've had this happen beforenot this... Discussion in 'Windows 10 Gaming' started by AngelHernandez Estrada, Nov 6, 2024.
  1. can low temeperatures cause kernell power 41 error?
    a week ago when starting my laptop it shut down a short time after, i hand to start it 2-3 times to finally use it, i've had this happen beforenot this frequent, those times it only happened once so i dont think its a power/battery issue, i'm suspicious of the weather since this began only now that temperatures dropped in my city like a week or two ago, also during the day my laptop works as usual, can't recall the temp the previous week, but todaythe error happened again the lowest was 5 degrees Celsius
  2. Kernel-Power event id 41. BugcheckCode 0
    In-order to get more clarity on this issue and to assist you with appropriate troubleshooting steps, reply with answers to the below questions:
    1. Are you aware of any changes made on your PC, prior to this issue?
    2. Is this issue specific while playing a particular game?
    3. Which edition of Windows are you currently using?
    A Kernel Power Event 41 can occur in the following scenarios.
    Scenario 1: The computer restarts, and there is a Stop error BugcheckCode in the event data.
    Scenario 2: The computer is shut down by pressing and holding the power button.
    Scenario 3: The system randomly restarts and no Stop error BugcheckCode is listed, or the computer is completely unresponsive (hard hang).
    I suggest you refer the article on Kernel
    Power Event ID 41
    and follow the steps for the scenario that is causing this error on your PC.
    Additionally, you can refer the article on Windows
    Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows
    and check if that helps.
    Sandeep Kumar M
    Sandeep_KM, Nov 6, 2024
  3. tigger Win User
    Kernel Power 41 error
    I found something to do with sound drivers, the guy solved the error. Don't know if it helps but it might give you a clue.
    [SOLVED] Kernel-Power 41 (63) error
    tigger, Nov 6, 2024
  4. 95Viper Win User
    Windows Kernel event ID 41 error is generated when the system does not shutdown properly.
    More info on this, here>Windows Kernel event ID 41 error in Windows 7 or in Windows Server 2008 R2: “The system has rebooted without cleanly shutting down first”
    Quote from page at MS:
    This error can be caused by various problems:
    Drivers - Audio, Video, etc.
    Hardware
    even a windows update
    There have been some fixes to address some issues:
    An update rollup package for the Hyper-V role in Windows Server 2008 R2: August 24, 2010
    Stop error message on a Windows Vista or Windows Server 2008-based computer that has multiple processors installed: "STOP: 0x00000101 CLOCK_WATCHDOG_TIMEOUT"
    Stop error message on a Windows Server 2008 R2-based computer that has the Hyper-V role installed and that uses one or more Intel CPUs that are code-named Nehalem: "0x00000101 - CLOCK_WATCHDOG_TIMEOUT"
    However, without more info, it would be just a guess at the cause or causes.
    *Smile can low temeperatures cause kernell power 41 error? :)
    95Viper, Nov 6, 2024
  1. can low temeperatures cause kernell power 41 error? - Similar Threads - low temeperatures cause
  2. can low temeperatures cause kernell power 41 error?
    can low temeperatures cause kernell power 41 error?: a week ago when starting my laptop it shut down a short time after, i hand to start it 2-3 times to finally use it, i've had this happen beforenot this frequent, those times it only happened once so i dont think its a power/battery issue, i'm suspicious of the weather since...
  3. Kernel Power Error 41
    Kernel Power Error 41: Link to the file here:Please shed some light I am really out of options.- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">- <System> <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" /> <EventID>41</EventID>...
  4. Kernel-Power 41 Error
    Kernel-Power 41 Error: When i first had this pc i had no problems with it i eventually restarted my windows tought that was the cause of this but it happened again any help ?-Provider[ Name]Microsoft-Windows-Kernel-Power[...
  5. Kernel Power Error 41
    Kernel Power Error 41: Good day.I am in need of some assistance.My system keeps on getting BSOD and for the last while now, out of the blue.Error details:Log Name: SystemSource: Microsoft-Windows-Kernel-Power Date: 2024/02/10 10:28:40 Event ID: 41 Task Category: 63 Level: Critical Keywords:...
  6. Kernel Power Error 41
  7. Kernel Power Error 41
    Kernel Power Error 41: For the last few months my PC has been having problems staying on. It will randomly shut down while I'm using my pc. I would like to know if there is something I can do to fix it before I just buy a new PSU. It all started when I updated to windows 11. After resetting my PC 4...
  8. error 41 kernel power
    error 41 kernel power: connected a sound bar via hdmi to usb converter. connected via usb to pc because the hdmi port wasnt working and i got this error https://imgur.com/a/hHTojZB . the hdmi port on the board doesnt seem to work is there something i need to do to make it work for the sound bar?...
  9. kernel error power 41
    kernel error power 41: https://1drv.ms/u/s!AkyPAJT0rdLygZdBz-5GqTX-t_GjuQ?e=CLCmCY get this while doing randomd things , i chected the psu single rail 12v psu is fine hdds are fine, bios is fine, please help ironiclly while getting the errors code this errored again , same issue just a crash...
  10. Kernel power error 41
    Kernel power error 41: Hi! *Smile I have a problem. After upgrading from windows 8.1 to 10, when laptop goes to sleep mode, it won't turn on anymore. If I disable driver signature enforcement it starts normally. What could be wrong? Error file is in attachment. Thank's in advance! 37134
