Windows 10: Charger LEd is not working and battery is not charging
Discus and support Charger LEd is not working and battery is not charging in Windows 10 Software and Apps to solve the problem; i got a new Surface Laptop 7th edition, and all was working finesuddenly the chager LED light stopped and sure the battery doesn't charge anymorewhen i... Discussion in 'Windows 10 Software and Apps' started by hassan oliek, Mar 25, 2025.
  1. Charger LEd is not working and battery is not charging
    i got a new Surface Laptop 7th edition, and all was working finesuddenly the chager LED light stopped and sure the battery doesn't charge anymorewhen i plug in the charger, it light for few seconds then Off... however some times it work perfectly, but very few timei try to charge by USB C port, it is working fine, but i noticed that the Laptop is Hot beside the USB port and beside the Power Button. Can you please help to check and solve this problem, the Laptop is still new and under warranty.
  2. Plugged in but battery does not charge
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Mar 25, 2025
  3. baskhara Win User
    Acer battery won't charge
    What if the battery unremoveable? Should I disassemble and remove it? also there is a switch underneath the case and around the RAM slot that prevent the laptop to turn on when the case is open and without the charger. Is that the same as removing the battery? although when turned on with charger, the laptop still see the battery. Thanks
    - - - Updated - - -
    I took the report, the design capacity was 41.440 mWh but full charge capacity is now 25.752 mWh. Is it that bad? Before this happened I believe HWMonitor also show the same number with 38% Wear Level.
    Here's the report file
    baskhara, Mar 25, 2025
  4. Charger LEd is not working and battery is not charging
    Battery Won't Charge Fully
    Step 1
    Step 2
    Step 3
  1. Charger LEd is not working and battery is not charging - Similar Threads - Charger LEd working
  2. Charger LEd is not working and battery is not charging
    Charger LEd is not working and battery is not charging: i got a new Surface Laptop 7th edition, and all was working finesuddenly the chager LED light stopped and sure the battery doesn't charge anymorewhen i plug in the charger, it light for few seconds then Off... however some times it work perfectly, but very few timei try to...
  3. My battery charger is showing plugged in but battery is not charging. Why?
    My battery charger is showing plugged in but battery is not charging. Why?: My charger is plugged in but the battery is not charging https://answers.microsoft.com/en-us/windows/forum/all/my-battery-charger-is-showing-plugged-in-but/8b984ed2-f3b9-47b2-b39f-cac7215f4aaf
  4. My battery charger is showing plugged in but battery is not charging. Why?
  5. My battery charger is showing plugged in but battery is not charging. Why?
  6. Battery charger
    Battery charger: I replaced the battery in my Dell Inspiron laptop about 2-3 months ago. It is now indicating charger disabled. How do I enable it? https://answers.microsoft.com/en-us/windows/forum/all/battery-charger/0b0dcf15-26ce-45ed-9064-3fdd5a3b6d56
  7. Battery charger
  8. Battery fully charged but orange LED is blinking
    Battery fully charged but orange LED is blinking: My Dell M4800 battery fully charged but the orange LED is blinking. https://answers.microsoft.com/en-us/windows/forum/all/battery-fully-charged-but-orange-led-is-blinking/94ba2e16-74e1-4088-a47b-590a7a2f6720
  9. ac adapter for battery charger not charging
    ac adapter for battery charger not charging: my dell insprion 5551 ac adapter isn't charging by battery and I have tried all the suggestions that dell provided and still nothing. my battery is at 10%. I not had a problem till I remember month or 2 ago I reset my pc but ac adapter didn't get notice till month ago. when I...
  10. Battery charger
    Battery charger: I recently bought a replacement charger for my PC. When I plug it in it starts charging for about 30 seconds then it stops charging. https://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/battery-charger/fc128b5e-bc9f-4b8d-90e1-b5dec2bc158f
