Windows 10: Diff between Hyper-V Home and Pro guest logins using PIN?
Discus and support Diff between Hyper-V Home and Pro guest logins using PIN? in Windows 10 Virtualization to solve the problem; Although both Windows 10 Home and Pro support use of a PIN for login on devices, that does not appear to be the case when using Hyper-V virtual... Discussion in 'Windows 10 Virtualization' started by Cbarnhorst, Apr 19, 2017.
Diff between Hyper-V Home and Pro guest logins using PIN? - Similar Threads - Diff between Hyper
Credential Guard ON but not working in Hyper V guest.
in Windows 10 GamingCredential Guard ON but not working in Hyper V guest.: I am running a Windows Server 2022 Standard Edition Eval Build 20348 in Hyper V on a Windows 11 22H2 host machine. Even after enabling Credential Guard, I can see the NTLM hash. What am I doing wrong?The following is the screenshot from System InformationFrom Device... -
in Windows 10 Software and AppsCredential Guard ON but not working in Hyper V guest.: I am running a Windows Server 2022 Standard Edition Eval Build 20348 in Hyper V on a Windows 11 22H2 host machine. Even after enabling Credential Guard, I can see the NTLM hash. What am I doing wrong?The following is the screenshot from System InformationFrom Device... -
Hyper V Dedicated Network Traffic for Hyper V Replication between two Hyper V Server
in Windows 10 GamingHyper V Dedicated Network Traffic for Hyper V Replication between two Hyper V Server: Hi AllI have a problem on the Hyper V of replication traffic. I search many KB or the articles in the internet and there are no official information on how to isolate the Hyper V replication traffic Does it anyone know how to configure it for the Hyper V Server 2012R2 and... -
in Windows 10 Software and AppsHyper V Dedicated Network Traffic for Hyper V Replication between two Hyper V Server: Hi AllI have a problem on the Hyper V of replication traffic. I search many KB or the articles in the internet and there are no official information on how to isolate the Hyper V replication traffic Does it anyone know how to configure it for the Hyper V Server 2012R2 and... -
Clipboard between host and Hyper-V guest not working
in Windows 10 VirtualizationClipboard between host and Hyper-V guest not working: I enabled Hyper-V and installed Windows XP (for very old apps). Everything seemed to be fine until I realize that I cannot transfer files between the host and the guest using clipboard! Any idea? Thanks! 169021 -
Hyper-V and Windows 10 Guest speed
in Windows 10 VirtualizationHyper-V and Windows 10 Guest speed: What are the best memory settings for a Windows 10 Guest on Hyper-V? 16 Gb of physical memory 127556 -
No full screen console in Windows XP running as Hyper-V guest
in Windows 10 VirtualizationNo full screen console in Windows XP running as Hyper-V guest: I have an old DOS program that runs fine in a console window under native Windows XP. I've setup a shortcut on the XP machines and selected full screen. When the application runs it opens full screen. On a Windows 10 with a Hyper-V instance of Windows XP the application is... -
Hyper-V unable to configure network for guest OS - no network
in Windows 10 VirtualizationHyper-V unable to configure network for guest OS - no network: I am running Hyper-V on Windows 10 Pro and trying to install CentOS 6 on a VM. I define an external virtual switch, create a VM, specifying the use of the external virtual switch. I have 2 NICs on the host system, both with network access and internet access. The external... -
Hyper-v guest internet connection lost after booting as VHDX.
in Windows 10 VirtualizationHyper-v guest internet connection lost after booting as VHDX.: Hello, I am running Windows 10 Pro (10240) and have a guest Windows 10 VM (10528) which were working fine. Both were activated and connected to internet correctly. Today I booted the VM as native boot VHDX. This installed some drivers, connected to internet and...
Tags:
hyper-v guest prompts for password not PIN
