Windows 10: DIY laptop battery: Battery Calibration / Design Capacity reset help
Discus and support DIY laptop battery: Battery Calibration / Design Capacity reset help in Windows 10 Software and Apps to solve the problem; Hello all,This is my first question here so forgive me if I overstep.I built a custom battery for my Asus G14 laptop and the cells in the new battery... Discussion in 'Windows 10 Software and Apps' started by Matthew Telzerow, Oct 7, 2024.
  1. DIY laptop battery: Battery Calibration / Design Capacity reset help
    Hello all,This is my first question here so forgive me if I overstep.I built a custom battery for my Asus G14 laptop and the cells in the new battery have a 30% higher capacity than the original battery. How I did this was I removed each individual cell from the original battery, kept the stock BMS, and soldered new cells to the BMS. I confirmed everything was working properly before installing. I've left the bottom cover off my laptop to check voltages of the battery. Upon initial charge, I noticed windows would get to 100% but the battery would still charge for a good hour or two at around 3
  1. DIY laptop battery: Battery Calibration / Design Capacity reset help - Similar Threads - DIY laptop battery
  2. DIY laptop battery: Battery Calibration / Design Capacity reset help
    DIY laptop battery: Battery Calibration / Design Capacity reset help: Hello all,This is my first question here so forgive me if I overstep.I built a custom battery for my Asus G14 laptop and the cells in the new battery have a 30% higher capacity than the original battery. How I did this was I removed each individual cell from the original...
  3. Battery Calibration / Design Capacity reset
    Battery Calibration / Design Capacity reset: Hello all,This is my first question here so forgive me if I overstep.I built a custom battery for my Asus G14 laptop and the cells in the new battery have a 30% higher capacity than the original battery. How I did this was I removed each individual cell from the original...
  4. Battery Calibration / Design Capacity reset
  5. Design capacity is equal to full charge capacity in battery report
    Design capacity is equal to full charge capacity in battery report: My battery report is acting very weird... it shows the design capacity equal to that of full charge capacity and both are decreasing over time. Can anyone help?I use my laptop plugged in most of the time.every week I drain the battery to 10-15% for its health so I shouldn't...
  6. Design capacity is equal to full charge capacity in battery report
  7. battery calibration
    battery calibration: I am new to this forum and for some reason I cant post my question in the HP forums, I am using a HP 15s-eq1xxx computer and there is a message in the support assistant saying my battery needs to be calibrated, what is this and how is it done. 179439
  8. How to change laptop battery designed capacity
    How to change laptop battery designed capacity: Hi all, anyone know how to re-setting laptop battery designed capacity?? i mod my old laptop battery, since the old battery only last for 1 hour less.... i give brand new battery in the battery pack, change from 4 x 18650 2200mAH cell to 8 x 22650 5000mAH cell...
  9. My Battery Design Capacity Changed?
    My Battery Design Capacity Changed?: I have interesting problem. In the past my laptop battery life was just 1 hour and then I searced why this thing is so low and, I noticed my laptop battery capacity is 24.000mWh. I did calibration my battery and this amounth decreased 20.000mWh. After that yesterdey my...
  10. Battery design capacity fluctuates
    Battery design capacity fluctuates: [ATTACH] submitted by /u/derekamoss [link] [comments] https://www.reddit.com/r/Windows10/comments/ffxalh/battery_design_capacity_fluctuates/
