Windows 10: DIY laptop battery: Battery Calibration / Design Capacity reset help
Discus and support DIY laptop battery: Battery Calibration / Design Capacity reset help in Windows 10 Gaming to solve the problem; Hello all,This is my first question here so forgive me if I overstep.I built a custom battery for my Asus G14 laptop and the cells in the new battery... Discussion in 'Windows 10 Gaming' started by Matthew Telzerow, Oct 7, 2024.
DIY laptop battery: Battery Calibration / Design Capacity reset help - Similar Threads - DIY laptop battery
in Windows 10 Software and AppsDIY laptop battery: Battery Calibration / Design Capacity reset help: Hello all,This is my first question here so forgive me if I overstep.I built a custom battery for my Asus G14 laptop and the cells in the new battery have a 30% higher capacity than the original battery. How I did this was I removed each individual cell from the original... -
in Windows 10 GamingBattery Calibration / Design Capacity reset: Hello all,This is my first question here so forgive me if I overstep.I built a custom battery for my Asus G14 laptop and the cells in the new battery have a 30% higher capacity than the original battery. How I did this was I removed each individual cell from the original... -
in Windows 10 Software and AppsBattery Calibration / Design Capacity reset: Hello all,This is my first question here so forgive me if I overstep.I built a custom battery for my Asus G14 laptop and the cells in the new battery have a 30% higher capacity than the original battery. How I did this was I removed each individual cell from the original... -
Design capacity is equal to full charge capacity in battery report
in Windows 10 Software and AppsDesign capacity is equal to full charge capacity in battery report: My battery report is acting very weird... it shows the design capacity equal to that of full charge capacity and both are decreasing over time. Can anyone help?I use my laptop plugged in most of the time.every week I drain the battery to 10-15% for its health so I shouldn't... -
in Windows 10 GamingDesign capacity is equal to full charge capacity in battery report: My battery report is acting very weird... it shows the design capacity equal to that of full charge capacity and both are decreasing over time. Can anyone help?I use my laptop plugged in most of the time.every week I drain the battery to 10-15% for its health so I shouldn't... -
battery calibration
in Windows 10 Performance & Maintenancebattery calibration: I am new to this forum and for some reason I cant post my question in the HP forums, I am using a HP 15s-eq1xxx computer and there is a message in the support assistant saying my battery needs to be calibrated, what is this and how is it done. 179439 -
How to change laptop battery designed capacity
in Windows 10 BSOD Crashes and DebuggingHow to change laptop battery designed capacity: Hi all, anyone know how to re-setting laptop battery designed capacity?? i mod my old laptop battery, since the old battery only last for 1 hour less.... i give brand new battery in the battery pack, change from 4 x 18650 2200mAH cell to 8 x 22650 5000mAH cell... -
My Battery Design Capacity Changed?
in Windows 10 Drivers and HardwareMy Battery Design Capacity Changed?: I have interesting problem. In the past my laptop battery life was just 1 hour and then I searced why this thing is so low and, I noticed my laptop battery capacity is 24.000mWh. I did calibration my battery and this amounth decreased 20.000mWh. After that yesterdey my... -
Battery design capacity fluctuates
in Windows 10 Ask InsiderBattery design capacity fluctuates: [ATTACH] submitted by /u/derekamoss [link] [comments] https://www.reddit.com/r/Windows10/comments/ffxalh/battery_design_capacity_fluctuates/
