Windows 10: Freezing/Not Responding Issues in Edge
Discus and support Freezing/Not Responding Issues in Edge in Browsers and Email to solve the problem; Has anyone been having issues with freezing or not responding issues in Microsoft Edge after the big update? Both of my computers are having the... Discussion in 'Browsers and Email' started by Jesse Williams, May 24, 2018.
Freezing/Not Responding Issues in Edge - Similar Threads - Freezing Responding Issues
Microsoft Edge Not Responding
in Windows 10 GamingMicrosoft Edge Not Responding: Hi, I'm experiencing frequent freezes and unresponsiveness with Microsoft Edge on my Windows 11 PC. It happens when I'm browsing multiple tabs or trying to load certain websites. I've tried clearing the cache and disabling extensions, but the problem persists. Can someone... -
in Windows 10 Software and AppsMicrosoft Edge Not Responding: Hi, I'm experiencing frequent freezes and unresponsiveness with Microsoft Edge on my Windows 11 PC. It happens when I'm browsing multiple tabs or trying to load certain websites. I've tried clearing the cache and disabling extensions, but the problem persists. Can someone... -
in Windows 10 Installation and UpgradeMicrosoft Edge Not Responding: Hi, I'm experiencing frequent freezes and unresponsiveness with Microsoft Edge on my Windows 11 PC. It happens when I'm browsing multiple tabs or trying to load certain websites. I've tried clearing the cache and disabling extensions, but the problem persists. Can someone... -
Outlook freezing and not responding
in Windows 10 GamingOutlook freezing and not responding: Hello. I work for an MSP and we are having an issue on a number of Dell issues laptops. All running windows 11 with good specs. Outlook will randomly start freezing and be unusable. The only way our users can get back to work is by force closing the app or restarting their... -
in Windows 10 Software and AppsOutlook freezing and not responding: Hello. I work for an MSP and we are having an issue on a number of Dell issues laptops. All running windows 11 with good specs. Outlook will randomly start freezing and be unusable. The only way our users can get back to work is by force closing the app or restarting their... -
PC not responding/freezes
in Windows 10 GamingPC not responding/freezes: PC apps stop responding/loading 1 by 1,eventually entire PC stops responding.Try to shutdown but the PC gets stuck on the 'Shutting down' screen.Tried updating windows,defragmenting,memory scan and a virus scan.none worked.disable fast start-up also... -
in Windows 10 Software and AppsPC not responding/freezes: PC apps stop responding/loading 1 by 1,eventually entire PC stops responding.Try to shutdown but the PC gets stuck on the 'Shutting down' screen.Tried updating windows,defragmenting,memory scan and a virus scan.none worked.disable fast start-up also... -
Edge not responding
in Browsers and EmailEdge not responding: OS version 21H1 19043.1081 When i open Microsoft Edge and click on a link i am getting the Microsoft Edge is not responding and have to close the program ( sometimes i have to use Task Manager to close it ). My version of Edge is Version 91.0.864.48 . Would i be able to... -
The page on Edge is not responding
in Windows 10 Network and SharingThe page on Edge is not responding: I often get the message that the page is not responding. It doesn’t depend on the specific page and can occur any time anywhere. I have to exit the page to get rid of this message...
