Windows 10: Having an annoying issue regarding sound and setting up my audio interface.
Discus and support Having an annoying issue regarding sound and setting up my audio interface. in Windows 10 Ask Insider to solve the problem; I've had my M-Audio M-Track 2x2 for about 2 years now and that time has been relatively painless until I finally let my computer download some new... Discussion in 'Windows 10 Ask Insider' started by /u/Nakoete, Dec 7, 2020.
  1. Having an annoying issue regarding sound and setting up my audio interface.
    I've had my M-Audio M-Track 2x2 for about 2 years now and that time has been relatively painless until I finally let my computer download some new update for Windows. Everything else has been fine, but now every time I restart my computer, if I want to use my audio interface, I have to troubleshoot my sound in the settings. It does work every time I use it, but you can probably understand that it's incredibly annoying to have to do this every time.
    When the troubleshooter does finish, it either says something about having messed with the sound settings, or something about the drivers. But it seems those settings must be reverting every time.
    submitted by /u/Nakoete
    [link] [comments]
  2. Junaid_A Win User
    Multichannel audio interface in/out routing
    Hi Paulo,
    Thank you for writing to Microsoft Community forums.
    • What is the make and model of your external audio interface?
    • Which routing application are you using?
    The configurations of inputs and outputs on any audio interface is dependent on the hardware and its supporting software. Any audio interface with more than 2 inputs and 2 outputs, should ideally give the user an option to map the
    Input and Output Config, according to his interest.
    I suggest you to go through the user manual provided by your audio interface's manufacturer to know how to set up the control surface.
    If it doesn't explain how to configure, I suggest you to get in touch with the audio interface's manufacturer to know how to configure the same.
    Hope it answers.
    Junaid_A, Dec 7, 2020
  3. Arun B J Win User
    Windows 10 issues with USB sound interfaces
    Hi George,
    I understand your concern and will assist you to resolve this issue.
    From what you have mentioned, I would suggest you to try these steps to see if it resolves the issue.
    Method 1: Hardware Troubleshoot
    Windows 10 has a built-in troubleshooter to check and fix issues with Sound. I would suggest you to run this troubleshooter to check if the issue is with your Audio.
    Refer these steps:
    • Press Windows key +X, select Control panel.
    • Change the view by option on the top right to Large icons.
    • Click on troubleshooting and click on the view all option on the left panel.
    • Run the Recording Audio troubleshooter.
    Method 2.
    Try updating the Audio drivers from the manufacturer's website and check if the issue persists.
    Follow the steps to update the audio drivers:
    a. Press Windows key + X key and click Device Manager.
    b. Expand the Sound, Video and game controllers.
    c. Right-click on the Sound card and click on Update driver software.
    d. Restart the computer and check.
    No sound in Windows.
    Refer the link below.
    http://windows.microsoft.com/en-US/windows/no-sound-help#no-sound=windows-8&v1h=win8tab4&v2h=win7tab1&v3h=winvistatab1&v4h=winxptab1
    Arun B J, Dec 7, 2020
  4. Having an annoying issue regarding sound and setting up my audio interface.
    Weird issue with sounds
    I understand it can be quite annoying when you have to change audio settings frequently. The volume of the audio might reduce automatically, if Loudness Equalization is enabled in audio enhancements.
    1. Is the issue specific to YouTube application?
    2. Since when are you facing this issue?
    I suggest you to follow the methods mentioned below and check if that helps:
    Method 1:
    Disable the Loudness Equalization from audio enhancements settings.
    1. Right-click on the volume icon on the taskbar.
    2. Select Sounds option from the list.
    3. Click on the Playback tab.
    4. Now right-click on the Speakers and select
      Properties from the list.
    5. Click on the Enhancements tab.
    6. Uncheck Loudness Equalization option.
    Also, change the option under communication tab from sound settings. Follow steps mentioned below:
    2. Select ‘Sounds’ option from the list.
    3. Now click on the ‘Communications’ tab.
    4. Select ‘Do nothing’ options from the list.
    Method 2: If you still face the issue, we can try running the
    Audio Troubleshooter. Follow the steps mentioned below:
    1. Tap on ‘Windows + I’ on the keyboard.
    2. Click on ‘Update & Security’ option.
    3. Select ‘Troubleshoot’ option.
    4. Now click on the ‘Playing Audio’ from the list and ‘Run the troubleshooter’.
    Hope it helps.
    Sandeep Kumar M
    Sandeep_KM, Dec 7, 2020
  1. Having an annoying issue regarding sound and setting up my audio interface. - Similar Threads - Having annoying issue
  2. annoying audio issue
    annoying audio issue: i've been dealing with this annoying bluetooth audio problem on my windows 11 pc for weeks now, and nothing fixes it. i got sony bluetooth headphones, they used to work fine with windows 10, but now the audio is bad, keeps cutting out, and the microphone won’t work at all....
  3. annoying audio issue
  4. Audio interface issues
    Audio interface issues: Hey how’s it going ,So I’m running an acer all in one With windows 8.1 I connect my art pro 2channel audio interface Installed the drivers all good and everything Opened my daw And. Noticed it wasn’t picking up any sound from my condenser mic neither was my mixer Now just...
  5. Audio interface issues
  6. Audio interface and audio apps set up help
    Audio interface and audio apps set up help: Hello, I work in audio post production and I've just moved from Mac to Windows. I'm having an issue with audio apps and my sound card when their respective sample rates differ. For example, lets say my sound card is set to 48kHz sampling rate. When I open a stand alone...
  7. Regarding audio issues
    Regarding audio issues: I had a problem with my audio. I am hearing the hissing noise from the speakers. I installed the Realtek 2.182 version. When I installed the version the audio was not there but when I started the system the hissing came. I was asked to update the driver. When I did that in...
  8. Sound interface not show up.
    Sound interface not show up.: When turning up or down the volume, there usually shown an interface that tells the sound level 0-100 and the song playing at that moment. But now it has gone for no reason, so I want it back. [ATTACH] This one [Move from Thai]...
  9. Sound interface not show up.
    Sound interface not show up.: When turning up or down the volume, there usually shown an interface that tells the sound level 0-100 and the song playing at that moment. But now it has gone for no reason, so I want it back....
  10. Windows audio/ interface issue
    Windows audio/ interface issue: I use my pc as a DAW Studio. I have a Universal Audio Apollo Twin USB audio interface. It works very well with all things audio on my pc - until Friday. I installed Sonarworks room calibration software to finish flattening my room acoustics out. This explanation is lengthy...
