Windows 10: Headphone audio will turn off between 5-7 minutes when audio volume is set to low Edge,...
Discus and support Headphone audio will turn off between 5-7 minutes when audio volume is set to low Edge,... in Windows 10 Drivers and Hardware to solve the problem; PC: Homebuilt system Intel CPU, MSI motherboard, using onboard audio, Windows 10 Pro, latest updates. I connect my PC to a Scarlett Solo audio... Discussion in 'Windows 10 Drivers and Hardware' started by Assassin 11B3P, Sep 22, 2024.
Headphone audio will turn off between 5-7 minutes when audio volume is set to low Edge,... - Similar Threads - Headphone audio turn
in Windows 10 GamingHeadphone audio will turn off between 5-7 minutes when audio volume is set to low Edge,...: PC: Homebuilt system Intel CPU, MSI motherboard, using onboard audio, Windows 10 Pro, latest updates. I connect my PC to a Scarlett Solo audio interface using a 3.5mm audio cable green.Notebook 1: Asus, running Windows 10 Pro and the Realtec audio stuff.Notebook 2: Samsung... -
in Windows 10 Software and AppsHeadphone audio will turn off between 5-7 minutes when audio volume is set to low Edge,...: PC: Homebuilt system Intel CPU, MSI motherboard, using onboard audio, Windows 10 Pro, latest updates. I connect my PC to a Scarlett Solo audio interface using a 3.5mm audio cable green.Notebook 1: Asus, running Windows 10 Pro and the Realtec audio stuff.Notebook 2: Samsung... -
Wireless headphones don't play audio for anywhere between ~5-30 seconds and then the audio...
in Windows 10 GamingWireless headphones don't play audio for anywhere between ~5-30 seconds and then the audio...: Hi,I've had this problem with my Beats solo 3's since I started using them wirelessly on my Dell laptop. Whenever I connect them and play any audio on them it will take a while before I start hearing the audio. Even when joining a discord voice call it will take a little bit... -
in Windows 10 Software and AppsWireless headphones don't play audio for anywhere between ~5-30 seconds and then the audio...: Hi,I've had this problem with my Beats solo 3's since I started using them wirelessly on my Dell laptop. Whenever I connect them and play any audio on them it will take a while before I start hearing the audio. Even when joining a discord voice call it will take a little bit... -
Audio Goes Up and Down When Volume Is Low
in Windows 10 GamingAudio Goes Up and Down When Volume Is Low: My audio volume is on 32 and when I'm playing an audio, if the audio volume is too low, it goes quiet. It's very annoying when I'm listening to songs, the experience will not be very nice since the volume kept going up and down constantly until you have your volume on 50-60+.... -
in Windows 10 Software and AppsAudio Goes Up and Down When Volume Is Low: My audio volume is on 32 and when I'm playing an audio, if the audio volume is too low, it goes quiet. It's very annoying when I'm listening to songs, the experience will not be very nice since the volume kept going up and down constantly until you have your volume on 50-60+.... -
in Windows 10 Drivers and HardwareAudio Goes Up and Down When Volume Is Low: My audio volume is on 32 and when I'm playing an audio, if the audio volume is too low, it goes quiet. It's very annoying when I'm listening to songs, the experience will not be very nice since the volume kept going up and down constantly until you have your volume on 50-60+.... -
Low headphone audio
in Windows 10 Drivers and HardwareLow headphone audio: Only when plugging in headphone, the audio goes totally quiet and is barely audible. This suddenly started to happen after opening it. I've tried a few things like reinstalling audio, clean boot, etc. No dice... -
Audio issue : random low volumes
in Windows 10 Drivers and HardwareAudio issue : random low volumes: Hi all, I am facing an issue with audio on my new laptop. Whenever I am playing any video on netflix windows applications, youtube on browsers or anything the audio sometimes randomly becomes very low and kind of sound flat. But when I close that application and reopen it...
