Windows 10: hello i am using an hp laptop and its not charging and i i switched some parts i week ago...
Discus and support hello i am using an hp laptop and its not charging and i i switched some parts i week ago... in Windows 10 Gaming to solve the problem; i would really like if someone helped me here... Discussion in 'Windows 10 Gaming' started by snetzzy s, Jan 16, 2023.
  1. snetzzy s Win User
  2. Mobyd33 Win User
    Laptop switching between charging and not charging when use.
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    Mobyd33, Jan 16, 2023
  3. Toshiba Laptop Not Holding Battery Charge
    attached is a pic of the internal of the laptop
    there does NOT appear to be a CMOS battery
    what should my next steps be?
    - fully charge existing battery and see if i remove it and install back teh next day whether its still fully charged?
    - charge the battery for 18 hours to charge the internal CMOS battery?
    - suggestions please as Im not sure
    bartjunited, Jan 16, 2023
  4. hello i am using an hp laptop and its not charging and i i switched some parts i week ago...
    Laptop Not Charging
    Unfortunately I wasn't able to download it as Running security scan kept running forever.
    In case you are interested
    I have an HP EliteBook 8540w laptop w/o a battery from a few years ago. I do not have the original battery & AC-Adapter.
    Determined the computer's laptop compartment battery information.
    If I had the original AC-Adapter I would have determined that information also.
    Checking for a replacement battery on-line resulted in conflicting information.
    Went on-line for the correct manual for my make and manual using HP's Support Assistant
    Found the parts list for the battery & AC-Adapter part #'s and power info.
    Went to HP's store and found the information and cost by plugging in the applicable p/n's.
    --- The best part of that step was exact information such as finding out the battery is an 8-cell unit
    Why did I go through that much trouble? Because I've seen mis-matched info many times.
    But also maybe because you'd like to ensure you will be ordering the correct battery using a similar approach on your Toshiba if you end up needing a replacement battery
    MeAndMyComputer, Jan 16, 2023
  1. hello i am using an hp laptop and its not charging and i i switched some parts i week ago... - Similar Threads - hello using laptop
  2. Hello it’s me i got an problem like a week ago and I have started to think that I have an...
    Hello it’s me i got an problem like a week ago and I have started to think that I have an...: My pc is showing me an BSoD and I think that I got a virus I can’t access my pc normally. I have tried installing windows but it shows an BSoD. I have also tried changing to an hhd two times but it also showed BSoD. Now I have started to think that my pc has an virus/malware...
  3. Hello it’s me i got an problem like a week ago and I have started to think that I have an...
  4. I am being charged for a service i cannot use
    I am being charged for a service i cannot use: i logged into my account and it wont let me use any of the microsoft. i want refund https://answers.microsoft.com/en-us/windows/forum/all/i-am-being-charged-for-a-service-i-cannot-use/c53b5182-e522-40cf-af0c-18a0fb67da9a
  5. I am being charged for a service i cannot use
  6. hello i am using an hp laptop and its not charging and i i switched some parts i week ago...
    hello i am using an hp laptop and its not charging and i i switched some parts i week ago...: i would really like if someone helped me here https://answers.microsoft.com/en-us/windows/forum/all/hello-i-am-using-an-hp-laptop-and-its-not-charging/abc537b2-5d43-41f3-b111-784c69e135b2
  7. hello i am using an hp laptop and its not charging and i i switched some parts i week ago...
  8. Hello! I am using a HP Pavilion x360 laptop and I just got this laptop mid 2022. However,...
    Hello! I am using a HP Pavilion x360 laptop and I just got this laptop mid 2022. However,...: my camera is not working and i dont know why. i opened the exact camera app and its just showing black. though the camera features are working like the click button but there's no visual appearing on the screen even though there's a light indicating that the camera is being...
  9. Hello! I am using a HP Pavilion x360 laptop and I just got this laptop mid 2022. However,...
  10. Hello , I am having a 'plugged in not charging' problem
    Hello , I am having a 'plugged in not charging' problem: Is there any authentic solution? windows is 10 AC Adapter is all set because I have tried it with another different charger but getting the same problem please help me...
