Windows 10: How do i fix a problem with my microphone where all audio stops when my microphone is on?
Discus and support How do i fix a problem with my microphone where all audio stops when my microphone is on? in Windows 10 Customization to solve the problem; I have had this problem with my pc where when i join a voice call, start a microphone test or simply select the input device on the control panel all... Discussion in 'Windows 10 Customization' started by Z.Hark, Dec 5, 2023.
How do i fix a problem with my microphone where all audio stops when my microphone is on? - Similar Threads - fix problem microphone
How do i fix my microphone
in Windows 10 GamingHow do i fix my microphone: HelloMy mic is not working on my computer.Just to be sure i've tried using it on my phone and there is no problem here.Ive checked its the right mic that is select in settings, but there is no input on the bar where you can see input sound. When i play games like valorant i... -
in Windows 10 Software and AppsHow do i fix my microphone: HelloMy mic is not working on my computer.Just to be sure i've tried using it on my phone and there is no problem here.Ive checked its the right mic that is select in settings, but there is no input on the bar where you can see input sound. When i play games like valorant i... -
in Windows 10 GamingHow do i fix a problem with my microphone where all audio stops when my microphone is on?: I have had this problem with my pc where when i join a voice call, start a microphone test or simply select the input device on the control panel all audio gets cut off. Im listening to a song on youtube, it gets cut off, i have background sounds from a game, it gets cut off,... -
in Windows 10 Software and AppsHow do i fix a problem with my microphone where all audio stops when my microphone is on?: I have had this problem with my pc where when i join a voice call, start a microphone test or simply select the input device on the control panel all audio gets cut off. Im listening to a song on youtube, it gets cut off, i have background sounds from a game, it gets cut off,... -
When my microphone is active, my audio stops working.
in Windows 10 GamingWhen my microphone is active, my audio stops working.: I don't know when this started but I know this problem wasn't occurring before.Some quick stats. I use AVG Driver Updater to update drivers and I update often. Except I don't update the touchpad on my laptop as the update removes features that makes it harder to use. I... -
in Windows 10 Software and AppsWhen my microphone is active, my audio stops working.: I don't know when this started but I know this problem wasn't occurring before.Some quick stats. I use AVG Driver Updater to update drivers and I update often. Except I don't update the touchpad on my laptop as the update removes features that makes it harder to use. I... -
in Windows 10 Drivers and HardwareWhen my microphone is active, my audio stops working.: I don't know when this started but I know this problem wasn't occurring before.Some quick stats. I use AVG Driver Updater to update drivers and I update often. Except I don't update the touchpad on my laptop as the update removes features that makes it harder to use. I... -
Using Microphone stops my audio
in Windows 10 CustomizationUsing Microphone stops my audio: Hi there, I've been having problems with my JBL Charge 3 Speaker which comes with a built in microphone. I've been using this with Zoom for the whole covid lockdown period and it has been working fine the last 3 months. Suddenly when i turn on Zoom, all my audio from the... -
How do I fix my audio problems with all microphones?
in Windows 10 BSOD Crashes and DebuggingHow do I fix my audio problems with all microphones?: About a week and a half to two weeks ago my main "Studio" microphone stopped working. The sound control panel shows it is the default mic, working properly and the troubleshooter always found nothing. I was still able to use headsets to talk to anyone on Google Meet. As of 2...
