Windows 10: how do I set battery percentage in Power and Battery
Discus and support how do I set battery percentage in Power and Battery in Windows 10 Gaming to solve the problem; I can't find the switch to turn it on... Discussion in 'Windows 10 Gaming' started by José Mª Goenaga, May 13, 2025.
  1. how do I set battery percentage in Power and Battery
  2. Battery percentage visualisation on taskbar and reduced task bar.
    Thanks for reaching out! I'm an Independent Advisor and a Microsoft user like you.
    To address the issue of displaying the battery percentage on the taskbar and reduced taskbar in Windows 11, there are several methods and tools available, although it appears that Windows 11 does not natively support this feature directly on the taskbar by default.
    Methods to Display Battery Percentage on Windows 11
    1. Using Taskbar Settings:
      • Open the Settings menu by clicking the Start button and selecting Settings.
      • Navigate to System > Power & sleep.
      • Scroll down to the Battery section and toggle the switch next to Battery percentage to enable it.
    2. Using Battery Icon Settings:
      • Click on the battery icon in the taskbar.
      • Select More Power Options.
      • Enable the Show Battery Percentage option.
    3. Third-Party Applications:
      • Battery Percentage Icon App: Available on the Microsoft Store, this app can be installed to display the battery percentage on the taskbar. After installation, it will show the battery percentage next to the battery icon
      • Battery Tracker: This app not only shows the battery percentage but also provides notifications when the battery life is lower/higher than a threshold or fully charged. It can be installed from GitHub or the Microsoft Store.
    Additional Tips
    • Reduced Taskbar in Tablet Mode: Unfortunately, there is no native setting in Windows 11 to display the battery percentage on the reduced taskbar in tablet mode. Using third-party applications like the Battery Percentage Icon App might be the best workaround for this scenario.
    • Feedback to Microsoft: If you find that these solutions do not meet your needs, you can suggest this feature to Microsoft through the Feedback Hub app. This app allows users to send suggestions and report issues directly to Microsoft.
    While Windows 11 does not natively support displaying the battery percentage directly on the taskbar by default, there are several methods and third-party applications available to achieve this functionality. For users who need this feature in tablet mode or on the reduced taskbar, third-party apps like the Battery Percentage Icon App or Battery Tracker are recommended solutions. Additionally, providing feedback to Microsoft through the Feedback Hub can help advocate for this feature in future updates.
    Please feel free to reach out if you require any additional assistance. I'm here to help!
    Munkhbayar B., May 13, 2025
  3. [Suejin] Win User
    Battery Percentage is not going
    Hello Prabash,
    I'm Jin, a fellow Windows 10 user and an independent advisor.
    I can see that plugging your laptop doesn't increase the percentage charged on the
    battery.
    Just to clarify, does charging stops at certain percentage or totally not charging the battery?
    There's also a possibility the the power consumption is too much for it to actually charge the battery, try keeping your laptop idle for 10-15 mins and see if there's a progress in the battery.
    If it stops charging on a certain percentage, try doing the steps below:
    1. Right-click on the battery icon.
    2. Select Power Options.
    3. Click on Change plan settings.
    4. Click on Change advanced power settings.
    5. Click Restore plan defaults.
    6. Then hit OK.
    Check as well if there is an installed utility from the manufacturer that may limit the charging capacity of your laptop. This are common to new laptops to extend the life of it's battery.
    You can also check the troubleshooting steps provided in this link:
    https://www.groovypost.com/howto/troubleshoot-b...
    This is a non-Microsoft website which would provide accurate and safe information. Watch out for ads on the site which are frequently classified as a PUP (Potentially Unwanted Products). There is no need to buy paid products to fix your computers as they do
    more harm than good sometimes.
    Kind regards.
    [Suejin], May 13, 2025
  4. oscer1 Win User
    oscer1, May 13, 2025
  1. how do I set battery percentage in Power and Battery - Similar Threads - set battery percentage
  2. how do I set battery percentage in Power and Battery
    how do I set battery percentage in Power and Battery: I can't find the switch to turn it on https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-set-battery-percentage-in-power-and/adb3c37f-f3f2-417b-9a58-530571de50d4
  3. Power & Battery Settings
    Power & Battery Settings: Hi Microsoft community, Greeting and good day to you. The reason writing in as i seeking further information regarding on the Power & Battery settings for my Laptop with currently update to Windows 11 Pro 24H2 OS Build 26100.2161. Before I update my windows, I remember there...
  4. Power & Battery Settings
  5. Power & Battery Settings
    Power & Battery Settings: The power & battery settings won't open when going to Settings >System > power & battery. The same thing happens when I right click the battery icon power & sleep settings in the sys tray. No error message; just won't open. Using Windows 11 - Home Edition. All System Updates...
  6. Battery Percentage
    Battery Percentage: I want the battery charge percentage visible while charging without taking the pointer to the icon. Is that feature already in Win10 or not?If not please take my suggestion and make an update. This is not a major issue, it's just that I am always worried I might keep the...
  7. Battery Percentage
  8. Battery Percentage
  9. How do I recalibrate the battery percentage?
    How do I recalibrate the battery percentage?: I own an XPS 15 9570. I noticed that my battery, according to both the battery report and the intel graphics command center, currently has a charging capacity of around 64800 mWh. Which is much less than the design capacity of 97000. I figured I would try recalibrating the...
  10. battery percentage
    battery percentage: after updating to 1809 my battery percentage does not not change from 100% nor doed percentage show in taskbar icon https://answers.microsoft.com/en-us/windows/forum/all/battery-percentage/c870e216-a100-4c31-ac0b-665f3b954b17
