Windows 10: How does cpu speed work?
Discus and support How does cpu speed work? in Windows 10 Software and Apps to solve the problem; So I was just wondering about something that’s kind of strange to me. I used to have a HP pavilion gaming laptop with 1050Ti and an intel i5 8300h with... Discussion in 'Windows 10 Software and Apps' started by syper, Nov 13, 2024.
  1. syper Win User
    So I was just wondering about something that’s kind of strange to me. I used to have a HP pavilion gaming laptop with 1050Ti and an intel i5 8300h with 8 gb of ram and 1 tb hdd. When I was using this laptop to play games and stuff, it would run kind of slow and it would a long time to load certain things I was on windows 11 btw not to mention gaming performance, So I tried to reset the laptop but this would not work since windows recovery couldn’t be turned on somehow. So I had decided to buy a usb stick and download windows 10 on it with a separate device and install it on the usb so I
    syper, Nov 13, 2024
  2. psyko12 Win User
    How to get speed step to work?
    Hmmm check to see if his power profiles are set to balanced, or even in High perf, it should work underclocking the proc... Even when I use High perf profile on power management I check with cpu z and it sees my proc underclocking, while ilde or net browsing... It should work if its turned on in BIOS... Speed step c1 state (correct me if I'm wrong) those are whats listed on my bios options.
    psyko12, Nov 13, 2024
  3. my cpu speed is set at base speed 1.19ghz
    Yes the speed stays the same when I load up any cpu consuming task and hp bios doesn't have Intel step speed and turbo boost settings
    VikrantSharma3, Nov 13, 2024
  4. Sasqui Win User
    Overclocking / Undervolting guide for Vega 56 or 64?
    Here's a quick laundry list:
    List of software to use for overclocking and testing
    Examples:
    Wattman (and how to find and use it, like an overview, including profiles)
    Unigine Valley or Heaven (use this for quick testing while changing settings in Wattman and checking for stability / artifacts) ...just suggesting this
    How to monitor cores / mem speeds and temps during testing (I've seen screen overlays, and others using GPUz)
    Step-by step overclocking in Wattman
    Fan speeds
    Power limit
    Temp limit
    Voltages
    Core speeds
    Memory speeds
    Sasqui, Nov 13, 2024
  1. How does cpu speed work? - Similar Threads - does cpu speed
  2. How to speed up cpu speed
    How to speed up cpu speed: Does anyone know how to speed up your cpu besides over clocking because I heard that the faster your cpu speed is the more for you get and I want to speed up my speed can someone give me tips pls...
  3. How to speed up cpu speed
  4. How to speed up cpu speed
  5. How does cpu speed work?
    How does cpu speed work?: So I was just wondering about something that’s kind of strange to me. I used to have a HP pavilion gaming laptop with 1050Ti and an intel i5 8300h with 8 gb of ram and 1 tb hdd. When I was using this laptop to play games and stuff, it would run kind of slow and it would a...
  6. How to increase CPU speed
    How to increase CPU speed: How To increase thisI certainly want to do thatplease help me increase that 2.69 to something I am ready to keep hands in the registry tooPlease help me increase this 2.69Ghz to atleast 3.10Ghz or 4Ghz* Original title: ! ! ! ! HELP PLEASE ! ! ! !...
  7. cpu speeds
    cpu speeds: I have an IntelR CoreTM i3-7130U CPU @ 2.70GHz 2.70 GHz on a dell laptop. my wife has a dell with amd a6-9225 radeon r4,5 compute cores 2c +3g 2.60 ghz. should they be about the same speed. her laptop is much slower....
  8. CPU speed throttling Maximum Processor State does not work anymore
    CPU speed throttling Maximum Processor State does not work anymore: First, I used the CPU speed limitation and system cooling policy=passive to keep down the fan noise. This worked fine, for a long time. But now I suddenly get this behaviour: Maximum Processor State: 80% or less -> CPU speed does not exceed 1.6 Ghz anymore! Maximum...
  9. Cpu Speed
    Cpu Speed: Hi everyone, I recently installed a fresh copy of windows 10 on my laptop, along with wiping my hard drive. Something I've notice however is that shortly after starting up, my CPU speed drops from around 3.50 ghz all the way down to 0.39 ghz, where it never fluctuates,...
  10. CPU speed
    CPU speed: How do I reduce my cpu speed from 100% to 65% to stop random freezing? https://answers.microsoft.com/en-us/windows/forum/all/cpu-speed/7e4c5137-0a24-4fd7-962d-d6180319a97e
