Windows 10: How long do pc repair shops usually take to fix my problem?
Discus and support How long do pc repair shops usually take to fix my problem? in AntiVirus, Firewalls and System Security to solve the problem; I dropped my laptop off at a local computer repair shop (Enterprise). I had a virus that wouldn't let me login into Windows. The technician left me a... Discussion in 'AntiVirus, Firewalls and System Security' started by beautyobsessed7, May 6, 2017.
Page 1 of 2
Page 1 of 2
How long do pc repair shops usually take to fix my problem? - Similar Threads - long repair shops
How long does it take Microsoft to fix a problem??
in Windows 10 GamingHow long does it take Microsoft to fix a problem??: I have an OEM windows 11 liscence, and I updated my BIOS, so my windows detected a new hardware change although i didnt even change a cable, and it wont let me activate my windows again, i had a chat with a respectable customer support, They said that its a know issue and... -
in Windows 10 Software and AppsHow long does it take Microsoft to fix a problem??: I have an OEM windows 11 liscence, and I updated my BIOS, so my windows detected a new hardware change although i didnt even change a cable, and it wont let me activate my windows again, i had a chat with a respectable customer support, They said that its a know issue and... -
How long will resetting my PC take
in Windows 10 GamingHow long will resetting my PC take: Having to reset my PC due to Windows 10 bug and broken updates.Very not happy with this b.s.How long will it take https://answers.microsoft.com/en-us/windows/forum/all/how-long-will-resetting-my-pc-take/91145d3e-0500-4d7c-bfe8-ded25a9ff8db -
in Windows 10 Software and AppsHow long will resetting my PC take: Having to reset my PC due to Windows 10 bug and broken updates.Very not happy with this b.s.How long will it take https://answers.microsoft.com/en-us/windows/forum/all/how-long-will-resetting-my-pc-take/91145d3e-0500-4d7c-bfe8-ded25a9ff8db -
in Windows 10 Installation and UpgradeHow long will resetting my PC take: Having to reset my PC due to Windows 10 bug and broken updates.Very not happy with this b.s.How long will it take https://answers.microsoft.com/en-us/windows/forum/all/how-long-will-resetting-my-pc-take/91145d3e-0500-4d7c-bfe8-ded25a9ff8db -
IDIOTS~!!! HOW LONG WILL IT TAKE TO FIX IT??
in Windows 10 Drivers and HardwareIDIOTS~!!! HOW LONG WILL IT TAKE TO FIX IT??: ANY BLUETOOTH HEADPHONES I CONNECT ARE AUTOMATICALLY DISCONNECTING!!! ALL OF THE SETTINGS ARE FINE1!!! IT'S YOU, YOU DUMB S11ITS, WHO CANNOT IMPLEMENT ONE.STUPIDEASY.FUNCTION!!!!!!!!The only solution I found to connect them manually !!!!!!EVERY TIME!!!!!BUT NO, YOU HAD TO... -
how long should a repair-install take?
in Windows 10 Installation and Upgradehow long should a repair-install take?: I'm using Win10_2004_English_x64.iso I'm going to select "not right now" for including further updates during the repair, and only do the repair using the ISO my HDD. I'm going to turn off my WIFI during the install so that Windows doesn't try to get anything else. Why?... -
How long does it take to repair an app?
in Windows 10 CustomizationHow long does it take to repair an app?: I can't open Phantasy Star online 2 in microsoft store, and when i check the directory, files are missing. The exe and other files. So the first thing that i can think of is the repair option in the settings. Since i click on repair, the files shows up outta nowhere and goes... -
File explorer take long to load. How do I fix this problem?
in Windows 10 Performance & MaintenanceFile explorer take long to load. How do I fix this problem?: Hello, I just upgraded to windows 10 and one of the things that bugs me is the file explorer on task bar load very slow. It takes around 1 seconds to load if I click on the explorer on task bar. However, if I use the win+E button the explorer open instantly. I tried to...
