Windows 10: How to auto-detect and auto-adjust max.resolution?
Discus and support How to auto-detect and auto-adjust max.resolution? in Windows 10 Graphic Cards to solve the problem; Assume I boot Win10 from an USB flash drive on various computers. The max possible resolution differs from computer to computer. I could always... Discussion in 'Windows 10 Graphic Cards' started by pstein, Mar 9, 2017.
How to auto-detect and auto-adjust max.resolution? - Similar Threads - auto detect auto
RDP windows resolution can't auto-adjust monitor screen resolution.
in Windows 10 GamingRDP windows resolution can't auto-adjust monitor screen resolution.: Hi,I'm using RDP to connect to my own Hyper-V Virtual Machine. and I have 2nd monitor which is bigger 27inch, don't know how to look the resolution. Issue is when I connect to my RDP, the windows display resolution cannot auto adjust according to the monitor size. I was... -
in Windows 10 Software and AppsRDP windows resolution can't auto-adjust monitor screen resolution.: Hi,I'm using RDP to connect to my own Hyper-V Virtual Machine. and I have 2nd monitor which is bigger 27inch, don't know how to look the resolution. Issue is when I connect to my RDP, the windows display resolution cannot auto adjust according to the monitor size. I was... -
Auto Adjust Resolution When Connecting External Monitor
in Windows 10 GamingAuto Adjust Resolution When Connecting External Monitor: Hi,So whenever i plug in my external monitor, the screen does not auto adjust resolution, maintains the same resolution as the laptop's first screen and I have to manually set it, I believe there is a way to have the monitor automatically adjust to the external monitor... -
in Windows 10 Software and AppsAuto Adjust Resolution When Connecting External Monitor: Hi,So whenever i plug in my external monitor, the screen does not auto adjust resolution, maintains the same resolution as the laptop's first screen and I have to manually set it, I believe there is a way to have the monitor automatically adjust to the external monitor... -
Windows Auto Resolution
in Windows 10 CustomizationWindows Auto Resolution: For some Background: I'm currently working on a Information display on windows 10 using a TV and a connected computer. I am using the NDI studio monitor software as a video source to play on the TV full screen. My issue is when the tv is turned off for the night, Windows... -
Microphone auto adjust!!!
in Windows 10 Drivers and HardwareMicrophone auto adjust!!!: Who came up with the ridiculous idea to auto adjust the microphone?? With so many things half baked and broken in windows 10, is it MS's mission to break everything else as well?? With one of the worst customer ratings in the world, one would think that you lot might want to... -
Adjust to Auto Brightness
in Windows 10 CustomizationAdjust to Auto Brightness: To, Microsoft Community Hi, this is Gavin. Using your Microsoft Windows 10 OS Version 2004 OS Build 19041.508 on My Laptop. I wan to keep keep Auto Brightness or Adaptive Brightness for My Laptop. How do i do that. Means My Laptop should Automatically adjust to the... -
Auto microphone adjust to max
in Windows 10 Ask InsiderAuto microphone adjust to max: I'm having this problem which whenever i open any game, my mic automatically boost it to 100. I'm using a blue yeti and it frustrates me so much that i have to adjust manually to 0. I have searched a lot of solution and it didn't work. For example: Dota 2 whenever the game... -
Microphone Auto Adjust
in Windows 10 Drivers and HardwareMicrophone Auto Adjust: On Windows 10, microphone keeps automatically adjusting. Anything to help? I have no idea what is wrong, so just reply if you need more info. https://answers.microsoft.com/en-us/windows/forum/all/microphone-auto-adjust/57afd8d5-bacf-46c5-b09b-61a0492c2668
