Windows 10: How to fix my base speed and speed stuck at 0.79 GHZ
Discus and support How to fix my base speed and speed stuck at 0.79 GHZ in Windows 10 BSOD Crashes and Debugging to solve the problem; [ATTACH]See my base speed is so low... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by NekoTheDev, Jan 12, 2021.
  1. How to fix my base speed and speed stuck at 0.79 GHZ
    How to fix my base speed and speed stuck at 0.79 GHZ 6c5aecc3-e412-4895-b6bc-6a64081ec690?upload=true.png See my base speed is so low
  2. My cpu base speed stuck at 0,8 GHz
    Hi William. This is what happens when i turn off the speedStep and TurboBoost. The GHz goes down to same speed as the base speed at 0,8 GHz. I dont understand how to base speed can be stuck at 0,8 GHz. Right now its on high performance.
    How to fix my base speed and speed stuck at 0.79 GHZ 018360d8-b2b5-4db3-a735-dc17115c974c?upload=true.png
    JonathanSandberg2, Jan 12, 2021
  3. CPU speed stuck to .79 GHZ
    Sorry, my question was misleading but my CPU is designed to go up to 4ghz with turbo and 2.4 GHz base. For some reason when I do a forced shutdown it seems to fix the problem of the CPU not being able to reach its designed speeds. However, when I put the
    computer to sleep, shut it down normally, or restart the computer all via the start menu. It brings up the problem of the CPU not being able to go to designed speeds. Something that could give a hint to what the problem is is that on HWmonitor, I have noticed
    that the package power after a regular shutdown is around 7~8 watts of power. Before this problem occurred, the system was pulling 55~60 watts of power. So it might have to dow the power, CPU, or something entirely different. Also heads up, the system that
    I am using is a FX505GT-US52 by asus. I have already contacted them and they could not provide a fix. So I believe that it might be a problem with windows limiting power to the CPU for some reason after sleep, regular shutdown, and restarts via the start menu.
    The current version of windows I am on is 2004 or the may update.
    AbelFlores2, Jan 12, 2021
  4. How to fix my base speed and speed stuck at 0.79 GHZ
    So far I have tried everything possible to make the CPU go over .79 GHZ. The CPU that I have is an i5-9300H and has been working we for the past few months until today. Please help, I cannot get anything done.
  1. How to fix my base speed and speed stuck at 0.79 GHZ - Similar Threads - fix base speed
  2. My laptop performance is so low CPU speed is 0.38 GHz while base speed is 2.90 GHz
    My laptop performance is so low CPU speed is 0.38 GHz while base speed is 2.90 GHz: I recently took my laptop to a service center to change my screen since I had problems with it, after getting it back I noticed my laptop performance is very slow it takes a lot of time to boot up and every action I take in any application is so slow to load. The cpu and gpu...
  3. CPU ghz stuck at base speed 1.19ghz
    CPU ghz stuck at base speed 1.19ghz: Specifications of laptop: HP Pavilion 14-ce3007ne not the gaming laptopCPU: i5-1035G1 Base Speed: 1.19ghz Max speed: 3.6ghzGPU: Geforce MX130RAM: 8GB DDR4 2667MHzProblem: In november 2022 I used to play gta online and minecraft alot and there was no issue with fps or anything...
  4. CPU ghz stuck at base speed 1.19ghz
  5. CPU ghz stuck at base speed 1.19ghz
  6. Cpu Ghz stuck at 1.08 ghz 1.19ghz base speed
    Cpu Ghz stuck at 1.08 ghz 1.19ghz base speed: Specifications of laptop: HP Pavilion 14-ce3007ne not the gaming laptopCPU: i51035G1 Base Speed: 1.19ghz Max speed: 3.6ghzGPU: Geforce MX130RAM: 8GB DDR4 2667MHzProblem: In november 2022 I used to play gta online and minecraft alot and there was no issue with fps or anything...
  7. Cpu Ghz stuck at 1.08 ghz 1.19ghz base speed
  8. Cpu Ghz stuck at 1.08 ghz 1.19ghz base speed
  9. CPU speed stuck to .79 GHZ
    CPU speed stuck to .79 GHZ: So far I have tried everything possible to make the CPU go over .79 GHZ. The CPU that I have is an i5-9300H and has been working we for the past few months until today. Please help, I cannot get anything done....
  10. My cpu base speed stuck at 0,8 GHz
    My cpu base speed stuck at 0,8 GHz: Hello people, My cpu base speed is stuck at 0,8 GHz, otherwise my CPU is doing well. The only problem is that i now cant update window because the cpu is lower than 1GHz. Window require a CPU that is higher then at least 1 GHz. I have a Intel core i7 -4790K. [ATTACH][ATTACH]...
  1. nu vot
