Windows 10: How to fix random low power warning and hibernation when plugged in at full battery?
Discus and support How to fix random low power warning and hibernation when plugged in at full battery? in Windows 10 BSOD Crashes and Debugging to solve the problem; My laptop is running windows 10. Recently it has started randomly going into hibernate mode without warning. For a couple of frames before it does it... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by redfearnben, Nov 21, 2021.
  1. How to fix random low power warning and hibernation when plugged in at full battery?
    My laptop is running windows 10. Recently it has started randomly going into hibernate mode without warning. For a couple of frames before it does it pops up a message warning low power, despite being plugged in at full battery. I have since updated my windows and drivers but without any luck. Is this a known issue?
  2. Pavan_N Win User
    WIndows 10 v1607 - no low battery warning
    Hi Ujjawal,
    Follow the steps below and check If you are able to get low battery notification.
    Change Critical & Low Level Battery Action.
    • To change the Critical and Low Level action for the battery for any Power Plan, you will have to open
      Power Options in the Control Panel > Change Plan Settings >
      Change Advanced Power Settings. In the box which opens, navigate down to the last item, i.e.
      Battery.
    • Here for each plan, you can configure and set WHAT your Windows should do, after its battery level drops below certain levels. The options for “while On Battery and “while Plugged In” are:
    • Low battery action: Do nothing, Sleep, Hibernate, Shutdown
    • Critical battery action: Sleep, Hibernate, Shutdown
    • The default for the first is Do nothing and for the second one is
      Hibernate. You can change it to suit your requirements.
    Do let us know the status. Thank you.
    Pavan_N, Nov 21, 2021
  3. WIndows 10 v1607 - no low battery warning
    Hi Pavan_N,
    Thanks for your response.
    I have the proper settings for all the above scenarios. But still I am facing problems. Sometimes I get notification that I battery is low(at 7%) and other times the laptop suddenly goes into hibernate because the battery was finished. As it didn't warn
    me, I didn't plug it in the power source. So, this is where my main concern is, the laptop sometimes suddenly goes into hibernate mode without giving a low battery warning.
    Ujjawal GK, Nov 21, 2021
  4. How to fix random low power warning and hibernation when plugged in at full battery?
    Warning: battery is low; plug the computer in.
    My Windows 10 desktop PC today 7/26/18 decided to display a warning continuously that the battery is low and to plug the computer in. I shut it down and changed the plug from UPS to a power bar which my printers which are on are plugged into. Still get
    the warning message. The battery icon in the system tray shows 6%. It always used to say 100%. I went to Cortana and typed troubleshoot, enter and followed the instruction to troubleshoot hardware. and devices Nothing was found.
    Richard_383, Nov 21, 2021
  1. How to fix random low power warning and hibernation when plugged in at full battery? - Similar Threads - fix random low
  2. Battery is Low Warning: Please Plug in your Charger
    Battery is Low Warning: Please Plug in your Charger: Hi,I have had this problem on my laptop for a week now, I even Disabled the Battery Notifications in the Power Plan Settings.I even Disabled Notifications in the Windows Settings.What do I do? This Battery is Low Notification is Popping up even though my Battery is at 67% and...
  3. Battery is Low Warning: Please Plug in your Charger
    How to fix random low power warning and hibernation when plugged in at full battery?: My laptop is running windows 10. Recently it has started randomly going into hibernate mode without warning. For a couple of frames before it does it pops up a message warning low power, despite being plugged in at full battery. I have since updated my windows and drivers but...
  5. How to fix random low power warning and hibernation when plugged in at full battery?
  6. Low Battery Warning minimizes any full screen application
    Low Battery Warning minimizes any full screen application: I don't know if this is the right subreddit to put this question on, but its getting kind of annoying already, not just games but any maximized app. Is there any fix for this? I dont know if i would put this in the mildly infuriating subreddit lol. submitted by /u/SemiEmmy...
  7. No low battery warnings
    No low battery warnings: I don't recall when this problem started exactly, but perhaps about a month ago, after an update. I'm using Windows 10 My laptop used to give me warnings pop up and sound when my battery level was down to 20 and 10 percent. It recently stopped doing that and only shows a...
  8. useless low battery power warning
    useless low battery power warning: My HP Laptop PC gives me just a two second warning before shutting down the computer. Is there a setting somewhere that can allow me sufficient time to shut it down manually?...
  9. Low battery warning
    Low battery warning: My laptop doesn't warn me when the battery level gets to a critically low status. Where do I fix this problem? https://answers.microsoft.com/en-us/windows/forum/all/low-battery-warning/2b0d75fe-540b-4e49-b07e-e71efabecbb1
  10. Warning: battery is low; plug the computer in.
    Warning: battery is low; plug the computer in.: My Windows 10 desktop PC today 7/26/18 decided to display a warning continuously that the battery is low and to plug the computer in. I shut it down and changed the plug from UPS to a power bar which my printers which are on are plugged into. Still get the warning message....
