Windows 10: how to fix virtual audio cable i'm using VB-Audio Virtual Audio Cable marking Input as an...
Discus and support how to fix virtual audio cable i'm using VB-Audio Virtual Audio Cable marking Input as an... in Windows 10 Gaming to solve the problem; I'm on a HP Windows 11, and when i installed a Virtual Audio Cable to add audio from an application, to discord, i installed the driver, and restarted,... Discussion in 'Windows 10 Gaming' started by Matthew Skees, Dec 26, 2023.
how to fix virtual audio cable i'm using VB-Audio Virtual Audio Cable marking Input as an... - Similar Threads - fix virtual audio
in Windows 10 Software and Appshow to fix virtual audio cable i'm using VB-Audio Virtual Audio Cable marking Input as an...: I'm on a HP Windows 11, and when i installed a Virtual Audio Cable to add audio from an application, to discord, i installed the driver, and restarted, like it asked, and it had marked the Input for the virtual cable as an Output, and the Input was marked as Output, how do i... -
Virtual audio output for windows
in Windows 10 Ask InsiderVirtual audio output for windows: So I have this problem. I would like to quickly switch between my speakers and my headphones in two apps simultaneously (discord, and voicemod). The problem is that I can't use default audio output because, one - voicemod doesn't allow setting output neither input to system... -
Audio Cable issue
in Windows 10 BSOD Crashes and DebuggingAudio Cable issue: So i unplugged the green audio cord on the back of my computer and when i did the audio jack in the front of my pc does not work. It would only work when i plugged it into the monitor. It now does not work with either even when i plugged it in every way i could try and... -
Where to post about an audio/audio cable question? Possibly here?
in Windows 10 Drivers and HardwareWhere to post about an audio/audio cable question? Possibly here?: I have a receiver that has RCA type connectors for 5.1, is there a way to connect the three 3.5mm surround sound connections (side,read and C/Sub) from a soundcard to this setup? Example of receiver connections I have:https://www.the-home-cinema-guide.co...ctions-960.jpg... -
Audio input says cable not plugged in.
in Windows 10 Drivers and HardwareAudio input says cable not plugged in.: I have 2 side by side Dell 9020 SFF computers with i7 4770 and 16 GB memory. Both have SSD drives. Both have WIN 10 Pro. I have a 12" M-M 3.5mm stereo cable from the output of one 9020 to the input of the other using the rear jacks. I keep getting cable not plugged in... -
Dont have audio with hdmi cable
in Windows 10 CustomizationDont have audio with hdmi cable: Yesterday I updated windows to 2004, and now I don't have any audio with my tv, I already tried to download new drivers and it didn't worked, on the version 1909, my tv was showing up in the sound control panel, an now I only have the Realtek, NVidia, and headset showing up... -
Virtual (VB Cable) audio issue - kind of :)
in Windows 10 Drivers and HardwareVirtual (VB Cable) audio issue - kind of :): Hi there Hoping someone can help me with this problem. So, I am streaming music to a server and everything is fine from that perspective, high quality, excellent, BUT I am unable to hear the music live from my laptop output (with ear buds) I can only hear via another device... -
disabling speakers ,virtual cable use & hearing audio from PC Speakers
in Windows 10 Drivers and Hardwaredisabling speakers ,virtual cable use & hearing audio from PC Speakers: I have software that requires the use of a Virtual Cable, in order to get the sound from the Internet source into this software I must disable the PC speakers and enable the Virtual Cable IN ,under Windows 10 user interface PLAYBACK audio setup . . . this puts the audio from... -
Need a PC Audio expert! OBS/Input Jacks/VB Cable?
in Windows 10 SupportNeed a PC Audio expert! OBS/Input Jacks/VB Cable?: Okay, I don't post on forums much, because I'm usually pretty good at researching through the inter-web, however I'm at a loss for wits with this problem, so I'll get right to the point. I use OBS, Open Broadcaster Software, a lot and would love to have my viewers hear...
