Windows 10: HP X0Q77ES#ABU Wont power up but charging LED lights up and fan twitches.
Discus and support HP X0Q77ES#ABU Wont power up but charging LED lights up and fan twitches. in Windows 10 BSOD Crashes and Debugging to solve the problem; Hi, i recently was given a non starting HP HP X0Q77ES#ABU with an i7 processor and <300Gb SSD not sure on size as no-one could remember Ive tried many... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by reecehoskins, May 31, 2021.
HP X0Q77ES#ABU Wont power up but charging LED lights up and fan twitches. - Similar Threads - X0Q77ES#ABU Wont power
My hp laptop doesn't boot up but power button light is on
in Windows 10 Software and AppsMy hp laptop doesn't boot up but power button light is on: My hp laptop screen kept going black randomly. Sometimes it showed lines and now when I try to boot it up, it is completely blank. My laptop also has battery issues. I can't use it with plugging it... -
in Windows 10 GamingMy hp laptop doesn't boot up but power button light is on: My hp laptop screen kept going black randomly. Sometimes it showed lines and now when I try to boot it up, it is completely blank. My laptop also has battery issues. I can't use it with plugging it... -
My battery is charging but the charging led light shows a red light even though its...
in Windows 10 Software and AppsMy battery is charging but the charging led light shows a red light even though its...: When I had first got this laptop, every time I charged it, it would show a blue light but now its showing red? It's still able to charge but is this bad? How do I fix this problem?... -
HP Pavilion 15 gaming laptop power LED lights up for a few seconds but laptop won't turn on
in Windows 10 GamingHP Pavilion 15 gaming laptop power LED lights up for a few seconds but laptop won't turn on: Hello.My laptop was working perfectly the night before. This morning, it just won't turn on.Everytime I press the power button, its LED lights up for about 5 seconds and turns off. The laptop itself doesn't come on no fans, screen stays black, keyboard backlight stays off,... -
in Windows 10 Software and AppsHP Pavilion 15 gaming laptop power LED lights up for a few seconds but laptop won't turn on: Hello.My laptop was working perfectly the night before. This morning, it just won't turn on.Everytime I press the power button, its LED lights up for about 5 seconds and turns off. The laptop itself doesn't come on no fans, screen stays black, keyboard backlight stays off,... -
GL702ZC Black Screen and no fan, but power led is on.
in Windows 10 BSOD Crashes and DebuggingGL702ZC Black Screen and no fan, but power led is on.: I was using my pc yesterday for gaming playing rome 2. The laptop worked fine all day with no issue unitl 10pm then I exit programs and go to start and manually selected shutdown. One hour later,I get power led light up, but the screen is black and fans are not working.... -
Insignia Flex NS-P11W7100-C - not booting up, red charging LED not lighting up
in Windows 10 Drivers and HardwareInsignia Flex NS-P11W7100-C - not booting up, red charging LED not lighting up: My Insignia Flex NS-P11W7100 Microsoft Windows 10 Tablet has 2GB RAM, although its user manual does not mention onboard RAM at all. I was looking through its UEFI BIOS and found a setting to select dual-channel RAM, which I thought would be a common feature in all Microsoft... -
Not entering sleep properly,- fan spin and led lights on.
in Windows 10 SupportNot entering sleep properly,- fan spin and led lights on.: Got an issue, sometimes when entering sleep mode windows and the pc (intel nuc) continue the normal procedure but seems to miss the last step. Instead of turning off the power button led it stays on, also the fan spins. Then the only way to turn it on is to hold in the power... -
Motherboard power light (PS_SW) is flashing and system wont boot up
in Windows 10 Drivers and HardwareMotherboard power light (PS_SW) is flashing and system wont boot up: The problem is in the thread title; normally my PS_SW light stays a solid yellow and I'm able to boot up no problem. After moving my computer around the house a bit, when I plugged everything in the light was flashing yellow and is now unable to boot up. All the build...
