Windows 10: Huge Battery Problem Only running on AC power
Discus and support Huge Battery Problem Only running on AC power in Windows 10 Drivers and Hardware to solve the problem; I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8.... Discussion in 'Windows 10 Drivers and Hardware' started by Mina Tamer, Sep 30, 2023.
Huge Battery Problem Only running on AC power - Similar Threads - Huge Battery Problem
AC power Problem
in Windows 10 GamingAC power Problem: Laptop model = HP Pavilion 14-ce0510nd Standard configuration.OS = Windows 11To get the laptop to charge i first have to shutdown the laptop. Then connect the power plug.If i turn the laptop on it will remain charging or operate on AC.However, when the laptop is running and i... -
AC power Problem
in Windows 10 Software and AppsAC power Problem: Laptop model = HP Pavilion 14-ce0510nd Standard configuration.OS = Windows 11To get the laptop to charge i first have to shutdown the laptop. Then connect the power plug.If i turn the laptop on it will remain charging or operate on AC.However, when the laptop is running and i... -
in Windows 10 GamingHuge Battery Problem Only running on AC power: I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8. One day while I was doing this, the battery suddenly cut off and never worked again Keep in mind the battery is relatively... -
in Windows 10 Software and AppsHuge Battery Problem Only running on AC power: I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8. One day while I was doing this, the battery suddenly cut off and never worked again Keep in mind the battery is relatively... -
How to use AC Power Adapter instead of battery
in Windows 10 Software and AppsHow to use AC Power Adapter instead of battery: Hi,I have the *ASUS TUF F15 2021* I want to use this laptop while using the AC Power Adapter because it performs better than Battery mode while using the battery*So, is there a way to do that without decreasing the battery's lifespan?*... -
Battery not charging only works in AC power even battery is zero
in Windows 10 GamingBattery not charging only works in AC power even battery is zero: My laptop is msi Bravo 15. I know about the msi dragon center's charging modes this is not about that. My laptops battery is not charging . It is initially at 44% when I know about this issue. When I connect the adaptor the laptop doesn't use the battery it automatically use... -
in Windows 10 Software and AppsBattery not charging only works in AC power even battery is zero: My laptop is msi Bravo 15. I know about the msi dragon center's charging modes this is not about that. My laptops battery is not charging . It is initially at 44% when I know about this issue. When I connect the adaptor the laptop doesn't use the battery it automatically use... -
Laptop Only Running on AC Power
in Windows 10 BSOD Crashes and DebuggingLaptop Only Running on AC Power: I have a Toshiba Qosmio X75-A, recently I noticed that it is only running on AC power and not on the battery. The battery reports that it is fully charged. I replaced the battery with a brand new OEM battery and produced the same results. The laptop will not power on... -
running on ac instead of battery
in Windows 10 Customizationrunning on ac instead of battery: I have an HP laptop. How do I run On AC instead of battery? https://answers.microsoft.com/en-us/windows/forum/all/running-on-ac-instead-of-battery/b5edead9-83eb-43a5-97c0-0bc9603d4f40
