Windows 10: i am having a problem in connecting external hard dist. it seems to be the power problem as...
Discus and support i am having a problem in connecting external hard dist. it seems to be the power problem as... in Windows 10 Software and Apps to solve the problem; I am having a problem in connecting external hard dist. it seems to be the power problem as the hard disk power disconnected after few seconds. so,... Discussion in 'Windows 10 Software and Apps' started by Perla Anil Kumar, Jul 19, 2024.
  1. i am having a problem in connecting external hard dist. it seems to be the power problem as...
    I am having a problem in connecting external hard dist. it seems to be the power problem as the hard disk power disconnected after few seconds. so, what would be a perfect solution for this case.
  2. rominmusa Win User
    Problem while connecting external hard disk
    Lenovo-F309-USB3-0-External-Hard is its name and i don't know much about it
    rominmusa, Jul 19, 2024
  3. keakar Win User
    Hvaing Problems with Old External HDD
    its not easy to say without running a diagnostic test to see how it does.
    i would suggest you take the drive out of the external case and hook it up inside your pc and test it that way so you can eliminate the chance it is the external case that is the problem. sometimes the connections inside the external cases can be bad.
    keakar, Jul 19, 2024
  4. NavyLCDR Win User
    What type of external HDD are you trying to connect? Is it a 2.5" laptop style hard drive or a 3.5" desktop style hard drive? All 3.5" desktop hard drives will require an external power source to connect them via USB. Your computer seems to be a newer computer so power at the USB ports should not be a problem for a 2.5" laptop hard drive. You can try a power boosting Y-cable like this:
    USB 2 0 A Female to 2 Dual USB Male Hub Power Adapter Y Splitter Cable Cord SGCC | eBay
    That will split the power draw between two USB ports if you have two USB ports next to each other on the computer.
    Even the Y-cable will not work for a 3.5" hard drive, though, it requires it's own real power supply.
    NavyLCDR, Jul 19, 2024
  1. i am having a problem in connecting external hard dist. it seems to be the power problem as... - Similar Threads - having problem connecting
  2. Problem with External Hard Disks
    Problem with External Hard Disks: A few weeks ago, I sometimes encountered read/write errors with my external hard drives, not just one hard drive, which were connected to my laptop, would like to seek for advice how to resolve it.Environment:HP Envy 16, 12th Gen Intel i7-12700H 2.3GHz, 64GB RAMOS = WIN11...
  3. i am having a problem in connecting external hard dist. it seems to be the power problem as...
    i am having a problem in connecting external hard dist. it seems to be the power problem as...: I am having a problem in connecting external hard dist. it seems to be the power problem as the hard disk power disconnected after few seconds. so, what would be a perfect solution for this case....
  4. the problem seems to be the power button
    the problem seems to be the power button: so my main reason was that my power button stopped working, so there would be a method I would use to force this thing to turn on.first, I would remove the battery for about 10 seconds, before putting it back in, and then plugging in the adapter.this worked for about a month...
  5. the problem seems to be the power button
  6. the problem seems to be the power button
  7. External hard drive problem
    External hard drive problem: I had been using my hard drive for a year and a half and today my laptop suddenly stopped detecting it even when it appears on the Devices under Settings. I tried every trick that's usually given like checking if the drivers were up-to-date if the USB cable was the problem,...
  8. External hard drive problem
    External hard drive problem: I have 2TB seaget hard disk (HD) . As soon as I attach my hard disk to surface go it shows 100% performance in task manager with 0 reading and writing speed. No antivirus is working as I start scanning it, it stays at 0% for long time until it detaches itself. Even the...
  9. Power problem? 8TB external hard drive keeps crashing.
    Power problem? 8TB external hard drive keeps crashing.: Hi guys, A month ago (03/16/2019) I purchased and started to use an 8TB Seagate Desktop external hard drive with my laptop computer (2018 HP Pavilion 15t-cc500 CTO). I had been backing up my data with 2 different 4TB external hard drives before. I use a 4-port USB hub with...
  10. Problem while connecting external hard disk
    Problem while connecting external hard disk: When i connect my hdd ,it sAYSpower DRAWING TOOMUCH and sometimes it doesn't support when i connect other usb no problem is there. Help 56792
