Windows 10: i am having a problem in connecting external hard dist. it seems to be the power problem as...
Discus and support i am having a problem in connecting external hard dist. it seems to be the power problem as... in Windows 10 Gaming to solve the problem; I am having a problem in connecting external hard dist. it seems to be the power problem as the hard disk power disconnected after few seconds. so,... Discussion in 'Windows 10 Gaming' started by Perla Anil Kumar, Jul 19, 2024.
i am having a problem in connecting external hard dist. it seems to be the power problem as... - Similar Threads - having problem connecting
Problem with External Hard Disks
in Windows 10 GamingProblem with External Hard Disks: A few weeks ago, I sometimes encountered read/write errors with my external hard drives, not just one hard drive, which were connected to my laptop, would like to seek for advice how to resolve it.Environment:HP Envy 16, 12th Gen Intel i7-12700H 2.3GHz, 64GB RAMOS = WIN11... -
in Windows 10 Software and Appsi am having a problem in connecting external hard dist. it seems to be the power problem as...: I am having a problem in connecting external hard dist. it seems to be the power problem as the hard disk power disconnected after few seconds. so, what would be a perfect solution for this case.... -
the problem seems to be the power button
in Windows 10 Gamingthe problem seems to be the power button: so my main reason was that my power button stopped working, so there would be a method I would use to force this thing to turn on.first, I would remove the battery for about 10 seconds, before putting it back in, and then plugging in the adapter.this worked for about a month... -
in Windows 10 Software and Appsthe problem seems to be the power button: so my main reason was that my power button stopped working, so there would be a method I would use to force this thing to turn on.first, I would remove the battery for about 10 seconds, before putting it back in, and then plugging in the adapter.this worked for about a month... -
in Windows 10 BSOD Crashes and Debuggingthe problem seems to be the power button: so my main reason was that my power button stopped working, so there would be a method I would use to force this thing to turn on.first, I would remove the battery for about 10 seconds, before putting it back in, and then plugging in the adapter.this worked for about a month... -
External hard drive problem
in Windows 10 Software and AppsExternal hard drive problem: I had been using my hard drive for a year and a half and today my laptop suddenly stopped detecting it even when it appears on the Devices under Settings. I tried every trick that's usually given like checking if the drivers were up-to-date if the USB cable was the problem,... -
in Windows 10 Drivers and HardwareExternal hard drive problem: I have 2TB seaget hard disk (HD) . As soon as I attach my hard disk to surface go it shows 100% performance in task manager with 0 reading and writing speed. No antivirus is working as I start scanning it, it stays at 0% for long time until it detaches itself. Even the... -
Power problem? 8TB external hard drive keeps crashing.
in Windows 10 SupportPower problem? 8TB external hard drive keeps crashing.: Hi guys, A month ago (03/16/2019) I purchased and started to use an 8TB Seagate Desktop external hard drive with my laptop computer (2018 HP Pavilion 15t-cc500 CTO). I had been backing up my data with 2 different 4TB external hard drives before. I use a 4-port USB hub with... -
Problem while connecting external hard disk
in Windows 10 Drivers and HardwareProblem while connecting external hard disk: When i connect my hdd ,it sAYSpower DRAWING TOOMUCH and sometimes it doesn't support when i connect other usb no problem is there. Help 56792
