Windows 10: I have a battery problem. My battery for some reason won't go past 23%. I have kept it for...
Discus and support I have a battery problem. My battery for some reason won't go past 23%. I have kept it for... in Windows 10 Gaming to solve the problem; Alright guys, so you see. I have a battery problem. My battery for some reason won't go past 23%. I have kept it for charging for a long 5-10 hours and... Discussion in 'Windows 10 Gaming' started by Agastya Sharma, Mar 26, 2023.
  1. I have a battery problem. My battery for some reason won't go past 23%. I have kept it for...
    Alright guys, so you see. I have a battery problem. My battery for some reason won't go past 23%. I have kept it for charging for a long 5-10 hours and it won't go ahead than that. It shows the white light near the charging port which usually means the laptop is 100% charged but in this case, its showing the white light when its just on 23%? I have tried updating my drivers and changing my battery settings to default but nothing seems to work. Please help, i need to take my laptop to school but i can't be carrying my laptop charger with me wherever i go considering there isn't a port everywher
  2. Battery Won't Charge Fully
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    I have a battery problem. My battery for some reason won't go past 23%. I have kept it for... pbDp4sx.png
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Mar 26, 2023
  3. Plugged in but battery does not charge
    Step 1
    Step 2
    Step 3
  4. Xylee Del Win User
    Deactivate low battery notification
    Windows 10 may have detected your old battery, the reason why your computer kept of notifying you about the battery life. To help you disable this notification, we suggest that you follow the steps below to turn off the notifications from battery saver:
    (Note: Make sure to unplug your laptop from the power source first before performing the steps below.)
    • Open Settings app.
    • Select System.
    • Click on Notifications & actions tab.
    • Scroll down and look for Battery Saver and turn off the slider.
    Let us know the results.
    Xylee Del, Mar 26, 2023
  1. I have a battery problem. My battery for some reason won't go past 23%. I have kept it for... - Similar Threads - battery problem battery
  2. I have a problem with the battery and i have no clue what is happening.
    I have a problem with the battery and i have no clue what is happening.: The laptop new literally Christmas was yesterday that's when i got it. its pugged in charging, but the stupid battery doesn't move. it just keeps sitting on 58%. Its put on Balance dont know if that changes anything, no energy saver on. idk. i tryed everything if i missed a...
  3. I have a problem with the battery and i have no clue what is happening.
  4. Having problem with battery
    Having problem with battery: Hi everyone, I’m having some trouble with my Dell laptop battery. Around 4-5 months ago, I had to replace the old battery because it wasn’t charging or even powering up the laptop. I had been using it with the charger plugged in all the time. When I took it to a repair shop,...
  5. Having problem with battery
  6. Having problem with battery
  7. Having problem with battery
  8. I have battery on my laptop but it randomly shuts off for no reason.
    I have battery on my laptop but it randomly shuts off for no reason.: I already have 80% battery but the laptop kept shutting off at random and i need to plug my charger in just to activate the laptop again. The moment i unplug, it will take a few mins and it will shut down on its on again....
  9. I have battery on my laptop but it randomly shuts off for no reason.
  10. I have a battery problem. My battery for some reason won't go past 23%. I have kept it for...
    I have a battery problem. My battery for some reason won't go past 23%. I have kept it for...: Alright guys, so you see. I have a battery problem. My battery for some reason won't go past 23%. I have kept it for charging for a long 5-10 hours and it won't go ahead than that. It shows the white light near the charging port which usually means the laptop is 100% charged...
