Windows 10: I have a problem that saysyour pc ran into a problem and needs to restart. We will restart...
Discus and support I have a problem that saysyour pc ran into a problem and needs to restart. We will restart... in Windows 10 Software and Apps to solve the problem; Hello I have problem with my computer as I said it says your pc ran into a problem and needs to restart. We will restart for you how can I solve this... Discussion in 'Windows 10 Software and Apps' started by Zaman03o, Jun 28, 2023.
  1. Zaman03o Win User
    Hello I have problem with my computer as I said it says your pc ran into a problem and needs to restart. We will restart for you how can I solve this problemAnd the stopcode:UNMOUNTABLE BOOT VOLUME
  2. michael Win User
    My PC restarts, What's the problems?
    Hi Team,
    My PC keeps on restarting ,
    System Specs are:-
    Asus P8Z77-V Deluxe
    i7 3770K
    Samsung SSD 256GB
    Corsair CX 430 PSU
    Win 7
    What I have done till now:-
    1.My PC started restarting so what I did, I installed Win7 on 500GB Samsung SATA drive and formatted my SSD , Full Format. and then installed Win7 on SSD, which worked for say, 2 hours or so and then PC again started restarting.
    2. It once also restarted when I was in BIOS.
    3.While rebooting it always asks for "Launch Windows Start up repair"
    4.Yesterday PC stayed ON 20 minutes and then again restarted.
    5.Sometimes it get restarted often while booting and does not even come to login Screen.
    Please suggest, I don't know what's the problem.
    Thanks.
    michael
    michael, Jun 28, 2023
  3. PC ran into problem and needs to restart
    I am continuously getting "PC ran into a problem and needs to restart" issue. I have tried disk checking using "chkdsk" command but got no problem with the disk. what might be the possible reason. please suggest something as I do not want to reset my
    system.
    anamikajain, Jun 28, 2023
  4. I have a problem that saysyour pc ran into a problem and needs to restart. We will restart...
    Your PC ran into a problem and needs restarting
    A stop error (also called a "blue screen" error) can occur if a problem causes your PC to shut down or restart unexpectedly. These errors can be caused by both hardware and software issues.
    For us to better assist you, we'd like to know the following:
    • Confirm which build is currently installed on your device. To check, follow the steps below:
    • Press Windows key + R, then type in winver.
    • Click OK.
    • Would you be able to capture an image or a screenshot of the complete error message that your getting?
    • Were there any software or application you've recently installed?
    Meanwhile, we suggest performing the steps on this article
    on how to troubleshoot blue screen errors on Windows 10.
    Regards.
    Melchizedek Qui, Jun 28, 2023
  1. I have a problem that saysyour pc ran into a problem and needs to restart. We will restart... - Similar Threads - problem saysyour ran
  2. I have a problem that saysyour pc ran into a problem and needs to restart. We will restart...
    I have a problem that saysyour pc ran into a problem and needs to restart. We will restart...: Hello I have problem with my computer as I said it says your pc ran into a problem and needs to restart. We will restart for you how can I solve this problemAnd the stopcode:UNMOUNTABLE BOOT VOLUME...
  3. Pc ran into problems we will restart for you
    Pc ran into problems we will restart for you: Hi there, I recently updated my driver but seems like it was supporting with my computer some how try to update it and ran into blue screen errorpc ran into problem and need restart and we will do it for you , to fix this I rest my pc keeping my personal file on option then...
  4. Pc ran into problems we will restart for you
  5. Pc ran into problems we will restart for you
  6. PC ran into a problem and needs to restart
    PC ran into a problem and needs to restart: My laptop is dual booted and whenever I try into go into windows I get the error that my pc ran into problem and needs to restart but I am able to go into Ubuntu easily. I can't even enter safemode. Whenever I do I get the following error again that your pc ran into...
  7. Windows ran into a problem and needs to restart. we will restart it for you
    Windows ran into a problem and needs to restart. we will restart it for you: so i have 2 windows on my pc 8.1 and 10. 8.1 is working perfectly but the windows 10 have this problem loop Windows ran into a problem and needs to restart. we will restart it for you and when i try to use the windows 10 tools it says it need an adminstrator account ,while...
  8. PC ran into problem and needs to restart
    PC ran into problem and needs to restart: I am continuously getting "PC ran into a problem and needs to restart" issue. I have tried disk checking using "chkdsk" command but got no problem with the disk. what might be the possible reason. please suggest something as I do not want to reset my system....
  9. pc ran into a problem and needs to restart
    pc ran into a problem and needs to restart: i just recently got my pc. i was just using it and all of the sudden the blue screen saying "your pc ran into a problem and needs to restart" and its been stuck on 0% for a few hours now. it doesnt move on or anything its just been frozen on 0%. ive looked up if i can do...
  10. PC ran into a problem and needs to restart
    PC ran into a problem and needs to restart: I had upgraded my Acer Aspire Laptop (CORE i5 - 4GB RAM) from Windows 8.1 to Windows 10 recently. As it was running very slow, I decided to do a 'clean reset'. By mistake, the recovery partition also cleaned. It then went to a blue screen saying "Your PC ran into a problem...
