Windows 10: I need help with this problem if and body had problem can you pls help me fix it pls.
Discus and support I need help with this problem if and body had problem can you pls help me fix it pls. in Windows 10 Gaming to solve the problem; dssswee https://answers.microsoft.com/en-us/windows/forum/all/i-need-help-with-this-problem-if-and-body-had/ef582537-41f2-4489-8bb5-e7877d7170ff Discussion in 'Windows 10 Gaming' started by Christian Gallardo1, Nov 19, 2023.
  1. I need help with this problem if and body had problem can you pls help me fix it pls.
    dssswee
  2. blazen95 Win User
    Radeon 6870 Problem, pls help !
    it seems that the problem is not from the 2 monitors *Frown I need help with this problem if and body had problem can you pls help me fix it pls. :( pls help
    blazen95, Nov 19, 2023
  3. blazen95 Win User
    Hello, i'm the new owner of a MSI Radeon 6870. I'm very happy with it, but i have one problem. In 2D mode the card just won't go with the 2D clocks (100/300), it stais at 300/1050 (gpu/memory). I've changed 2 sets of catalyst drivers and the problem still remains. Any ideeas ?? Pls help !
  4. krivis Win User
    Sapphire Ati x1650 pro 512mb PCIE BIG PROBLEM pls help!!!!!
    Pls people help me.
    I have Sapphire ati x1650 pro 512mb pcie.
    The problem showed up 3 days ago.
    So when the computer is booting the screen is filled with lines yelow blue red bla bla etc. i cant even reinstall windows because i cant read anything. SO when is booting there are lines but when enters in Windows Xp everything is ok, the picture is steady. I know that is the graphic card problem because i updated my motherboard bios and everything is the same. i have two monitors attached and the lines are the same on both. Maybe the bios is messed up.
    Someone pls make bios dump from the original bios and send it to me on pls people.
    Or maybe someone have a fix for this problem...
    THX
    krivis, Nov 19, 2023
  1. I need help with this problem if and body had problem can you pls help me fix it pls. - Similar Threads - need help problem
  2. I got blue screen problem any body help pls
    I got blue screen problem any body help pls: hi i want to ask for help/ so i installed fyde os previously and it contains rEFIND boot manager it allows you to choose which os you want to bootFyde Or Windows, i started my computer and want to use windows so i choose windows and then blue screen with stop code bad system...
  3. I got blue screen problem any body help pls
  4. IT adminstrator problem help me pls
    IT adminstrator problem help me pls: i get this msg on windows 11 i did a reset to everything on my pc including files and apps created a new microsoft acc and get this msg your it adminstrator had limited access to some areas of this app and the item you tried to access in not available contact it helpdesk for...
  5. IT adminstrator problem help me pls
  6. I need help with this problem if and body had problem can you pls help me fix it pls.
    I need help with this problem if and body had problem can you pls help me fix it pls.: dssswee https://answers.microsoft.com/en-us/windows/forum/all/i-need-help-with-this-problem-if-and-body-had/ef582537-41f2-4489-8bb5-e7877d7170ff
  7. Can you pls help me at the topic?
    Can you pls help me at the topic?: https://answers.microsoft.com/en-us/windows/forum/windows_10-performance/pls-help-why-my-cpu-is-like-that-again/5aab43ab-80e2-4fab-b914-e15b6590154dI need help about this discussion, also have screenshot already. Thanks....
  8. Can you pls help me at the topic?
  9. Can you pls help me at the topic?
  10. Help me fix this pls
    Help me fix this pls: I have a good headset for gaming and good audio but say I wanna record a youtube video I click on record with the mic option on. 20 minutes later I'm looking back and my mic audio sound like jack s* can someone help me fix this or is it just like that. submitted by...
