Windows 10: I removed battery because it was low storage. Now, I am running my laptop with ac power...
Discus and support I removed battery because it was low storage. Now, I am running my laptop with ac power... in Windows 10 Gaming to solve the problem; I removed the battery because it was low storage. Now, I am running my laptop with AC power but, my charging light is blinking after a while. why is... Discussion in 'Windows 10 Gaming' started by asif chy, Feb 28, 2025.
  1. asif chy Win User
    I removed the battery because it was low storage. Now, I am running my laptop with AC power but, my charging light is blinking after a while. why is this happening?
  2. laptop battery wont charge after latest update
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    6. Under the Batteries category, right-click all of the Microsoft ACPI Compliant Control Method Battery listings, and select Uninstall (it’s okay if you only have 1).
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    FreeBooter, Feb 28, 2025
  3. MikeMilo Win User
    Laptop Only Running on AC Power
    I have a Toshiba Qosmio X75-A, recently I noticed that it is only running on AC power and not on the battery. The battery reports that it is fully charged. I replaced the battery with a brand new OEM battery and produced the same results. The laptop will
    not power on without being plugged into AC power. If I remove the AC power cord while the laptop is powered on, it immediately shuts off.
    I checked system settings battery usage and found that Windows will only track usage data when it's running on battery power. So I'm thinking it's a hardware issue. Any ideas on how I could check/diagnose and then make a repair? It's long out of warranty.
    Thanks in advance.
    MikeMilo, Feb 28, 2025
  4. I removed battery because it was low storage. Now, I am running my laptop with ac power...
    Battery Won't Charge Fully
    Step 1
    I removed battery because it was low storage. Now, I am running my laptop with ac power... pbDp4sx.png
    Step 2
    Step 3
  1. I removed battery because it was low storage. Now, I am running my laptop with ac power... - Similar Threads - removed battery was
  2. Dell laptop running low storage
    Dell laptop running low storage: There is this Dell Latitude 3190 2 in 1, it is low on memory. It only has 50GB HDD, and I need my CLF IT to do that. The name of the laptop is WFA-STLAP-SEND1....
  3. I removed battery because it was low storage. Now, I am running my laptop with ac power...
    I removed battery because it was low storage. Now, I am running my laptop with ac power...: I removed the battery because it was low storage. Now, I am running my laptop with AC power but, my charging light is blinking after a while. why is this happening?...
  5. i just bought 1TB of storage from microsoft 365 because i was running low, and now my pc...
    i just bought 1TB of storage from microsoft 365 because i was running low, and now my pc...: bought storage and now my pc won’t turn on https://answers.microsoft.com/en-us/windows/forum/all/i-just-bought-1tb-of-storage-from-microsoft-365/f1648e94-8456-4976-82a3-fdb00c66069d
  6. i just bought 1TB of storage from microsoft 365 because i was running low, and now my pc...
  7. Huge Battery Problem Only running on AC power
    Huge Battery Problem Only running on AC power: I have an old “Acer Aspire One” laptop that is extremely small in size 1 GB RAM. I use it to test various versions of windows 2000, XP, vista, 7 and 8. One day while I was doing this, the battery suddenly cut off and never worked again Keep in mind the battery is relatively...
  8. Huge Battery Problem Only running on AC power
  9. Huge Battery Problem Only running on AC power
  10. Laptop Only Running on AC Power
    Laptop Only Running on AC Power: I have a Toshiba Qosmio X75-A, recently I noticed that it is only running on AC power and not on the battery. The battery reports that it is fully charged. I replaced the battery with a brand new OEM battery and produced the same results. The laptop will not power on...
