Windows 10: I'm having audio problems with my headset- Muffled sound and microphone capturing PC sounds
Discus and support I'm having audio problems with my headset- Muffled sound and microphone capturing PC sounds in Windows 10 Ask Insider to solve the problem; A few days ago I bought a new headset (JBL Quantum100) and it works correctly in my notebook. But, when I use in my PC, output audio is muffled and my... Discussion in 'Windows 10 Ask Insider' started by /u/Cruzess, Mar 28, 2021.
I'm having audio problems with my headset- Muffled sound and microphone capturing PC sounds - Similar Threads - I'm having audio
Headset Microphone sounds muffled when used on PC
in Windows 10 GamingHeadset Microphone sounds muffled when used on PC: So my Mic has been having this issue for over a month now where it will sound muffled when trying to use it to talk to people and I don't know what to do. I've tried updating drivers and looking up fixes for the problem but nothing works I am using the Turtle Beach Recon... -
in Windows 10 Software and AppsHeadset Microphone sounds muffled when used on PC: So my Mic has been having this issue for over a month now where it will sound muffled when trying to use it to talk to people and I don't know what to do. I've tried updating drivers and looking up fixes for the problem but nothing works I am using the Turtle Beach Recon... -
My audio started to sound muffled/have bad quality.
in Windows 10 GamingMy audio started to sound muffled/have bad quality.: I turned on my computer this morning, and when I tried to watch a TV show it came out muffled/bad quality. Thing like Spotify, Youtube, and PC games also sound muffled. Audio/Media files that I had downloaded before sounds clear. This has happened once before and went away... -
in Windows 10 Software and AppsMy audio started to sound muffled/have bad quality.: I turned on my computer this morning, and when I tried to watch a TV show it came out muffled/bad quality. Thing like Spotify, Youtube, and PC games also sound muffled. Audio/Media files that I had downloaded before sounds clear. This has happened once before and went away... -
Are new headsets supposed to sound muffled?
in Windows 10 Software and AppsAre new headsets supposed to sound muffled?: All of the new headsets I buy wired or wireless all sound muffled and unclear compared to my old cheaper one. Please help! The audio is unbalanced and I don't know what to do.... -
in Windows 10 GamingAre new headsets supposed to sound muffled?: All of the new headsets I buy wired or wireless all sound muffled and unclear compared to my old cheaper one. Please help! The audio is unbalanced and I don't know what to do.... -
muffled sound on headset
in Windows 10 Gamingmuffled sound on headset: Since some days my headset sounds muffled. Mostly voices are muffled i can hear music just fine. If i don´t plug in the headset all the way, i can hear perfectly fine but then my mic doesn´t work. I have an other headset not as good where everything works perfectly fine. If... -
in Windows 10 Software and Appsmuffled sound on headset: Since some days my headset sounds muffled. Mostly voices are muffled i can hear music just fine. If i don´t plug in the headset all the way, i can hear perfectly fine but then my mic doesn´t work. I have an other headset not as good where everything works perfectly fine. If... -
Headset microphone sounds muffled, quiet, and plays desktop audio through it.
in Windows 10 Drivers and HardwareHeadset microphone sounds muffled, quiet, and plays desktop audio through it.: I have a headset that works fine on another device, but for some reason on my desktop, no matter what port I use, all the audio from the desktop gets played through the microphone and the microphone is really quiet and muffled. The only way you can hear anything from the...
