Windows 10: Is there any possible solution for the reoccurring fan running at max speed problem? Or is...
Discus and support Is there any possible solution for the reoccurring fan running at max speed problem? Or is... in Windows 10 Software and Apps to solve the problem; I've purchased an Asus ZenBook 14 UM433IQ a year ago and I have been encountering some weird issue with my laptop. When I normally use my laptop for a... Discussion in 'Windows 10 Software and Apps' started by radan azamian, May 22, 2023.
  1. Is there any possible solution for the reoccurring fan running at max speed problem? Or is...
    I've purchased an Asus ZenBook 14 UM433IQ a year ago and I have been encountering some weird issue with my laptop. When I normally use my laptop for a while and close the lid or stay AFK with the screen going off, when I reopen the lid or wake the laptop, the fan goes on full blast without stopping anytime soon even after hours of using But when this issue happens, I shut down my laptop and reboot it. Then, the fan stops and works quietly with business as usual. Note: This issue doesn't happen every time, but it appears randomly.to be honest I've waited this long hoping a softw
  2. The CPU is cool but the fan is running at max speed which is very noisy. Is this the HP hardware problem ? Or is it the Window 10 issues ?
    <Original title: Desktop fan control>
    I bought a refurbished HP desktop with Window 10 operating system. The CPU is cool but the fan is running at max speed which is very noisy. Is this the HP hardware problem ? Or is it the Window 10 issues ? How to fix this problem ? Thank you.
    Thanh-Nguyen, May 22, 2023
  3. Intel i3 6100 fan running at max speed for no reason!
    On December 26th, I moved my PC into a new case. For about a week, my CPU fan kept spinning at max speed for no reason and i couldnt change it in the BIOS or anything. I booted up my PC on January 2nd and for some reason, my fan was normal. A week later
    today, after the new update, my CPU fan is back to spinning at 100%. My temps are very low so there's no reason for it to be spinning so fast; any help? running the stock cooler with an MSI H110M Pro-VH motherboard and a GTX 970. CPU usage in task manager
    is pretty low as well.
    Matt28299292, May 22, 2023
  4. Vinodh.V Win User
    W10 CPU fan not boosting to max speed
    Hi Pablo,
    Sorry to hear about the inconvenience caused.
    We would suggest you to update the following items and check the cpu fan speed and performance.
    Check if there is a program to control the fan speed, may be the controller program is not compatible with Windows 10. Also check for the below list and please update it:
    • BIOS.
    • Chipset drivers.
    http://support.lenovo.com/us/en/pro...enovo-y-series-laptops/y50-70-notebook-lenovo
    If you don't find the drivers compatible for Windows 10. refer to the motherboard manufacturer website and check for updated chipset drivers and install it.
    BIOS Disclaimer:
    Modifying BIOS/ complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS
    settings can be solved. Modifications of the settings are at your own risk.
    Hope this information helps, for further assistance please reply.
    Vinodh.V, May 22, 2023
  1. Is there any possible solution for the reoccurring fan running at max speed problem? Or is... - Similar Threads - possible solution reoccurring
  2. Desktop fans run on max speed, the system is windows 11 24H2
    Desktop fans run on max speed, the system is windows 11 24H2: Desktop fans run on max speed, the system is windows 11 24H2, I tried in-place upgrade and tried reinstalling the motherboard control software but nothing helped, it seems it is a windows bug....
  3. Desktop fans run on max speed, the system is windows 11 24H2
  4. PC IS NOT BOOTING AND FANS ARE IN MAX SPEED
    PC IS NOT BOOTING AND FANS ARE IN MAX SPEED: My pc is not booting up and fans are in max speed i triedreseating the cpu and ram but nothing works when i reseat the ram it beeps 5 times. what can be the possible can be the possible cause of this issue and if theres need to replace some parts what parts it is?...
  5. PC IS NOT BOOTING AND FANS ARE IN MAX SPEED
  6. monitor goes black , fans go max speed
    monitor goes black , fans go max speed: Hey guys, so i recently just upgraded from 1 stick of t force ddr 5 ram to two sticks and suddenly like once a day when i load up the computer , about 3-5 min in, no matter what application im on , the screen goes black , application freezes, and pc stays “on” with fans...
  7. PC has no display and fans are speeding up to max
    PC has no display and fans are speeding up to max: I have this PC for 2014 and i still use today 10 days ago my power supply got damaged so we got one today but when i start my pc i notice my power button is not lighting up expect the disk LED. My PC spins to life but no display and i heard all my fans are spining to the...
  8. Is there any possible solution for the reoccurring fan running at max speed problem? Or is...
    Is there any possible solution for the reoccurring fan running at max speed problem? Or is...: I've purchased an Asus ZenBook 14 UM433IQ a year ago and I have been encountering some weird issue with my laptop. When I normally use my laptop for a while and close the lid or stay AFK with the screen going off, when I reopen the lid or wake the laptop, the fan goes on full...
  9. fan is running at full speed
    fan is running at full speed: I have a problem with a fan because it is running at full speed all the time. It is an old problem which I am unable to fix. I think the OS cannot detect the hardware and force the fan to run at full speed. It is Dell Precision T3500, Windows 10, ver. 10.0.17763. I...
  10. Intel i3 6100 fan running at max speed for no reason!
    Intel i3 6100 fan running at max speed for no reason!: On December 26th, I moved my PC into a new case. For about a week, my CPU fan kept spinning at max speed for no reason and i couldnt change it in the BIOS or anything. I booted up my PC on January 2nd and for some reason, my fan was normal. A week later today, after the new...
