Windows 10: Lenovo Edge 71/E72 and E73 Sleep/Power issues
Discus and support Lenovo Edge 71/E72 and E73 Sleep/Power issues in Windows 10 Support to solve the problem; Good Afternoon All, I am a bit lost here and was wondering if anyone has had similar experiences or knows of any fixes. These are work computers... Discussion in 'Windows 10 Support' started by Maximusi, Aug 11, 2016.
Lenovo Edge 71/E72 and E73 Sleep/Power issues - Similar Threads - Lenovo Edge E72
Sleep/Power settings issue
in Windows 10 Software and AppsSleep/Power settings issue: I have a W10 machine running latest updates. I have set power to sleep after 15 minutes, but it shuts down instead of going to sleep. I have tried going through all power & sleep settings to no avail. Possibly a registry setting? Anyone have advice?... -
in Windows 10 CustomizationSleep/Power settings issue: I have a W10 machine running latest updates. I have set power to sleep after 15 minutes, but it shuts down instead of going to sleep. I have tried going through all power & sleep settings to no avail. Possibly a registry setting? Anyone have advice?... -
in Windows 10 GamingSleep/Power settings issue: I have a W10 machine running latest updates. I have set power to sleep after 15 minutes, but it shuts down instead of going to sleep. I have tried going through all power & sleep settings to no avail. Possibly a registry setting? Anyone have advice?... -
Power/Sleep issue
in Windows 10 GamingPower/Sleep issue: I have a Dell HP Pavillion desktop 590 with windows 11. Since I purchased the computer, it has never been able to restart after it goes into sleep mode requiring me to have to completely disconnect it from the outlet wait about 30 seconds then plug it back in before it will... -
Power/Sleep issue
in Windows 10 Software and AppsPower/Sleep issue: I have a Dell HP Pavillion desktop 590 with windows 11. Since I purchased the computer, it has never been able to restart after it goes into sleep mode requiring me to have to completely disconnect it from the outlet wait about 30 seconds then plug it back in before it will... -
Power and sleep issue
in Windows 10 Performance & MaintenancePower and sleep issue: I'm having a frustrating time with explorer.exe crashing when the monitors wake up.After several hours left alone, when I go to 'wake up' the computer, my desktop background are black, the start menu button is missing and the system tray looks all mangled. The only way to get... -
Power/Sleep issues
in Windows 10 Performance & MaintenancePower/Sleep issues: Hi All, My Power/Sleep issues only started up after the October updates started to come in. I've tried everything without success. To me it's just another of the things that have plagued Windows since day 1, updates and past issue fixes put forward only to be replaced with... -
sleep and power issue
in Windows 10 Performance & Maintenancesleep and power issue: I have a Lenovo PC with the latest version of Windows 10 and a HPw17e monitor. Monitor will not wake from sleep. PC is set to sleep after 20 minutes and monitor is set to never sleep but it goes to sleep when PC does. PC will wake just fine but I have to do a hard reboot... -
sleep/power issue
in Windows 10 Performance & Maintenancesleep/power issue: i have an hp laptop that i have set to never turn off, sleep or hibernate when the lid is closed so i can run full av scans at night. however, when i open the laptop up to check the results, the system blinks, then blacks out forcing a reboot. i have set this using advanced...
