Windows 10: Low CPU, Low GPU, Low Temp, Low FPS drops and delayed/sluggish controller input
Discus and support Low CPU, Low GPU, Low Temp, Low FPS drops and delayed/sluggish controller input in Windows 10 Gaming to solve the problem; Hi, I'm currently facing an issue where games suddenly drop to a crawl of sometimes 4-5 fps ... while playing at 60+ fps seconds before. After a couple... Discussion in 'Windows 10 Gaming' started by AlexanderPino, Feb 11, 2021.
  1. Low CPU, Low GPU, Low Temp, Low FPS drops and delayed/sluggish controller input
    Hi, I'm currently facing an issue where games suddenly drop to a crawl of sometimes 4-5 fps ... while playing at 60+ fps seconds before. After a couple of seconds the fps go up again and recent controller input is 'played' as if it got recorded/buffered.
    My system; i9 10900K cpu 10/20, 32GB RAM, 2TB 970 NVME and a highend NVidia graphics card running at 4K. I've got everything updated to their latest version. I dont do overclocking and when I look at all temperatures or cpu/gpu usage everything is low or at moderate levels.
    Nothing special seems to be happening when I'm look at Resource Monitor, Task Manager or Process Explorer. What I do notice is that it only seems te be happening when I'm using a controller Xbox Elite 2 controller. Controls become slow and unresponsive. When I connect my controller to my Xbox One X and use it, nothing seems to be wrong with the controller itself. It has the latest update etc.
    Is there anything you guys can think of that might be causing this issue? I've unpaired the controller several times, but to no avail. Is there anything I can look for?
  2. Seren Win User
    GPU Low fps, high load, low temps
    I'm having issues with my gpu. Videogames suddenly have super low fps compared to what it used to be like a few weeks ago. There's terrilble fps even at the lowest settings: ~20fps.
    Only thing that changed on my system are windows updates. It's version 1903 now.
    Normally I'd get good fps and the temp would rise but not exceed 70C.
    When videogames run the GPU temp stays around 35C as if it's idle but GPU load is 100%. CPU is around 50% during videogames.
    Power saving in bios and windows are disabled.
    System is not being overclocked.
    No parked cores.
    Drivers and windows are the latest update
    Virus/malware free
    Specs:
    Z97P-D3
    i7 4790k @ 4.00GHz
    16gb ram @ 666.5 MHz
    GTX 560 SE
    650W PSU
    Thanks in advance,
    Seren, Feb 11, 2021
  3. mohammad9933, Feb 11, 2021
  4. Low CPU, Low GPU, Low Temp, Low FPS drops and delayed/sluggish controller input
    Good pc but low FPS
    Hi guys , first excuse my english Low CPU, Low GPU, Low Temp, Low FPS drops and delayed/sluggish controller input :)
    I have a good pc :
    CPU : AMD FX-6300
    GPU : Nvidia geforce gtx 1050 ti
    Ram : 8 gb ram
    i have a good ventilation
    And i have low fps
    like in League Of legends i have 70 fps drop to 50 with medium settings , any help ?
    TudorIrinel, Feb 11, 2021
  1. Low CPU, Low GPU, Low Temp, Low FPS drops and delayed/sluggish controller input - Similar Threads - Low CPU Low
  2. Low Fps
    Low Fps: when i play battlefield 3 i get like 100 - 120 and its running very smooth but when i play roblox/minecraft my fps instantly drop to 60 - 70, i tried to optimize my pc for greater performance but it doesnt affect anything. GTX 1050 Ti , Intel core i5-6500 , 4gb ram...
  3. Low fps and cpu and gpu utilisation
    Low fps and cpu and gpu utilisation: I bought a second hand gaming pc with the pecs 3070ti and i7 11700k and I’m experiencing low fps and low cpu and gpu utilisation. I’ve tried organising my power plan and many other options I’ve been recommended but still no difference. For example it says I should be able to...
  4. Low fps and cpu and gpu utilisation
  5. low cpu and gpu usage causing fps drops
    low cpu and gpu usage causing fps drops: i have a hp omen gaming laptop with i7-10875h and rtx 3070. my laptop run pretty smooth while gaming and had my gpu usage was 98% and rare fps drop before but now both my cpu and gpu usage fluctuates a lot, and rarely hit above 70%. i have tried a lot of things but no...
  6. low cpu and gpu usage causing fps drops
  7. High GPU but low FPS
    High GPU but low FPS: Hello. Very generally, my issue is that I used to be able to run certain programs and games easily with my GPU, but in the past few months, I've been seeing heavy performance drops. My GPU is at 100% most of the time, my NVIDIA settings are tuned for performance, and as far...
  8. Low FPS/GPU
    Low FPS/GPU: I got this Gaming Laptop that is a ASUS - ROG Strix G15 15.6" Gaming Laptop - Intel Core i7 - 8GB Memory - NVIDIA GeForce GTX 1650 Ti - 512GB SSD - Electro Punk I got it around August and wasn't playing it for games, mostly just for school. Later on i had started playing...
  9. Help needed with Low CPU usage and Low FPS
    Help needed with Low CPU usage and Low FPS: Since the last week i started getting low fps in ALL games all of a sudden and i tracked the culprit to be my CPU's low utilization which for some reason is now very low despite it working completely fine past week.I have tried reinstalling windows 10, it worked fine for a...
  10. GPU Low fps, high load, low temps
    in Windows 10 Graphic Cards
    GPU Low fps, high load, low temps: Hello, I'm having issues with my gpu. Videogames suddenly have super low fps compared to what it used to be like a few weeks ago. There's terrilble fps even at the lowest settings: ~20fps. Only thing that changed on my system are windows updates. It's version 1903 now....
