Windows 10: Microphone sound quality drops
Discus and support Microphone sound quality drops in Windows 10 Software and Apps to solve the problem; So this problem started a week ago when my microphone hyperx quadcast sound quality dropped. Before I fixed it through the control panel, device... Discussion in 'Windows 10 Software and Apps' started by Karanvir Dulku, Oct 7, 2024.
  1. Microphone sound quality drops
    So this problem started a week ago when my microphone hyperx quadcast sound quality dropped. Before I fixed it through the control panel, device manager, and anything to do with sound or devices. When I tried to do the same it didn't fix it at all. I have it plugged into my laptop so I'm not sure why it would differ from my PC because it works fine on there but on the computer completely 180. I'm just not sure what to try now. I've looked at videos that all had the same stuff but nothing worked.
  2. Smittychat., Oct 7, 2024
  3. Microphone Sound Quality
    Hi I'm Peter an independent advisor, you could try the following:
    Step 1 - Run the troubleshooter
    a) Press Windows and X key together and select Control Panel.
    b) Click on Troubleshooting.
    c) Click onView all option on the left side of the Windows.
    d) Click on Playing Audio option.
    e) Click on Next and follow the onscreen instructions to troubleshoot the issue.
    Step 2 - Check your microphone’s drivers
    1. Type in “Device Manager” in the Search box and select it from the list.
    2. Expand Sound, video and game controllers
    3. Right-click (or tap and hold) your microphone device and select Update Driver Software.
    4. Select Search automatically for updated driver software. This option will scan the Internet for the correct version of the driver or determine if you already have the most recent driver installed. You may be prompted to restart your computer to install the
    driver.
    Step 3 - Manually turn up the mic gain
    1. Type in “Sound” in the Search box and select Sound (Control Panel) from the list.
    2. Select the Recording tab.
    3. Right-click (or tap and hold) on the active microphone input device and select Properties.
    4. Select the Levels tab.
    Manually drag the Microphone gain to a higher level and click Apply.
    PeterFlynn4, Oct 7, 2024
  4. Microphone sound quality drops
    Bad Microphone Quality after turning on Audio Enhancements
    There are a few things you can try to improve the microphone quality while keeping Audio Enhancements on. Here are some suggestions:
    1. Configure your input device settings: You can adjust the input volume and change the format quality to see if it improves the microphone quality. To do this, go to Settings > Sound and scroll down to the Input section. Adjust the input volume, change the format quality, and test your microphone.
    2. Update your audio drivers: Outdated drivers can sometimes cause problems, so make sure your audio drivers are up-to-date .
    3. Use a noise reduction feature: If you’re dealing with background noise, try using a noise reduction feature to eliminate microphone background noise .
    4. Use a dedicated microphone or headset: Many laptops have low-quality built-in microphones. Try plugging in a dedicated microphone or headset into your PC.
    I hope these suggestions help you improve the microphone quality while keeping Audio Enhancements on! Let me know if you have any further questions or concerns.
    Cristiana
    Cristiana_C, Oct 7, 2024
  1. Microphone sound quality drops - Similar Threads - Microphone sound quality
  2. Microphone sound quality drops
    Microphone sound quality drops: So this problem started a week ago when my microphone hyperx quadcast sound quality dropped. Before I fixed it through the control panel, device manager, and anything to do with sound or devices. When I tried to do the same it didn't fix it at all. I have it plugged into my...
  3. output sound quality drops drastically when activating microphone
    output sound quality drops drastically when activating microphone: when ever i use my microphone my input quality is normal but when ever someone speaks or any sound is played the quality that i hear is terrible can someone please tell me how to get rid of this problem ?...
  4. output sound quality drops drastically when activating microphone
  5. Audio quality drops when using microphone
    Audio quality drops when using microphone: Whenever I join a discord call, the audio quality of my headphones that are really good drop down to absolutely horrible audio quality.I know about the bluetooth device having stereo and hands free mode but after i switched back to wired earphones and headset, the audio still...
  6. Audio quality drops when using microphone
  7. Audio quality drops when using microphone
    Audio quality drops when using microphone: Whenever I join a discord call, the audio quality of my headphones that are really good drop down to absolutely horrible audio quality. https://answers.microsoft.com/en-us/windows/forum/all/audio-quality-drops-when-using-microphone/ccfe3493-031f-4480-8abc-b4f212a9554f
  8. Audio quality drops when using microphone
  9. Sound quality drop when microphone is activated
    Sound quality drop when microphone is activated: Hi team, I'm facing an issue with a bluetooth headset Jabra Evolve2 85. This device is correctly paired with windows thanks to a bluetooth dongle. Both microphona and headset are recognized. When i'm playing sound with any app a web browser, an offline music player, a music...
  10. Microphone Sound Quality
    Microphone Sound Quality: Hi, how do you make your microphone quality sound better? With that unknown noise like scratch sound or whatever. Because I am having bad mic quality in my headset. Help, please. Thank you...
