Windows 10: More sound not vissible , sound not clarity,low sound
Discus and support More sound not vissible , sound not clarity,low sound in Windows 10 Drivers and Hardware to solve the problem; Low sound visible to laptop , The sound sysytem is low... Discussion in 'Windows 10 Drivers and Hardware' started by VADDE AKSHAY KUMAR, May 1, 2025.
  1. More sound not vissible , sound not clarity,low sound
  2. fireberd Win User
    Sound Quality
    One thing that sticks out from looking at your "My Computer" specs. You list "ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)" which suggests you do not have the correct sound hardware driver. Your motherboard has Realtek sound and the first step is to install the Realtek sound drivers. My ASUS also came with Sonic Studio 2 which is a sound enhancement package. Check the ASUS install disc to see if you have something similar.
    May not be a speaker problem.
    fireberd, May 1, 2025
  3. sound
    Thank you for posting the query on Microsoft Community.
    As per the description I understand that you are unable to hear the email notification sound.
    I suggest you to try the following steps and check if it helps:
    • Go to Control Panel Items
    • Click on Sound.
    • Click on Sounds Tab.
    • Click on Desktop Mail Notification.
    • Click TEST.
    • Click OK.
    And check if you are able to hear the email notification sound.
    Please let us know if you need further assistance.
    Divya Murugan, May 1, 2025
  4. Tibbies=4 Win User
    Sound low
    The sound is very low - Have recently connected my computer to a Dell monitor with a sound bar. Sound is very low although it worked perfectly with a Dell computer.
    Tibbies=4, May 1, 2025
  1. More sound not vissible , sound not clarity,low sound - Similar Threads - More sound vissible
  2. More sound not vissible , sound not clarity,low sound
    More sound not vissible , sound not clarity,low sound: Low sound visible to laptop , The sound sysytem is low https://answers.microsoft.com/en-us/windows/forum/all/more-sound-not-vissible-sound-not-claritylow-sound/58327d30-e4fa-4e1c-bf45-73850152d317
  3. More sound not vissible , sound not clarity,low sound
  4. Sound is very low
    Sound is very low: I have recently formatted my pc with official latest ISO in Windows's website. Ever since the format my computer has been very quiet especially in Valorant, I maximize all the sound but even footsteps are very quiet. Google chrome, spotify, netflix and everything has very low...
  5. Sound is too low
    Sound is too low: I upgraded my laptop to windows 11 and my audio drivers are up to date. the sound is at 100 but its very low... Help Ican hardly distinguish the sounds! https://answers.microsoft.com/en-us/windows/forum/all/sound-is-too-low/3c950915-e7e1-4adf-aee8-91a1dcc3bd95
  6. Sound is too low
  7. No more sound
    No more sound: I use an Acer laptop, and after the feature update, it will not play any sounds without speakers or earphones. Where can I get a new sound driver? (I think I was called "Realtek")....
  8. Sound low
    Sound low: The sound is very low - Have recently connected my computer to a Dell monitor with a sound bar. Sound is very low although it worked perfectly with a Dell computer....
  9. Low sound volume?
    Low sound volume?: Since updating my wife's and my Sister-N-Law's laptops to the April update And the CU the volume on their laptops is low even though the volume is set to 100. Is this a known problem and is there a fix? I have tried deleting and reinstalling the sound card drivers. My wife's...
  10. Low sound volume
    Low sound volume: Since going from Win8 to Win10 tech preview I have had to increase my volume a lot more than before to hear anything. Has anyone else had sound volume issues with Win10? thanks 3965
