Windows 10: MSI GF63Thin 11SC, I am Facing some blur issue in some particular parts please help me with...
Discus and support MSI GF63Thin 11SC, I am Facing some blur issue in some particular parts please help me with... in Windows 10 Gaming to solve the problem; I am Facing some blur issue in some particular parts please help me with this........... Discussion in 'Windows 10 Gaming' started by Biplob Paul, Mar 8, 2024.
  1. MSI GF63Thin 11SC, I am Facing some blur issue in some particular parts please help me with...
  2. Persistent Blurring Issue on Windows 11 with High-Resolution Display
    I'm encountering a challenging issue on my Windows 11 system that I hope to get some insights on. My system exhibits a persistent blurring effect around windows or applications when they are not in active use. This problem is notably pronounced with certain applications like Visual Studio Code and the OBS stream chat. The issue seems to be system-wide and independent of the application in use.
    System Specifications:
    • Operating System: Windows 11
    • Display: High-resolution (2560x1440) on a 32-inch monitor
    • Display 2: 1080x1920 (Vertical) 27 inch monitor.
    Symptoms:
    • Blurring effect around inactive windows or parts of the screen, affecting multiple applications.
    Troubleshooting Steps Taken:
    • Updated all graphics and system drivers.
    • Adjusted High DPI scaling settings and experimented with custom scale settings in Windows.
    • Reinstalled affected applications.
    • Attempted various display and system settings adjustments, including changing resolution, scaling, and refresh rate settings.
    Temporary Resolution Attempt:
    • Changing the monitor setting from "Auto" to "Wide" provided temporary relief, but the issue later reoccurred.
    Additional Context:
    • The blurring seems to activate when focus shifts away from a window or application.
    • Standard display setting adjustments and driver updates have not resolved the issue.
    Despite these efforts, the issue persists and is impacting my workflow significantly. I would greatly appreciate any insights, suggestions, or guidance on further troubleshooting steps. Has anyone else experienced something similar or can offer advice on resolving this?
    Thank you in advance for your time and assistance.
    MSI GF63Thin 11SC, I am Facing some blur issue in some particular parts please help me with... SgewtDp2pw1zCqAeDL3ps6mokttNV3lDgOjW6gTChxatQFxbZkbB6Ss%2bRE3hALl8kJBAg36hHnjPmSww1S6cCU0Vbzw%3d.png
    nicklasjespersen, Mar 8, 2024
  3. Edge Search Does Not Permit Change of Region
    Step 1:
    Step 2:
    1. Go to Settings.
    5. Click on Finish.
    Step 3:
    hurricane51, Mar 8, 2024
  4. Jessen P Win User
    Some parts of facebook displays non english
    Hi Judy,
    Thank you for being part of Microsoft Community.
    • Does the issue persist with a particular website?
    • Which browser do you use to access websites, is the issue specific to a particular browser?
    If the issue is with a particular website, then I would request you to add the website in compatibility and then check if it displays properly.
    Perform the steps mentioned below if you use Internet Explorer.
    a: Open Internet Explorer.
    b: Then click Alt and then press Tools.
    c: Then click compatibility view settings and then add that website.
    Please revert if you face any issues with Windows in future.
    Jessen P, Mar 8, 2024
  1. MSI GF63Thin 11SC, I am Facing some blur issue in some particular parts please help me with... - Similar Threads - MSI GF63Thin 11SC
  2. MSI GF63Thin 11SC, I am Facing some blur issue in some particular parts please help me with...
    MSI GF63Thin 11SC, I am Facing some blur issue in some particular parts please help me with...: I am Facing some blur issue in some particular parts please help me with this........ https://answers.microsoft.com/en-us/windows/forum/all/msi-gf63thin-11sc-i-am-facing-some-blur-issue-in/d327c542-0bd8-4aeb-956f-3a5259b9b269
  3. MSI GF63Thin 11SC, I am Facing some blur issue in some particular parts please help me with...
  4. Help please I am got a issues in MSI Afterclock
    Help please I am got a issues in MSI Afterclock: Hi! My laptop is pro but i have low fps while playing. Then I installed MSI Afterburner yesterday from I asked this question in microsoft community. But I have an issues in MSI Afterburner. The issues its i can't drag any row in the overclocking area. Please help me!Sorry, I...
  5. Some programs are blurred
    Some programs are blurred: > starting in compatibility mode helps, but half of the functionality is lost> reinstall GPU driver does not help> on/off ClearType does not help> Advanced scaling settings are not available in Windows 11...
  6. Some issues in font faces
    Some issues in font faces: So I recently downloaded a Segoe Emoji UI font faceThe problem is it has two facesOne is the originaland one is the new oneBoth are showing up as regularI have selected the one with the changeIt is showing in the Win Key + . combo but in some web apps or apps like discord ,...
  7. Some issues in font faces
  8. I am facing BSOD. please help me.
    I am facing BSOD. please help me.: here is the link to the dmp file https://1drv.ms/u/s!Akx9yvsgSBQkzkr72RbrRZyVYa2F https://answers.microsoft.com/en-us/windows/forum/all/i-am-facing-bsod-please-help-me/9f52f14f-95c6-4da9-b41b-bdc597759939
  9. Some of the problems in Windows 10 i face, please help!
    Some of the problems in Windows 10 i face, please help!: i have laptop dell inspiron 11 3147 i upgrade my windows 10 from the year 2015 to 2019 version 1903 (OS build 18362.418) windows 10 home when i do that i have some trouble with some driver i didn't find any solution for these problems i have installed again and again...
  10. Blur in some windows apps and programs ... Please help
    Blur in some windows apps and programs ... Please help: Hi everyone ...I have a problem with some windows apps like messenger facebook and Instagram and some programs like google chrome (But it has been fixed) which are the programs shows blurry text and images (But the images in Instagram are clear)...And this is different from...
