Windows 10: My audio output device shows in Device Manage but not in System/Sound or in Control Panel...
Discus and support My audio output device shows in Device Manage but not in System/Sound or in Control Panel... in Windows 10 Software and Apps to solve the problem; How do I troubleshoot this?... Discussion in 'Windows 10 Software and Apps' started by Keith Bradley1, Aug 18, 2023.
  1. My audio output device shows in Device Manage but not in System/Sound or in Control Panel...
  2. paulpv Win User
    Disabling Audio input/output (Microphone/Speaker/etc) in Device Manager does not disable device in Sound Control Panel or stop audio...oh my!
    In Windows 10 (1803 build 17134.228), I open both "Device Manager" (devmgmt.msc) and the "Sound Control Panel" (mmsys.cpl).
    Both Device Manager and the Sound Control Panel show the same audio input/output devices.
    ex: "Speakers" and "Microphone".
    This is good!
    In Device Manager, I disable "Speakers", which continues to show up and has an icon showing it is disabled.
    In Sound Control Panel, "Speakers" still shows up and *is not disabled*!
    When I play a sound through the [disabled in Device Manager] Speakers, I can still hear the audio!
    This is horrible!
    In Device Manager, I re-enable "Speakers".
    In Sound Control Panel, I disable "Speakers".
    In Device Manager, "Speakers" disappears as an Audio output device.
    Audio correctly cannot be heard.
    This is good!
    In summary:
    1. Why does disabling "Speakers" in "Device Manager" not stop audio coming out of them?
    2. What does disabling "Speakers" in "Device Manager" actually do?
    3. Why is disabling Speakers in Device Manager different than disabling Speakers in Sound Control Panel?
    Now for the real meat: I am trying to disable/enable the Audio input/output device...
    ...the way that the Sound Control Panel does...
    ...but programmatically (PowerShell, C#, C...whatever works).
    There are many of examples of how to disable/enable a device that involve "devcon.exe disable/enable", "Get-PnpDevice | Disable/Enable-PnpDevice", and "Get-Device | Disable/Enable-Device".
    All of these result in the device being disabled in the Device Manager, and exhibiting the above undesirable behavior; the audio devices still show up in Sound Control Panel and are usable. My audio output device shows in Device Manage but not in System/Sound or in Control Panel... :(
    I also have tried the Registry hack (HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\MMDevices\Audio\Capture\{GUID} DeviceState=1 or 10000001), but that seems to be a cosmetic hack only and doesn't actually force close any open devices or prevent new opens.
    So I'll add another question:
    1. How can I programmatically disable/enable and audio device to have the same effect as doing it in Sound Control Panel?
    And no; UI automation of the Sound Control Panel is not an acceptable answer.
    I am looking for an actual API that can be called in the background, not a horrible UI hack that requires being in the foreground.
    Thanks!
    Pv
    paulpv, Aug 18, 2023
  3. spapakons Win User
    No audio device found but there is in Control Panel
    I have a strange issue at my main system (see my specs). The taskbar icon for sound is the speaker with the red X and it reports that no input or output audio device is found. Running the troubleshooter finds no problems. In Device Manager the sound card and all audio inputs/outputs are there without any exclamation mark. What is going on? How can I make the sound card work again? I tried to restart the Windows Audio service, nothing changed. I even tried to reinstall the Realtek HD audio driver, nothing changed. Any ideas about this weird issue?
    Thank you in advance.
    My audio output device shows in Device Manage but not in System/Sound or in Control Panel... 336187d1622967188t-no-audio-device-found-but-there-control-panel-sound-settings.png
    My audio output device shows in Device Manage but not in System/Sound or in Control Panel... 188d1622967221t-no-audio-device-found-but-there-control-panel-control-panel-audio-inputs-outputs.png
    My audio output device shows in Device Manage but not in System/Sound or in Control Panel... 336189d1622967260t-no-audio-device-found-but-there-control-panel-control-panel-sound-devices.png
    spapakons, Aug 18, 2023
  4. fireberd Win User
    No audio output device is installed
    A screenshot of the Device Manager, Sounds section is still needed. Can't really offer a suggestion until I see what is showing there now.
    e.g this is mine It shows AMD which the audio for HDMI, Realtek and Tranzport which is a wireless controller for my recording studio program.
    My audio output device shows in Device Manage but not in System/Sound or in Control Panel... 124090d1488901086t-no-audio-output-device-installed-device-manager-capture.jpg
    fireberd, Aug 18, 2023
  1. My audio output device shows in Device Manage but not in System/Sound or in Control Panel... - Similar Threads - audio output device
  2. no audio input output device in device manager
    no audio input output device in device manager: Hi , I bought a used device from a while and it showed many problems in it , I am stuck with the problem were suddenly the sound did not come out , I opened the device manager and uninstalled the audio input and output driver then did the scan for hardware change and it got...
  3. no audio input output device in device manager
  4. no audio input output device in device manager
  5. My audio output device shows in Device Manage but not in System/Sound or in Control Panel...
    My audio output device shows in Device Manage but not in System/Sound or in Control Panel...: How do I troubleshoot this? https://answers.microsoft.com/en-us/windows/forum/all/my-audio-output-device-shows-in-device-manage-but/b12e4b08-c1ee-45ff-9de0-0f4c69409741
  6. My audio output device shows in Device Manage but not in System/Sound or in Control Panel...
  7. No audio output devices installed but devices show up on device manager
    No audio output devices installed but devices show up on device manager: Hi, my PC always has a red cross on the sound icon at the taskbar whenever I turn it on. I take a look at the sound settings on the control panel and there are no audio devices listed at the playback menu. I look at the device manager and there are literally 5 audio devices...
  8. Realtek not showing up in Control Panel or Device Manager.
    Realtek not showing up in Control Panel or Device Manager.: I’ve been having this issue for almost a week now and I’m at my wits end. I feel like I’ve researched everything and anything and can’t find a solution. I’ve tried updating straight from Realtek, using my specific MOBO drivers, Windows Catalog and nothing will work. I’ve seen...
  9. No Audio Output Device Installed - Device Manager Lists "High Definition Audio Controller"...
    No Audio Output Device Installed - Device Manager Lists "High Definition Audio Controller"...: Hello all, I am currently running Windows 10 on an MSI GS63 Stealth GS63 Stealth 8RE 64-bit machine. Today I restarted my computer after having installed some unrelated software Bluejeans when suddenly I noticed I could no longer select my normal computer audio as an...
  10. Control Panel Device Manager
    Control Panel Device Manager: Where are they on my window 10 - Dell computer https://answers.microsoft.com/en-us/windows/forum/all/control-panel-device-manager/b3606eb3-afbd-43ad-a043-254425334cae"
