Windows 10: My battery power plan keeps switching to high performance
Discus and support My battery power plan keeps switching to high performance in Windows 10 BSOD Crashes and Debugging to solve the problem; Every 20 minutes my battery plan is switching to high performance. How can I resolve this issue? I am running windows 10.... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Jalenp, Aug 8, 2018.
My battery power plan keeps switching to high performance - Similar Threads - battery power plan
No "High Performance" power plan.
in Windows 10 GamingNo "High Performance" power plan.: When choosing a power plan, only the "balanced" plan is available. Also, when creating your own plan, they offer a balanced one. The question is how to fix this and set more “Maximum performance”?... -
in Windows 10 Software and AppsNo "High Performance" power plan.: When choosing a power plan, only the "balanced" plan is available. Also, when creating your own plan, they offer a balanced one. The question is how to fix this and set more “Maximum performance”?... -
my power plan keeps switching back and forth between high performance and balanced
in Windows 10 Gamingmy power plan keeps switching back and forth between high performance and balanced: so this isnt the first time this has happened but in the past it was down to MSI centre and its 'user scenario' setting , however recently this problem has started happening again with my cpu usage staying at 100% most of the time while only opening task manager. i currently... -
in Windows 10 Software and Appsmy power plan keeps switching back and forth between high performance and balanced: so this isnt the first time this has happened but in the past it was down to MSI centre and its 'user scenario' setting , however recently this problem has started happening again with my cpu usage staying at 100% most of the time while only opening task manager. i currently... -
High performance power plan disappeared
in Windows 10 Software and AppsHigh performance power plan disappeared: Hi, My name is Miko , I have dell G15 with Windows 10I was using High performance mode in power plan from control panelBut suddenly it disappeared so I chose the balanced modeNow I can't restore it and the laptop is running slowI need help and I need to restore and use high... -
High Performance Power Plan Disappeared
in Windows 10 GamingHigh Performance Power Plan Disappeared: I am using the latest version of Windows 11 and I changed my power plan to "Balanced" just to try it out and when I went back into Control Panel to change it back to "High Performance", it was not there anymore. I tried a lot of suggested fixes that are on the internet but... -
High performance power plan missing
in Windows 10 Performance & MaintenanceHigh performance power plan missing: Hi, so it seems like high performnace power plan is missing in my new pc. I've tried a lot of methods, but they didn't work.PS: I already made a post about this, but no one replied.... -
autounattend.xml High Performance power plan
in Windows 10 Supportautounattend.xml High Performance power plan: In previous versions of Windows 10, a default installation would have 3 power plans, and you could simply make a choice. Now only the "Balanced" power plan exists and you have to create whatever plan you want. Using Windows System Image Manager, I created an autounattend.xml... -
High Performance Power Plan and Ultimate Performance Power Plan.
in Windows 10 BSOD Crashes and DebuggingHigh Performance Power Plan and Ultimate Performance Power Plan.: What is the real difference between the High Performance Power Plan and Ultimate Performance Power Plan? https://answers.microsoft.com/en-us/windows/forum/all/high-performance-power-plan-and-ultimate/6625509a-a16e-4c61-a36f-a7c9a5d7ce5c
